    2.3k Posts 515 Posters 2.3m Views 520 Watching
      Kondybas
      WOW!
      I promise I'll be VERY careful with licenses now!
      Am I got it right that SUTools 5.0.3 is not compatible with SU2017?
        Rich O Brien Moderator @Kondybas
        @Kondybas
        Correct, but we'll take a look and see what we can do to make it work.
          Kondybas
          Thank you very much for all the efforts, SketchUp is the only CAD I really love since version 6.
          1 Reply Last reply 👏 Reply Quote 2
          • E Offline
            ethansatsky Newcomers
            Im activating my Toposhaper liscense, but when I select the .scflience liscense, I get a message saying: error in liscense validation. repsonse from sketchucation liscense is not in the database
              Rich O Brien Moderator @ethansatsky
              @ethansatsky
              Yeah, I can confirm there is a hiccup. Give us a few mins to look into it.
                @ethansatsky
                Can you try again please?
                  dmsone
                  Hello, I purchased the "round corner" license, installed the latest Fredo6, and Sketchucation. When I press the round corner plugin button, nothing happens. Appreciate any help or advice.
                  A 1 Reply Last reply Reply Quote 0
                    Anne O Grady @dmsone
                    @dmsone
                    Hi there - when I look at the license it appears that it has been activated. Could you send me a screenshot of this issue to support@sketchucation.com and I can help you from there.
                    Anne
                    • N Offline
                      nebhamzah
                      Hi can anyone guide me on how to release license seats? I have gone to sketchucation>global license status but nothing come up. but if i checked under my license page i have all the plugins i have purchased with number of seats linked to it. i need to unlink some as im not using that computer anymore.
                        With the latest versions of the SketchUcation tools installed you should see the options on our web page or in one of the settings tabs in the ExtensionStore dialog ?
                        If not Rich will probably be able to do something via admin...
                          @nebhamzah
                          Releasing seats at My Licenses
                            Christel Chenot
                            Hello,
                            I'm trying to use Thrupaint2 by Fredo06, which indicates that my trial license expired in 2021. However, I don't recall having used this extension before. Would it be possible to obtain a history or correct this date error? Thank you in advance, have a nice day.
                            Bonjour,
                            J'essaye d'utiliser Thrupaint2 de Fredo06 qui indique que ma licence d'essai a expiré en 2021. Or, il ne me semble pas avoir déjà utilisé cette extension précédémment. Serait-ce possible d'obtenir un historique ou de corriger cette erreur de date ? Merci d'avance, belle journée
                              Rich O Brien Moderator @Christel Chenot
                              @Christel-Chenot said in SCFLicense: Extension Licensing on Sketchucation:
                              ThruPaint was originally free and got a major update and went commercial.
                              I believe v1 is still in FredoTools
                                Christel Chenot
                                Hello @Rich-O-Brien
                                Thank you for your reply.
                                Indeed, but Thrupaint 2 has been on the market since 2023, yet my error message indicates that the trial period ended in December 2021.
                                I've never used Thrupaint 2, and I don't understand why the 30-day trial isn't working.
                                Is it possible to contact Fredo06? (Perhaps this isn't the right forum section for my question?)
                                Thank You 🙂
                                Bonjour Rich O'Brien,
                                Merci pour cette réponse.
                                En effet, mais Thrupaint 2 est commercialisé depuis 2023, or mon message d'erreur indique que la période d'essai est terminée depuis Décembre 2021.
                                Je n'ai jamais utilisé Thrupaint 2, je ne comprends pas pourquoi l'essai de 30 jours ne fonctionne pas.
                                Est-il possible de contacter @fredo6 ? (peut-être n'est-ce pas le bon endroit du forum pour ma question ? )
                                Merci 🙂
                                  @fredo6 gets his attention.
                                  C 1 Reply Last reply 👍 Reply Quote 0
                                  • fredo6F Offline
                                    Sorry, there may be a problem.
                                    Could you give more information on your set up. Just invoke the menu Window > LibFredo6 Settings... > Fredo6 Plugin Information for Sketchucation Support, copy/paste the output of the Ruby Console here. Thanks.
                                    C 1 Reply Last reply Reply Quote 0
                                      Christel Chenot @Rich O Brien
                                      @Rich-O-Brien Hello, i made it in my french text 😉 Thank You
                                        Christel Chenot @fredo6
                                        @fredo6
                                        Hello,
                                        Thank you for your response and follow-up.
                                        Here is the requested informations.
                                        Have a nice day.
                                        Bonjour @fredo6
                                        Merci pour votre réponse et votre suivi.
                                        Voici les informations demandées.
                                        Belle journée
                                        Fredo6 Plugins Information on 2025-12-09 19:06:23 +0100
                                        • Sketchup: 26.0.429
                                        • LibFredo6: v15.6b
                                        • LibFredo6 Binary loaded
                                        • Sketchucation ExtensionStore: 4.4.1
                                        • SCFLicense: v6.4a - 74
                                        • Fredo6 Plugins
                                          Curviloft v2.0a
                                          FredoScale v3.6a - licensed FULL
                                          FredoTools v4.3a
                                          JointPushPull v4.9a
                                          RoundCorner v3.4a
                                          ThruPaint v2.8d
                                          Signature File: 2025-11-27 12:04:58 +0100
                                          FredoScale: 2025-11-27 12:44:06 +0100
                                          jemoavi14 Newcomers @fredo6
                                          @fredo6 Hola Fredo, intento entrar al link y no me deja, tengo un proyecto y quiero comprar la licencia
                                            Christel Chenot
                                            Thanks to Fredo6 for the sending solution 🙂 - Solved
                                            Merci à @fredo6 pour la solution qui m'a été envoyée 🙂 - Résolu
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 115
                                            • 116
                                            • 109 / 116
