    [Plugin] Multiple Offsets (Updated 09-Feb-2014)
    37 Posts 16 Posters 78.1k Views 16 Watching
      darrellhaemer
      Can anyone confirm that this extension still works (or doesn't) in SketchUp 2020? I can't seem to get it to have an effect.
        It works for me in SketchUp 2021. I would expect it should work in 2020, too.
        Click on the picture
        BTW, your profile indicates you are using SU2016. Please update your profile.
        • HornOxxH Offline
          HornOxx
          Hi everyone—does anyone know if this plugin also works somehow on SU 2025? Unfortunately, I can't get it to work.
          never trust a skinny cook
            Rich O Brien Moderator @HornOxx
            @HornOxx said in [Plugin] Multiple Offsets (Updated 09-Feb-2014):
            Yeah, it is broken. If you check the Console you can see it throws some errors.
            We will take a look.
              Any error messages in the Ruby Console ?
              Are you following the detailed instructions.
              It hasn't been supported for sometime - the author has stopped all development on his extensions.
              Although it's old it has been reported as working in versions up to a few years ago...
                You get this on 2026
                #<Sketchup::Face:0x000001956f6860e0> did not offset:
                  I was also looking ! It seems to be a simple issue with 'FixNum' being deprecated in the newer Ruby version, replaced by 'Integer'.
                  I'll edit the file and publish an updated version asap.
                  Under the author's © notice it's allowed...
                  • HornOxxH Offline
                    HornOxx
                    ...thanks to you Both for checking this 🤚
                      v5 is now available in the PluginStore / ExtensionStore³
                      https://sketchucation.com/pluginstore?pln=Multiple_Offsets
                      It's now compatible with the newer SketchUp version's Ruby methods [e.g. 'FixNum' was deprecated in favor of 'Integer']
                      The RBZ is now also 'signed' to suit all Loading Policies...
                      • HornOxxH Offline
                        HornOxx
                        ...and works so well now!! Thanks Tig!
                        • 2 / 2
