    [Plugin][$] FredoBend - v1.5b - 23 Jul 26
    76 Posts 14 Posters 16.4k Views 14 Watching
    • fredo6F
      fredo6 @Dave R
      @Dave-R said:
      Ah ... So the file needs to be saved before using the extension. Makes sense.
      No. you can use FredoBend on New models.
      The SaveCopy feature is just for saving a copy of the original solid to file (in subfolder FredoBend Saved Containers). This is simply not done if the model is new.
      1 Reply Last reply πŸ‘
      • fredo6F
        fredo6 @AISmebel
        @AISmebel said:
        the triangulating line that appears after using the plugin should become soft+smooth. Then the squares of the SubD work. Now the following is happening:
        I am not sure it is possible to identfy and carry over the quad mesh, because of the slicing.
        Could you send me a model and a curve so that I see what can be done. Thanks.
        panixiaP 1 Reply Last reply
          AISmebel
          This post is deleted!
            AISmebel
            @fredo6 I also want to suggest that after using the plug-in, the components do not deform, bend in shape and retain their component properties. This will give more options to the users of your plugin. As an example, I additionally created objects made using the Flowify plugin. It transfers components without distortion, but the components lose their connection to each other, if you can implement this in your plugin, it will be great.
            Test.skp - This is the model you asked for
            panixiaP fredo6F 2 Replies Last reply
            • panixiaP
              panixia @AISmebel
              Nope.
              It should be soft = true; smooth = true AND cast shadows = false otherwise it will not work.
              I agree +20 on this!
              I already said that in the original discussion on Trimble forum and I 100% stand on that.
              Slicing should be optional. The default behavior should be "deform only", that would make more sense.
              A 1 Reply Last reply
              • panixiaP
                panixia @fredo6
                I guess it's super-difficult when you need to slice (so you are creating new geometry with new vertex-order/face-IDs), but it's actually quite easy when you just need to deform.
                The key is that you apply preemptive triangulation (with different properties for planar quads/planar n-gons) at the very beginning of the deforming operation in order to stabilize vertex order, edge properties and UV mapping, then you can safely preserve/restore everything once the deformation is done.
                I'm not a programmer, but I managed to formalize the whole algorithm decently enough that Claude can execute that brilliantly (based on the steps that I use to do manually in order to stabilize a mesh for proper Subdivision/Uv-mapping workflow).
                I achieved good deformations which are reliably preserving quads, and UV mapping with decent fallback methods for n-gons.
                I was planning to share the code with you regardless (for review before publishing it on Sketchucation), I think it could be interesting if you could integrate (and probably improve) it in some of your plugins, this one could be a clear candidate.
                  AISmebel @panixia
                  @panixia said:
                  НСт.
                  Π”ΠΎΠ»ΠΆΠ½ΠΎ Π±Ρ‹Ρ‚ΡŒ soft = true; smooth = true И cast shadows = false, ΠΈΠ½Π°Ρ‡Π΅ это Π½Π΅ сработаСт.
                  I was sure that I was not giving complete information, but I wrote that I knew)) I think Fredo knows exactly what it's about and how it should be. But still, thanks for the correction, maybe this way we will get the desired result faster)
                    AISmebel @panixia
                    @panixia said:
                    Π― ΠΏΠ»Π°Π½ΠΈΡ€ΠΎΠ²Π°Π» ΠΏΠΎΠ΄Π΅Π»ΠΈΡ‚ΡŒΡΡ с Π²Π°ΠΌΠΈ ΠΊΠΎΠ΄ΠΎΠΌ Π² любом случаС (для ΠΏΡ€ΠΎΠ²Π΅Ρ€ΠΊΠΈ ΠΏΠ΅Ρ€Π΅Π΄ ΠΏΡƒΠ±Π»ΠΈΠΊΠ°Ρ†ΠΈΠ΅ΠΉ Π½Π° Sketchucation), Π΄ΡƒΠΌΠ°ΡŽ, Π±Ρ‹Π»ΠΎ Π±Ρ‹ интСрСсно, Ссли Π±Ρ‹ Π²Ρ‹ ΠΈΠ½Ρ‚Π΅Π³Ρ€ΠΈΡ€ΠΎΠ²Π°Π»ΠΈ (ΠΈ, Π²ΠΎΠ·ΠΌΠΎΠΆΠ½ΠΎ, ΡƒΠ»ΡƒΡ‡ΡˆΠΈΠ»ΠΈ) Π΅Π³ΠΎ Π² Π½Π΅ΠΊΠΎΡ‚ΠΎΡ€Ρ‹Π΅ ΠΈΠ· Π²Π°ΡˆΠΈΡ… ΠΏΠ»Π°Π³ΠΈΠ½ΠΎΠ², этот ΠΌΠΎΠΆΠ΅Ρ‚ ΡΡ‚Π°Ρ‚ΡŒ подходящим Π²Π°Ρ€ΠΈΠ°Π½Ρ‚ΠΎΠΌ.
