    2.3k Posts 517 Posters 3.0m Views 522 Watching
    • P
      ppappa0099 Newcomers @Rich O Brien
      @Rich-O-Brien
      Plugin: JointPushPull (v7.1a - 74) on SketchUp 2023
      Issue: Persistent License Validation Errors (A04 $\rightarrow$ B03) after correcting computer name.
      Hello SCF Support Team,
      I'm stuck in a license loop after changing my computer name, which triggered ERROR_A04.
      I have tried the following steps multiple times:
      1.Deleted Signature File: Erased SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt to force revalidation.
      2.Activation Failed (B03): Upon trying to "Activate License", I immediately receive ERROR_B03 (connection failure to server).
      3.Network Check: I confirmed I have a stable internet connection and temporarily disabled Windows Defender Firewall (Public/Private). The B03 error still persists.
      Since the system cannot connect to complete the revalidation, I'm stuck "Not Licensed".
      Could you please provide a manual method or an alternative solution to bypass the online connection for revalidation?
      Thank you!
        Rich O Brien Moderator @ppappa0099
        @ppappa0099
        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
        P 1 Reply Last reply
        • P
          @Rich-O-Brien said in SCFLicense: Extension Licensing on Sketchucation:
          Fredo6 Plugins Information on 2025-11-19 01:27:43 +0800
          • Platform: x64-mswin64_140 - Ruby: 2.7.2
          • Sketchup: 23.0.397
          • LibFredo6: v15.5a
          • LibFredo6 Binary loaded
          • Sketchucation ExtensionStore: 5.0.3
          • SCFLicense: v7.1a - 74
          • Fredo6 Plugins
            Curviloft v2.0a
            JointPushPull v4.8a
            Signature File: 2025-11-19 01:01:49 +0800
            @ppappa0099 Is your device named with non-alphanumeric characters?
            Please don't delete posts that have info we need to help.
            Error B03 is related the non-alphanumeric characters
              As well as your computer-name, your windows-username shouldn't contain any non-ASCII characters.
              Because these can trip up Ruby code processes...
              Also you do need to restart your computer after the renaming...
              • K
                Kondybas @Rich O Brien
                @nguyenhung269
                Please update Sketchucation Tools on all these devices
                I have the same problem.
                Old notebook was formatted and donated to the ukrainian army. Sure licenses were not released before. Now I have licenses that cannot be revoked via the web page.
                  Rich O Brien Moderator @Kondybas
                  @Kondybas
                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp on your current device and copy/paste the output into your reply.
                  • K
                    Kondybas
                    Fredo6 Plugins Information on 2025-11-18 20:59:03 +0200
                    • Platform: x64-mingw32 - Ruby: 2.2.4
                    • Sketchup: 17.2.2555
                    • LibFredo6: v15.5a
                    • Sketchucation ExtensionStore: 4.3.1
                    • SCFLicense: v6.1a - 72
                    • Fredo6 Plugins
                      Curviloft v2.0a
                      Curvizard v2.5a
                      FredoScale v3.6a
                      JointPushPull v4.9a
                      RoundCorner v3.4a
                      ToolsOnSurface v2.6a
                      Signature File: 2025-11-18 19:44:48 +0200
                      @Kondybas Please update Sketchucation Tools to v 5.0.3
                      Sketchucation Tools | SketchUcation
                      (sketchucation.com)
                      Restart SketchUp
                      After restart run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and copy/paste output
                      Latest Sketchucation Tools enables online releasing.
                      • K
                        Kondybas
                        I have that pane not responding to clicks
                          Ah....SketchUp 2017.
                          Please Install this version
                          SketchUcationTools_v4.4.1.rbz
                          • K
                            Kondybas
                            Have installed 4.4.1 and still no checkboxes for license revokation
                            Also there are no button images and bottom buttons in SUTools 4.4.1 (4.3.1 has the same issue for a while)
                              Check https://sketchucation.com/webshop/my-licences.php now
                              1 Reply Last reply 😳
                              • K
                                Kondybas
                                WOW!
                                I promise I'll be VERY careful with licenses now!
                                Am I got it right that SUTools 5.0.3 is not compatible with SU2017?
                                  @Kondybas
                                  Correct, but we'll take a look and see what we can do to make it work.
                                  1 Reply Last reply πŸ‘
                                  • K
                                    Kondybas
                                    Thank you very much for all the efforts, SketchUp is the only CAD I really love since version 6.
                                    1 Reply Last reply πŸ‘
                                    Reply Quote 2
                                    • E
                                      ethansatsky Newcomers
                                      Im activating my Toposhaper liscense, but when I select the .scflience liscense, I get a message saying: error in liscense validation. repsonse from sketchucation liscense is not in the database
                                        Rich O Brien Moderator @ethansatsky
                                        @ethansatsky
                                        Yeah, I can confirm there is a hiccup. Give us a few mins to look into it.
                                          @ethansatsky
                                          Can you try again please?
                                            dmsone
                                            Hello, I purchased the "round corner" license, installed the latest Fredo6, and Sketchucation. When I press the round corner plugin button, nothing happens. Appreciate any help or advice.
                                            A 1 Reply Last reply
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 115
                                            • 116
                                            • 108 / 116
