    Rayscaper New Releases
    rayscaperrender
    466 Posts 12 Posters 206.9k Views 13 Watching
    • KrassK Offline
      Krass
      I previously attached images of Rayscaper with a very satisfactory upscale and I am now adding a character: So, Rayscaper rendering, adding a character with Flux dev basic (via my ComfyUI installation for those who know), and upscale with Magnific via the Xfigura site which gives a few free credits per month.
      Krass
      P 1 Reply Last reply Reply Quote 2
        @Krass Very cool, I didn't know about ComfyUI; I'm going to try that out. Thanks for sharing the workflow!
        • KrassK Offline
          Krass
          Be careful, Comfy UI requires a large graphics card and lots of free disk space, and a lot of patience.
          Krass
            Hey, Rayscaper users!
            Another release!
            Rayscaper 0.9.64 Beta is available in the SketchUcation store. As
            always, I recommend upgrading to the latest version.
            What Changed?
            • Fix weird artifacts in the interactive render viewport.
            • Fix the upside-down images when saving.
            • Add transmission support for the PBR material. This makes it possible to create glass or liquid materials with the PBR material.
            • Fix a regression when renaming light components. Rayscaper lights should now correctly use the name of their SketchUp
              light component again.
            • Fix glass rendering, when multiple glass surfaces overlapped, Rayscaper would render them too dark.
            • Fix the render timer in the viewport. It will stop counting when the render is paused or finished.
            Help Me Build the Community 👍
            If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
            and helps me showcase its capabilities to new users.
            Follow me on Twitter.
            Happy Rendering!
            • KrassK Offline
              Krass
              thanks Pix, but no change for the lights component name with this version 9.64 If I rename the lights componant all lights go down
              Krass
                @Krass, just as a sanity check, you are not changing the name right, and not the component definition name?
                • KrassK Offline
                  Krass
                  ok, sorry, Indeed, I changed the component name and the instance name... thanks. Perfect, I'll test it.
                  However, I don't understand. I set the HDR definition to 8k, and it seems that it doesn't take this definition into account. I'll redo the rendering after downloading the map from the site.
                  Krass
                  P 1 Reply Last reply Reply Quote 1
                  • KrassK Offline
                    Krass
                    before/after: rayscaper project/Nano banana+Magnific upscale
                    Krass
                    P 1 Reply Last reply Reply Quote 3
                      You are THE man, Sir. I am in awe of your rendering talents. Unless they are photographs in which case. Pptttttttttttttttttht!
                      Change a thing and you get a call from sister carol. Not something for the faint hearted.....
                        @Krass
                        To clarify, updating the PolyHaven HDRI size will change the size of the textures after a restart:
                        I will not update the HDRI images/textures you are currently using in your scene. You can check the actual size here, but I should also display the HDRI size more prominently in the UI.
                        If you want to use the larger size, reapply the HDRI later.
                        I hope that clarifies things!
                        Regards,
                        Thomas
                          @Krass Wow, that's jaw-dropping. Congratulations. Great work!
                          KrassK 1 Reply Last reply Reply Quote 0
                          • KrassK Offline
                            Krass @pixelcruncher
                            Mike Amos Thanks,
                            I'll have a hard time understanding your joke "Change one thing and you get a call from Sister Carol. Not something for the faint-hearted..." because I'm French and my level of English is limited. But thank you for this feedback.
                            It's true that the result of "arranged" renderings ends up producing standardized photographic images (I'm thinking of this couple in this image; it looks like an advertising brochure for real estate development), but it's perfect for my clients.
                            I'm very happy, thanks to AI, to be able to use Rayscaper as a complete rendering engine (characters and vegetation). I find the quality of the rendering engine equal to Vray, but simpler.
                            Krass
                            • KrassK Offline
                              Krass @Krass
                              pixelcruncher
                              Thanks for the details
                              In truth, I think I'm on the wrong line for the choice of HDRI size definition. I'm confusing it with the size of the textures... sorry for the messages above
                              Krass
                              • KrassK Offline
                                Krass
                                Here's a version with an HDRI map background
                                But I'm trying to make a "studio" render for a friend, and Sketchup crashes when I change the image resolution during rendering. I set it to 300x400 and double-scaled it twice, and it crashed both times. Should I send a crash report?
                                https://jskup.fr/wp-content/uploads/2025/09/rocking-chair-3-Phil94.jpg
                                Krass
                                • KrassK Offline
                                  Krass
                                  I paused the rendering and changed the definition, and it didn't crash... "studio" version raw rayscaper
                                  alt text
                                  Krass
                                    @Krass said in Rayscaper New Releases:
                                    Making sure I understood you correctly. Just changing the resolution (of the rendered image) in Rayscaper made the software crash?
                                    alt text
                                    Nice render, it doesn't seem to have the correct tags in the forum post because the picture is not visible for me immediately.
                                    • KrassK Offline
                                      Krass
                                      hello, yes, as I can remember
                                      Krass
                                        I created a hotfix for a crash and updated to version 0.9.68 Beta - please ensure you get that one.
                                        A new release, with some cool stuff!
                                        Rayscaper 0.9.68 Beta is available in the SketchUcation store. As
                                        What Changed?
                                        • Support for SketchUp 2026.
                                        • Draw overlays for the lights in the viewport. This allows the user to select the lights in the viewport directly. You can enable
                                          or disable the overlay in the viewport toolbar.
                                        • Save the layout and position of the Rayscaper window between sessions. You can reset the layout via the menu "File >
                                          Reset Window Layout".
                                        • Fix a crash when minimizing the Rayscaper window.
                                        Here's the light overlay feature in action:
                                        Follow me on X.
                                        Happy Rendering!
                                        • KrassK Offline
                                          Krass
                                          Thanks, very usefull function
                                          Krass
                                            Mike Amos @pixelcruncher
                                            @pixelcruncher
                                            I am getting a crash when minimising or closing Rayscaper latest version.
                                            Also this. Setpoint error, graphic did not save. The crash of Sketchup is repeatable.
                                            P 2 Replies Last reply Reply Quote 0
                                            • 11
                                            • 23
                                            • 24
                                            • 9 / 24
