    2.3k Posts 515 Posters 2.3m Views 520 Watching
      @LEADERFIT3D
      The advice here: https://community.sketchucation.com/post/1617255
      Delete this:
      Restart SketchUp
      • O Offline
        othn11 @fredo6
        @fredo6
        hi, ther's any type of discount for subscription "Fredo6 Bundle 2022 - A bundle of 8 plugins"
        thank's
          ppappa0099 Newcomers
          @fredo6
          Can you help me.!!
          I don't know why.
          θž’εΉ•ζ“·ε–η•«ι’ 2025-11-13 010402.png θž’εΉ•ζ“·ε–η•«ι’ 2025-11-13 010420.png θž’εΉ•ζ“·ε–η•«ι’ 2025-11-13 010429.png
            Rich O Brien Moderator @ppappa0099
            @ppappa0099
            Please follow the prompt and delete the signature file at C:\Users\SomeName\AppData\Local\SCF Licenses
            Restart SketchUp
            If your device name uses special characters please rename it to only use alphanumeric.
            P 2 Replies Last reply Reply Quote 0
              ppappa0099 Newcomers @Rich O Brien
              @Rich-O-Brien said in SCFLicense: Extension Licensing on Sketchucation:
              @ppappa0099
              Restart SketchUp
                mandraget
                hi fredo can you help me releasing my round corner license because there no option to release it from web, i need it asap, thank you
                • N Offline
                  nguyenhung269 Newcomers
                  I can't log out of activation on other computers can you help me
                    Rich O Brien Moderator @mandraget
                    @mandraget said in SCFLicense: Extension Licensing on Sketchucation:
                    Update extensions on all these devices to enable online releasing.
                    Most important is to update Sketchucation Tools.
                    M 1 Reply Last reply Reply Quote 0
                      Rich O Brien Moderator @nguyenhung269
                      @nguyenhung269
                      Please update Sketchucation Tools on all these devices
                      K 1 Reply Last reply Reply Quote 0
                        mandraget @Rich O Brien
                        but i cannot access there device right now, that my office device, and my office on day off till friday
                          @Rich-O-Brien
                          Plugin: JointPushPull (v7.1a - 74) on SketchUp 2023
                          Issue: Persistent License Validation Errors (A04 $\rightarrow$ B03) after correcting computer name.
                          Hello SCF Support Team,
                          I'm stuck in a license loop after changing my computer name, which triggered ERROR_A04.
                          I have tried the following steps multiple times:
                          1.Deleted Signature File: Erased SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt to force revalidation.
                          2.Activation Failed (B03): Upon trying to "Activate License", I immediately receive ERROR_B03 (connection failure to server).
                          3.Network Check: I confirmed I have a stable internet connection and temporarily disabled Windows Defender Firewall (Public/Private). The B03 error still persists.
                          Since the system cannot connect to complete the revalidation, I'm stuck "Not Licensed".
                          Could you please provide a manual method or an alternative solution to bypass the online connection for revalidation?
                          Thank you!
                            @ppappa0099
                            Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                              Fredo6 Plugins Information on 2025-11-19 01:27:43 +0800
                              • Platform: x64-mswin64_140 - Ruby: 2.7.2
                              • Sketchup: 23.0.397
                              • LibFredo6: v15.5a
                              • LibFredo6 Binary loaded
                              • Sketchucation ExtensionStore: 5.0.3
                              • SCFLicense: v7.1a - 74
                              • Fredo6 Plugins
                                Curviloft v2.0a
                                JointPushPull v4.8a
                                Signature File: 2025-11-19 01:01:49 +0800
                                @ppappa0099 Is your device named with non-alphanumeric characters?
                                Please don't delete posts that have info we need to help.
                                Error B03 is related the non-alphanumeric characters
                                  As well as your computer-name, your windows-username shouldn't contain any non-ASCII characters.
                                  Because these can trip up Ruby code processes...
                                  Also you do need to restart your computer after the renaming...
                                    Kondybas @Rich O Brien
                                    @nguyenhung269
                                    I have the same problem.
                                    Old notebook was formatted and donated to the ukrainian army. Sure licenses were not released before. Now I have licenses that cannot be revoked via the web page.
                                      Rich O Brien Moderator @Kondybas
                                      @Kondybas
                                      Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp on your current device and copy/paste the output into your reply.
                                        Kondybas
                                        Fredo6 Plugins Information on 2025-11-18 20:59:03 +0200
                                        • Platform: x64-mingw32 - Ruby: 2.2.4
                                        • Sketchup: 17.2.2555
                                        • LibFredo6: v15.5a
                                        • Sketchucation ExtensionStore: 4.3.1
                                        • SCFLicense: v6.1a - 72
                                        • Fredo6 Plugins
                                          Curviloft v2.0a
                                          Curvizard v2.5a
                                          FredoScale v3.6a
                                          JointPushPull v4.9a
                                          RoundCorner v3.4a
                                          ToolsOnSurface v2.6a
                                          Signature File: 2025-11-18 19:44:48 +0200
                                          @Kondybas Please update Sketchucation Tools to v 5.0.3
                                          Sketchucation Tools | SketchUcation
                                          (sketchucation.com)
                                          Restart SketchUp
                                          After restart run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and copy/paste output
                                          Latest Sketchucation Tools enables online releasing.
                                            Kondybas
                                            I have that pane not responding to clicks
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 115
                                            • 116
                                            • 108 / 116
