    2.3k Posts 507 Posters 1.3m Views 512 Watching
    • N Offline
      nlipovac
      Hi Fredo,
      I work for a school where I teach 3D modeling to interior designers, and they would like to purchase Fredo6Bundle2022Corp30 - A bundle of 8 plugins for activation on 30 devices, but the administrator would like a proforma invoice instead of buying it through the Sketchucation store. Is that doable?
      • E Offline
        epitaph Newcomers
        After using fredoghost in the model, there will be a warning as shown in the figure when the model is opened again. In addition, lord of toolbar cannot be used normally in version 2026, and it will disappear after adding a custom toolbar and restarting.
          This looks more like an issue with Libfredo and FredoGhost than our licensing system.
          Maybe ping Fredo on his FredoGhost thread
            Tramhuong Newcomers
            @sd091688 said in SCFLicense: Extension Licensing on Sketchucation:
            Hope anyone can help to make it work cause I need it urgently.
              @Tramhuong Do you have a problem ?
              You are quoting another user's problem.
                LEADERFIT3D Newcomers @Rich O Brien
                @Rich-O-Brien said in SCFLicense: Extension Licensing on Sketchucation:
                C:\Users\SomeName\AppData\Local\SCF Licenses et supprimez le fichier SCFLicenseSignature - NE PAS MODIFIER NI SUPPRIMER.txt .
                Bonjour
                Voici ce qu'il y a dans le dossier en question :
                Je n'ai pas réinstallé le système, j'ai changer de PC en intégralité... Système d'exploitation inclus
                  @LEADERFIT3D
                  The advice here: https://community.sketchucation.com/post/1617255
                  Delete this:
                  Restart SketchUp
                  • O Offline
                    othn11 @fredo6
                    @fredo6
                    hi, ther's any type of discount for subscription "Fredo6 Bundle 2022 - A bundle of 8 plugins"
                    thank's
                      ppappa0099 Newcomers
                      @fredo6
                      Can you help me.!!
                      I don't know why.
                      螢幕擷取畫面 2025-11-13 010402.png 螢幕擷取畫面 2025-11-13 010420.png 螢幕擷取畫面 2025-11-13 010429.png
                        Rich O Brien Moderator @ppappa0099
                        @ppappa0099
                        Please follow the prompt and delete the signature file at C:\Users\SomeName\AppData\Local\SCF Licenses
                        Restart SketchUp
                        If your device name uses special characters please rename it to only use alphanumeric.
                        P 2 Replies Last reply Reply Quote 0
                          ppappa0099 Newcomers @Rich O Brien
                          @ppappa0099
                          Restart SketchUp
                            mandraget
                            hi fredo can you help me releasing my round corner license because there no option to release it from web, i need it asap, thank you
                            • N Offline
                              nguyenhung269 Newcomers
                              I can't log out of activation on other computers can you help me
                                Rich O Brien Moderator @mandraget
                                @mandraget said in SCFLicense: Extension Licensing on Sketchucation:
                                Update extensions on all these devices to enable online releasing.
                                Most important is to update Sketchucation Tools.
                                M 1 Reply Last reply Reply Quote 0
                                  Rich O Brien Moderator @nguyenhung269
                                  @nguyenhung269
                                  Please update Sketchucation Tools on all these devices
                                  K 1 Reply Last reply Reply Quote 0
                                    mandraget @Rich O Brien
                                    but i cannot access there device right now, that my office device, and my office on day off till friday
                                      @Rich-O-Brien
                                      Plugin: JointPushPull (v7.1a - 74) on SketchUp 2023
                                      Issue: Persistent License Validation Errors (A04 $\rightarrow$ B03) after correcting computer name.
                                      Hello SCF Support Team,
                                      I'm stuck in a license loop after changing my computer name, which triggered ERROR_A04.
                                      I have tried the following steps multiple times:
                                      1.Deleted Signature File: Erased SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt to force revalidation.
                                      2.Activation Failed (B03): Upon trying to "Activate License", I immediately receive ERROR_B03 (connection failure to server).
                                      3.Network Check: I confirmed I have a stable internet connection and temporarily disabled Windows Defender Firewall (Public/Private). The B03 error still persists.
                                      Since the system cannot connect to complete the revalidation, I'm stuck "Not Licensed".
                                      Could you please provide a manual method or an alternative solution to bypass the online connection for revalidation?
                                      Thank you!
                                        @ppappa0099
                                        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                          Fredo6 Plugins Information on 2025-11-19 01:27:43 +0800
                                          • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                          • Sketchup: 23.0.397
                                          • LibFredo6: v15.5a
                                          • LibFredo6 Binary loaded
                                          • Sketchucation ExtensionStore: 5.0.3
                                          • SCFLicense: v7.1a - 74
                                          • Fredo6 Plugins
                                            Curviloft v2.0a
                                            JointPushPull v4.8a
                                            Signature File: 2025-11-19 01:01:49 +0800
                                            @ppappa0099 Is your device named with non-alphanumeric characters?
                                            Please don't delete posts that have info we need to help.
                                            Error B03 is related the non-alphanumeric characters
                                            • 105
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 114
                                            • 115
                                            • 107 / 115