                    I would like to ask you to share this interesting plugin. I created a lot of interesting things myself with the help of Claude. It's interesting to see what others are doing.
                    • fredo6F
                      With FredoBend v1.2b, you can normally keep the quad properties by turning off:
                      • Slicing
                      • remove coplanar edge
                      • soften edges
                      Here is a video showing the process.
                      FredoBends - Quads.mp4
                      Here is the test file. Tell me if this is OK.
                      test quads 2.skp
                      • fredo6F
                        fredo6 @AISmebel
                        I don't understand what you mean.
                        The component / group property is kept. If you bend a component. the output is a component. Same for subcomponents.
                        However, all the content of the container is made unique, because bending is not a transformation but a creation of geometry. This has nothing to do with slicing.
                        panixiaP A 2 Replies Last reply
                        • panixiaP
                          panixia @fredo6
                          Wow, I realize that I didn't understand correctly the proposal, so I retreat my + 20 on this.
                          Because you basically can't do that in Sketchup (you'd need some sort of modifier system similar to the 3dsMax one to accomplish this).
                          I understood that he was talking about a non-slicing behavior instead (which would be preferable).
                          • panixiaP
                            panixia @AISmebel
                            It's currently in the last (I hope so) alpha stage, I'll need to fix a couple of edge cases before it can go beta.
                              AISmebel @fredo6
                              @fredo6 said:
                              Π’ΠΎΡ‚ тСстовый Ρ„Π°ΠΉΠ». Π‘ΠΊΠ°ΠΆΠΈΡ‚Π΅, поТалуйста, всё Π»ΠΈ Π² порядкС.
                              тСстовыС ΠΊΠ²Π°Π΄Ρ€ΠΎΠΊΠΎΠΏΡ‚Π΅Ρ€Ρ‹ 2.skp
                              2.mp4
                                AISmebel @fredo6
                                @fredo6 said:
                                Π― Π½Π΅ понимаю, Ρ‡Ρ‚ΠΎ Π²Ρ‹ ΠΈΠΌΠ΅Π΅Ρ‚Π΅ Π² Π²ΠΈΠ΄Ρƒ.
                                Бвойство ΠΊΠΎΠΌΠΏΠΎΠ½Π΅Π½Ρ‚Π°/Π³Ρ€ΡƒΠΏΠΏΡ‹ сохраняСтся. Если Π²Ρ‹ ΠΈΠ·Π³ΠΈΠ±Π°Π΅Ρ‚Π΅ ΠΊΠΎΠΌΠΏΠΎΠ½Π΅Π½Ρ‚, Π½Π° Π²Ρ‹Ρ…ΠΎΠ΄Π΅ получаСтся ΠΊΠΎΠΌΠΏΠΎΠ½Π΅Π½Ρ‚. Π’ΠΎ ΠΆΠ΅ самоС относится ΠΈ ΠΊ ΠΏΠΎΠ΄ΠΊΠΎΠΌΠΏΠΎΠ½Π΅Π½Ρ‚Π°ΠΌ.
