    [Plugin][$] FredoBend - v1.6a - 21 Oct 26
    81 Posts 16 Posters 20.3k Views 16 Watching
    • fredo6F
      With FredoBend v1.2b, you can normally keep the quad properties by turning off:
      • Slicing
      • remove coplanar edge
      • soften edges
      Here is a video showing the process.
      FredoBends - Quads.mp4
      Here is the test file. Tell me if this is OK.
      test quads 2.skp
      A 1 Reply Last reply
      • fredo6F
        fredo6 @AISmebel
        @AISmebel said:
        I also want to suggest that after using the plug-in, the components do not deform, bend in shape and retain their component properties
        I don't understand what you mean.
        The component / group property is kept. If you bend a component. the output is a component. Same for subcomponents.
        However, all the content of the container is made unique, because bending is not a transformation but a creation of geometry. This has nothing to do with slicing.
        panixiaP A 2 Replies Last reply
        • panixiaP
          panixia @fredo6
          Wow, I realize that I didn't understand correctly the proposal, so I retreat my + 20 on this.
          Because you basically can't do that in Sketchup (you'd need some sort of modifier system similar to the 3dsMax one to accomplish this).
          I understood that he was talking about a non-slicing behavior instead (which would be preferable).
          • panixiaP
            panixia @AISmebel
            @AISmebel said:
            I would like to ask you to share this interesting plugin. I created a lot of interesting things myself with the help of Claude. It's interesting to see what others are doing.
            It's currently in the last (I hope so) alpha stage, I'll need to fix a couple of edge cases before it can go beta.
              AISmebel @fredo6
              @fredo6 said:
              Вот тестовый файл. Скажите, пожалуйста, всё ли в порядке.
              тестовые квадрокоптеры 2.skp
              2.mp4
                AISmebel @fredo6
                @fredo6 said:
                Я не понимаю, что вы имеете в виду.
                Свойство компонента/группы сохраняется. Если вы изгибаете компонент, на выходе получается компонент. То же самое относится и к подкомпонентам.
                Однако всё содержимое контейнера уникально, поскольку изгибание — это не трансформация, а создание геометрии. Это не имеет ничего общего с разрезанием.
                Perhaps I did not state my thought correctly, perhaps I got confused in the terms, or perhaps my translator did not translate it correctly) I want to say the following: when we use a plugin, is it possible not to deform the component so that the component does not lose its connection with its own kind? As an example in the video, I used the Copy Along Curve plugin. He arranged the components in an arc without deforming or making the components unique.
                3.mp4
                • fredo6F
                  Plugins like Copy Along Curve just move and rotate the objects to position them along the curve. So, this is not really bending and it is another use case.
                  For FredoBend, it is possible to add an option where only the top container is modified, leaving the sub-container not deformed.
                  • alexpacio2013A
                    alexpacio2013
                    It doesn't work for me. With my sketchup 2025 full of plugins, it doesn't work. In practice, if I place the object on a line or a curve, it doesn't get curved. While if I install it on sketchup 2026 with very few plugins, it works. There are some incompatibilities, but it doesn't give me any errors. Anyway, congratulations, it's fantastic.
                    [link text](Here is a video In the first case it is that if up 2025 and in the second scatchup 2026
                    https://community.sketchucation.com/post/1620017)
                      Rich O Brien Moderator @alexpacio2013
                      If there are errors in the Ruby Console you should post those to help Fredo determine the cause.
                      I presume you have an updated LibFredo installed.
                      alexpacio2013A 1 Reply Last reply
                      • alexpacio2013A
                        alexpacio2013 @Rich O Brien
                        @Rich-O-Brien Latest version of FredoBend 1.2b and FredoLib 15.9a. Everything is up to date.
                        Ruby console
                        [#Sketchup::ComponentInstance:0x0000018ac36785f0]
                        [#Sketchup::Group:0x0000018aca8649c0]
                        #<NameError: uninitialized constant Array::Fixnum>
                        C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:12:in block in sum' C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:11:in upto'
                        C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:11:in sum' c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1792:in courbe_register'
                        c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1693:in placement_manage' c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1667:in placement_dragging_move'
                        c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:424:in onMouseMove' #<NameError: uninitialized constant Array::Fixnum> C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:12:in block in sum'
                        C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:11:in upto' C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:11:in sum'
                        c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1792:in courbe_register' c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1693:in placement_manage'
                        c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1667:in placement_dragging_move' c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:424:in onMouseMove'
                        fredo6F 1 Reply Last reply
                          rv1974
                          Looks great Fredo. This is destructive one, isn't it? No way to edit afterwards
                            AISmebel @fredo6
                            @fredo6 said:
                            Для FredoBend можно добавить опцию, при которой изменяется только верхний контейнер , а подконтейнер остается недеформированным.
