    2.3k Posts 515 Posters 2.8m Views 520 Watching
    • P
      ppappa0099 Newcomers @Rich O Brien
      @Rich-O-Brien said in SCFLicense: Extension Licensing on Sketchucation:
      @ppappa0099
      Please follow the prompt and delete the signature file at C:\Users\SomeName\AppData\Local\SCF Licenses
      Restart SketchUp
      If your device name uses special characters please rename it to only use alphanumeric.
        mandraget
        hi fredo can you help me releasing my round corner license because there no option to release it from web, i need it asap, thank you
        • N
          nguyenhung269 Newcomers
          I can't log out of activation on other computers can you help me
            Rich O Brien Moderator @mandraget
            @mandraget said in SCFLicense: Extension Licensing on Sketchucation:
            Update extensions on all these devices to enable online releasing.
            Most important is to update Sketchucation Tools.
            M 1 Reply Last reply
              Rich O Brien Moderator @nguyenhung269
              @nguyenhung269
              Please update Sketchucation Tools on all these devices
              K 1 Reply Last reply
                mandraget @Rich O Brien
                but i cannot access there device right now, that my office device, and my office on day off till friday
                • P
                  @Rich-O-Brien
                  Plugin: JointPushPull (v7.1a - 74) on SketchUp 2023
                  Issue: Persistent License Validation Errors (A04 $\rightarrow$ B03) after correcting computer name.
                  Hello SCF Support Team,
                  I'm stuck in a license loop after changing my computer name, which triggered ERROR_A04.
                  I have tried the following steps multiple times:
                  1.Deleted Signature File: Erased SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt to force revalidation.
                  2.Activation Failed (B03): Upon trying to "Activate License", I immediately receive ERROR_B03 (connection failure to server).
                  3.Network Check: I confirmed I have a stable internet connection and temporarily disabled Windows Defender Firewall (Public/Private). The B03 error still persists.
                  Since the system cannot connect to complete the revalidation, I'm stuck "Not Licensed".
                  Could you please provide a manual method or an alternative solution to bypass the online connection for revalidation?
                  Thank you!
                    Rich O Brien Moderator @ppappa0099
                    @ppappa0099
                    Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                    P 1 Reply Last reply
                    • P
                      Fredo6 Plugins Information on 2025-11-19 01:27:43 +0800
                      • Platform: x64-mswin64_140 - Ruby: 2.7.2
                      • Sketchup: 23.0.397
                      • LibFredo6: v15.5a
                      • LibFredo6 Binary loaded
                      • Sketchucation ExtensionStore: 5.0.3
                      • SCFLicense: v7.1a - 74
                      • Fredo6 Plugins
                        Curviloft v2.0a
                        JointPushPull v4.8a
                        Signature File: 2025-11-19 01:01:49 +0800
                        @ppappa0099 Is your device named with non-alphanumeric characters?
                        Please don't delete posts that have info we need to help.
                        Error B03 is related the non-alphanumeric characters
                          As well as your computer-name, your windows-username shouldn't contain any non-ASCII characters.
                          Because these can trip up Ruby code processes...
                          Also you do need to restart your computer after the renaming...
                          • K
                            Kondybas @Rich O Brien
                            @nguyenhung269
                            I have the same problem.
                            Old notebook was formatted and donated to the ukrainian army. Sure licenses were not released before. Now I have licenses that cannot be revoked via the web page.
                              Rich O Brien Moderator @Kondybas
                              @Kondybas
                              Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp on your current device and copy/paste the output into your reply.
                              • K
                                Kondybas
                                Fredo6 Plugins Information on 2025-11-18 20:59:03 +0200
                                • Platform: x64-mingw32 - Ruby: 2.2.4
                                • Sketchup: 17.2.2555
                                • LibFredo6: v15.5a
                                • Sketchucation ExtensionStore: 4.3.1
                                • SCFLicense: v6.1a - 72
                                • Fredo6 Plugins
                                  Curviloft v2.0a
                                  Curvizard v2.5a
                                  FredoScale v3.6a
                                  JointPushPull v4.9a
                                  RoundCorner v3.4a
                                  ToolsOnSurface v2.6a
                                  Signature File: 2025-11-18 19:44:48 +0200
                                  @Kondybas Please update Sketchucation Tools to v 5.0.3
                                  Sketchucation Tools | SketchUcation
                                  (sketchucation.com)
                                  Restart SketchUp
                                  After restart run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and copy/paste output
                                  Latest Sketchucation Tools enables online releasing.
                                  • K
                                    Kondybas
                                    I have that pane not responding to clicks
                                      Ah....SketchUp 2017.
                                      Please Install this version
                                      SketchUcationTools_v4.4.1.rbz
                                      • K
                                        Kondybas
                                        Have installed 4.4.1 and still no checkboxes for license revokation
                                        Also there are no button images and bottom buttons in SUTools 4.4.1 (4.3.1 has the same issue for a while)
                                          Check https://sketchucation.com/webshop/my-licences.php now
                                          1 Reply Last reply 😳
                                          • K
                                            Kondybas
                                            WOW!
                                            I promise I'll be VERY careful with licenses now!
                                            Am I got it right that SUTools 5.0.3 is not compatible with SU2017?
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 115
                                            • 116
                                            • 108 / 116