                                Однако всё содСрТимоС ΠΊΠΎΠ½Ρ‚Π΅ΠΉΠ½Π΅Ρ€Π° ΡƒΠ½ΠΈΠΊΠ°Π»ΡŒΠ½ΠΎ, ΠΏΠΎΡΠΊΠΎΠ»ΡŒΠΊΡƒ ΠΈΠ·Π³ΠΈΠ±Π°Π½ΠΈΠ΅ β€” это Π½Π΅ трансформация, Π° созданиС Π³Π΅ΠΎΠΌΠ΅Ρ‚Ρ€ΠΈΠΈ. Π­Ρ‚ΠΎ Π½Π΅ ΠΈΠΌΠ΅Π΅Ρ‚ Π½ΠΈΡ‡Π΅Π³ΠΎ ΠΎΠ±Ρ‰Π΅Π³ΠΎ с Ρ€Π°Π·Ρ€Π΅Π·Π°Π½ΠΈΠ΅ΠΌ.
                                Perhaps I did not state my thought correctly, perhaps I got confused in the terms, or perhaps my translator did not translate it correctly) I want to say the following: when we use a plugin, is it possible not to deform the component so that the component does not lose its connection with its own kind? As an example in the video, I used the Copy Along Curve plugin. He arranged the components in an arc without deforming or making the components unique.
                                3.mp4
                                • fredo6F
                                  Plugins like Copy Along Curve just move and rotate the objects to position them along the curve. So, this is not really bending and it is another use case.
                                  For FredoBend, it is possible to add an option where only the top container is modified, leaving the sub-container not deformed.
                                  • alexpacio2013A
                                    alexpacio2013
                                    It doesn't work for me. With my sketchup 2025 full of plugins, it doesn't work. In practice, if I place the object on a line or a curve, it doesn't get curved. While if I install it on sketchup 2026 with very few plugins, it works. There are some incompatibilities, but it doesn't give me any errors. Anyway, congratulations, it's fantastic.
                                    [link text](Here is a video In the first case it is that if up 2025 and in the second scatchup 2026
                                    https://community.sketchucation.com/post/1620017)
                                      Rich O Brien Moderator @alexpacio2013
                                      If there are errors in the Ruby Console you should post those to help Fredo determine the cause.
                                      I presume you have an updated LibFredo installed.
                                      alexpacio2013A 1 Reply Last reply
                                      • alexpacio2013A
                                        alexpacio2013 @Rich O Brien
                                        @Rich-O-Brien Latest version of FredoBend 1.2b and FredoLib 15.9a. Everything is up to date.
                                        Ruby console
                                        [#Sketchup::ComponentInstance:0x0000018ac36785f0]
                                        [#Sketchup::Group:0x0000018aca8649c0]
                                        #<NameError: uninitialized constant Array::Fixnum>
                                        C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:12:in block in sum' C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:11:in upto'
                                        C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:11:in sum' c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1792:in courbe_register'
                                        c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1693:in placement_manage' c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1667:in placement_dragging_move'
                                        c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:424:in onMouseMove' #<NameError: uninitialized constant Array::Fixnum> C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:12:in block in sum'
                                        C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:11:in upto' C:/Users/roberto.bolletta/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/mx_constructtools/mx_constructtools.rb:11:in sum'
                                        c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1792:in courbe_register' c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1693:in placement_manage'
                                        c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:1667:in placement_dragging_move' c:/users/roberto.bolletta/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/fredo6_fredobend/fredobendcurvetool.rbe:424:in onMouseMove'
                                        fredo6F 1 Reply Last reply
                                          rv1974
                                          Looks great Fredo. This is destructive one, isn't it? No way to edit afterwards
                                            AISmebel @fredo6
                                            @fredo6 said:
                                            Для FredoBend ΠΌΠΎΠΆΠ½ΠΎ Π΄ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΎΠΏΡ†ΠΈΡŽ, ΠΏΡ€ΠΈ ΠΊΠΎΡ‚ΠΎΡ€ΠΎΠΉ измСняСтся Ρ‚ΠΎΠ»ΡŒΠΊΠΎ Π²Π΅Ρ€Ρ…Π½ΠΈΠΉ ΠΊΠΎΠ½Ρ‚Π΅ΠΉΠ½Π΅Ρ€ , Π° ΠΏΠΎΠ΄ΠΊΠΎΠ½Ρ‚Π΅ΠΉΠ½Π΅Ρ€ остаСтся Π½Π΅Π΄Π΅Ρ„ΠΎΡ€ΠΌΠΈΡ€ΠΎΠ²Π°Π½Π½Ρ‹ΠΌ.
                                            I think that's what you need. At least it would be great to experience it. Thank you.
                                            • 2 / 4