                            I think that's what you need. At least it would be great to experience it. Thank you.
                            1 Reply Last reply 👍
                            • fredo6F
                              fredo6 @alexpacio2013
                              mx_constructtools
                              It looks like the plugin mx_constructtools is redefining a base method (Array#sum), which is not a good practice and is dangerous for other plugins. This is causing the error.
                              • fredo6F
                                fredo6 @rv1974
                                The bent object is of course new geometry.
                                However, as shown in the main video:
                                • the original object is untouched
                                • If you modify this original object, you can update the bent object in one click.
                                • you can also edit the bent object and change the bending parameters. If the original object has been modified, the new bent object will be updated.
                                • there is an option to save a copy of the original object to an external file. This is for the case where you delete the original object in the model, including its definition.
                                • chonC
                                  chon
                                  Hi all,
                                  running FredoBend v1.2b with LibFredo v15.9a on SU 2019 / Win11 and i've got an issue on the bend generation step with this error log :
                                  "Date: 27-Mar-26 09:24:41 - SU2019.3 - LibFredo6 - v15.9a
                                  Une erreur s'est produite dans
                                  Error in Bend Generation
                                  undefined method `save_copy' for #<Sketchup::ComponentDefinition:0x0000023c3844c1d8>
                                  fredobendcurvetool.rbe: 1195 -- saver_solid_comp
                                  fredobendcurvetool.rbe: 2425 -- generation_step_prepare
                                  fredobendcurvetool.rbe: 3270 -- job_perform
                                  fredobendcurvetool.rbe: 3212 -- job_notification
                                  body_lib6webprogress.rbe: 104 -- call
                                  body_lib6webprogress.rbe: 104 -- process_notify
                                  body_lib6webprogress.rbe: 388 -- fast_process_next_step
                                  body_lib6webprogress.rbe: 358 -- fast_process_start
                                  body_lib6webprogress.rbe: 370 -- fast_process_next
                                  body_lib6webprogress.rbe: 346 -- fast_process_top
                                  body_lib6webprogress.rbe: 123 -- invoke
                                  fredobendcurvetool.rbe: 3158 -- job_start
                                  fredobendcurvetool.rbe: 2392 -- block in generation_launch"
                                  In the Parameters window / Generation parameters, i don't see the build options as shown in the tuto :
                                  Is that the problem ?
                                  Thanks for response
                                  SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                                  • fredo6F
                                    NEW RELEASE: FredoBend v1.2c - 27 Mar 26
                                    Requirements
                                    • LibFredo6: v15.9a or above
                                    FredoBend 1.2c is a maintenance release including:
                                    • Bug fixing
                                    • Evolution of the Save Original objects with 3 options and the capability to retrive the original object, even if it is not present in the model any longer.
                                    Home Page of FredoBend for information and Download.
                                    Main post of this FredoBend thread.
                                    Spirou4DS 1 Reply Last reply
                                    • Spirou4DS
                                      Spirou4D @fredo6
                                      @fredo6
                                      I just installed FredoBend v1.2c + LibFredo6 15.9a - 25 Mar 26 on my SketchUp Make 2017 v 17.2.2555 64bits .
                                      I have the tools but after I choose my Text object and place to the courve....NOTHING !
                                      Impossible to place on the curve ???
                                      Traceback Rubby:
                                      c:/users/patrick/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1656:in `placement_manage'
                                      c:/users/patrick/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1618:in `placement_dragging_move'
                                      c:/users/patrick/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:421:in `onMouseMove'
                                      Error: #<NoMethodError: undefined method `sum' for #<Array:0x0002627992fa30>>
                                      • Spirou4DS
                                        Spirou4D
                                        Hi @fredo6
                                        I just ended the french translation of the LibFredo6 15.9a messages.
                                        And FredoBend v1.2c too.
                                        How to send you the result "LibFredo6_FR.lang" + "FredoBend_FR.lang" please?
                                        • fredo6F
                                          NEW RELEASE: FredoBend v1.2d - 28 Mar 26
                                          Requirements
                                          FredoBend 1.2d is a maintenance release including:
                                          • Bug fixing for SU2017
                                          • fredo6F
                                            fredo6 @Spirou4D
                                            Many thanks. I am lazy to do it.
                                            Just PM the .lang files to me on this forum.
                                            For LibFredo6, this is useful.
                                            For FredoBend, I did not make it translatable yet, until I finish the other features. So, the translation is uncomplete.
                                            • 2 / 5
