    [Plugin] Multiple Offsets (Updated 09-Feb-2014)
    37 Posts 16 Posters 77.4k Views 16 Watching
      Thank you very much for the update, Sam. It does exactly what I needed.
      nmhai: That's not an issue with the plugin. You'd get that with the native offset tool as well. The error is in the setup. You can either fix by deleting the unwanted edges or you start with the inner most profile and offset outward. You might also have a look at TIG's Smart Offset.
      • cottyC Offline
        cotty
        @dave r said:
        update
        my SketchUp gallery
          darrellhaemer
          Can anyone confirm that this extension still works (or doesn't) in SketchUp 2020? I can't seem to get it to have an effect.
            It works for me in SketchUp 2021. I would expect it should work in 2020, too.
            Click on the picture
            BTW, your profile indicates you are using SU2016. Please update your profile.
            • HornOxxH Offline
              HornOxx
              Hi everyone—does anyone know if this plugin also works somehow on SU 2025? Unfortunately, I can't get it to work.
              never trust a skinny cook
              • Rich O BrienR Online
                Rich O Brien Moderator @HornOxx
                @HornOxx said in [Plugin] Multiple Offsets (Updated 09-Feb-2014):
                Yeah, it is broken. If you check the Console you can see it throws some errors.
                We will take a look.
                  Any error messages in the Ruby Console ?
                  Are you following the detailed instructions.
                  It hasn't been supported for sometime - the author has stopped all development on his extensions.
                  Although it's old it has been reported as working in versions up to a few years ago...
                    You get this on 2026
                    #<Sketchup::Face:0x000001956f6860e0> did not offset:
                      I was also looking ! It seems to be a simple issue with 'FixNum' being deprecated in the newer Ruby version, replaced by 'Integer'.
                      I'll edit the file and publish an updated version asap.
                      Under the author's © notice it's allowed...
                      • HornOxxH Offline
                        HornOxx
                        ...thanks to you Both for checking this 🤚
                          v5 is now available in the PluginStore / ExtensionStore³
                          https://sketchucation.com/pluginstore?pln=Multiple_Offsets
                          It's now compatible with the newer SketchUp version's Ruby methods [e.g. 'FixNum' was deprecated in favor of 'Integer']
                          The RBZ is now also 'signed' to suit all Loading Policies...
                          • HornOxxH Offline
                            HornOxx
                            ...and works so well now!! Thanks Tig!
                            • 2 / 2
