    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • fredo6F
      fredo6 @SunnyGee2017
      @SunnyGee2017
      Can also invoke menu Window > LibFredo6 Settings.... > Fredo6 Plugin Information... and copy/paste here the content of the Ruby Console.
      This will tell me which version of plugins you have.
      S 1 Reply Last reply
        SunnyGee2017
        Fredo6 Plugins Information on 2026-02-08 18:19:24 +0800
        • Sketchup: 24.0.553
        • LibFredo6: v15.8d
        • LibFredo6 Binary loaded
        • Sketchucation ExtensionStore: NOT installed
        • SCFLicense: NOT installed
        • Fredo6 Plugins
          Curviloft v2.0a
          FredoTools v4.5c
          JointPushPull v4.9a
          RoundCorner v3.4a
          SunnyGee2017 @fredo6
          @fredo6
          • LibFredo6: v15.8d
          • Fredo6 Plugins
            Curviloft v2.0a
            FredoTools v4.5c
            JointPushPull v4.9a
            RoundCorner v3.4a
            I'm sure @fredo6 will have more to say...
            but the report your posted shows that although you have the latest versions of the 4 extensions installed,
            you don't have the SketchUcation toolset installed - for the ExtensionStore and the required SCFLicensing files.
            Without those all licensed extensions will not work.
            Download the RBZ for the SketchUcation tools and use the Extension Manager dialog's Install... button.
            Restart SketchUp to sync everything.
            Now you will have the licensing set up.
            You need to validate appropriate licenses for the 4 fredo extensions.
            If you already have those use them, or get them from the appropriate page on this forum.
            If you haven't already got a license then buy it.
            Restart SketchUp after all of this to sync everything...
            • G
              GavinG
              I have recently upgraded to sketchup 2026 and my laptop to windows 11. Up till today my Fredo^ plugins have been working fine, until today. I have the prepetual licences for all the plugins, and when I want to use them I get a window saying - TRIAL PERIOD EXPIRED etc etc. I have removed all the files from my PC, and reinstalled Fredo^ and all the plugins from my licence profile on Sketchucation. I have restarted sketchup and still receive the same notification. What must i do next please. Can admin assist?
              Dave RD R 2 Replies Last reply
                Dave R @GavinG
                @GavinG do you have the latest version of the Sketchucation Extension Store installed?
                • G
                  GavinG
                  I think so, I have 3 new icons on my ribbon ( see attached). This is where I get directed when looking for Sketchucation Extension Store
                  • G
                    GavinG
                    • fredo6F
                      First, when you have a problem of license, do not try to reinstall. Just check you have the latest versions.
                      Also, if you get the message of expiration, try first to revalidate the license. It won't count for a new seat.
                      Does it work in your case?
                      G 1 Reply Last reply
                      • fredo6F
                        NEW RELEASE: LibFredo6 v15.8e - 15 Feb 26
                        LibFredo6 15.8e is a maintenance release. It includes changes related to:
                        • Bug Fixing
                        • Future compatibility
                        ntxdaveN 1 Reply Last reply
                        • ntxdaveN
                          ntxdave @fredo6
                          @fredo6 Is there any place where we can find out what the bug fixes are?
                          Press F1...thank me later
                          • ntxdaveN
                            ntxdave
                            I did a quick test on an old Animator file and it looks like we now can use perspective and generate a video.
                            • G
                              GavinG @fredo6
                              @fredo6 - I have tried to uninstall and reinstall, no luck, I have just installed the plugin as indicated below in the next reply, still nothing working. I still get the TRIAL PRERIOD EXPIRED window
                              fredo6F 1 Reply Last reply
                              • fredo6F
                                fredo6 @GavinG
                                @GavinG
                                When you get the expiration message, did you try to click on the button 'Manage License' and revalidate the license (using the file you received by email when you purchased the license)?
                                If you do not have the license file, you can retrieve it and download it at https://sketchucation.com/webshop/my-licences.php. Just sign in.
                                • ntxdaveN
                                  ntxdave @ntxdave
                                  said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
                                  Well, I also tried to generate a video with the Animator file that has both perspective and parallel and the generation stopped when it switched from parallel to perspective. So, if the file has all scenes with the camera set the same way (either perspective or parallel) it works fine but having both options in the same file will not generate the video.
                                  Just thought I would pass this along but maybe you already knew that.
                                    roxanmusni Newcomers @GavinG
                                    @GavinG this is also my problem now. Can someone help me fix this?
                                      Rich O Brien Moderator @roxanmusni
                                      @roxanmusni said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
                                      If you have a license and experience issues please update extensions to recent releases
                                      • P
                                        polosan
                                        is it still available for skp 2021?
                                        • fredo6F
                                          fredo6 @polosan
                                          @polosan said in [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26:
                                          yes.
                                            The current LibFredo6 works with all recent versions of Sketchup.
                                            There is also a legacy version in the PluginStore for older versions - i.e. <= v2016
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 113
                                            • 114
                                            • 110 / 114
