    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • fredo6F
      Not in the current version. However, I think VRay has this function by default
      • alexpacio2013A
        alexpacio2013
        I haven't found this function in the V-Ray batch command. Basically, the batch function follows the renders of all active scenes but not the transition between them.
        • fredo6F
          Did you look in the Animation settings?
          alexpacio2013A 2 Replies Last reply
          • alexpacio2013A
            alexpacio2013 @fredo6
            @fredo6 Yes, the option you're referring to is only for SketchUp exports of images, including the transitions between scenes, but not for V-Ray batch.
            • alexpacio2013A
              @fredo6 Looking more carefully in the manual, I found how to create scene animations from V-Ray, but it doesn't include object animation—only the transition between scenes. It would be nice to have the transitions in batch with Fredo Animator.
              link --->>
              fredo6F 1 Reply Last reply
              • fredo6F
                fredo6 @alexpacio2013
                @alexpacio2013 said in [Plugin Beta] Animator - v4.4a - 01 Jun 25:
                If you wish to have the objects animated, then it means you rely on Animator. Neither Sketchup nor VRay can move objects between scenes.
                With the latest version of Animator and VRay 6 or 7, you can use the VRay batch mode, or the VRay cloud for remote rendering.
                alexpacio2013A 1 Reply Last reply
                • alexpacio2013A
                  @fredo6 Yes, I've seen it, but the problem is that you can't do object animation and scene transitions with Animator simultaneously. In practice, you have to make two videos and then work with a video editor, which doesn't seem like a good solution to me. It would have been nice if Animator's batch mode also included transitions, with an option.
                  • fredo6F
                    New Release: Animator - v4.5a - 22 Jul 25
                    Requirement: LibFredo6 v15.4
                    Animator 4.5a is a maintenance release for:
                    • Fix for Thea Render (reverse Animation mode). You need also to upgrade Thea.
                    See plugin home page of Animator for Download of RBZ from the PluginStore.
                    See Main Post of the Animator thread for more information.
                      jamesmeng
                      Hi, I find one error in animator plugin, in fact I find it at the version v4.4.
                      the speed factor is not correct. previously I will set 0.75 factor for speed that mean if you create a 10seconds video and set factor as 0.75, normally the final video should be 13.3seconds. however for new version of animator if you set 0.75 it becomes 24.1 seconds.
                      if it does a bug, please correct it as before.
                      • fredo6F
                        With Animator v4.5a, I cannot reproduce the issue, whether in interactive mode or when generation the video.
                        Could you be more precise and tell me where you set the speed factor.
                        J 1 Reply Last reply
                          jamesmeng @fredo6
                          @fredo6
                          Please see above image. for previous verisons (before v4.4) for example if you choose 0.75 (frame tate I choose 45f/s I don't know if it affects the speed), and if your video last 100 seconds, then the video generated will be 133seconds, that mean 100/133=0.75 (this is exactly the factor you choose).
                          however after I install v4.4 version, and choose the 0.75 factor, the generated video will last 241seconds, and even I input 0.95 factor, the video last 170seconds around. I think maybe there is something you can adjust in your program. to make the speed factor back to normal.
                          • fredo6F
                            I released v4.5a. Did you try with this version?
                            J 2 Replies Last reply
                              jamesmeng @fredo6
                              @fredo6 Yes I tried v4.5a but same problem.
                                jamesmeng @fredo6
                                @fredo6
                                you can see my version now is v4.5a
                                I just created one 36 seconds video and choose 0.75 with 45p/s I finally get 1 minute and 26second video:
                                • fionmacoolF
                                  fionmacool
                                  I love this plugin, but I find the elements get moved due to some glitch- What often happens is that an element gets repositioned to the end of it's path. This means that it will travel the right direction and distance but start and end at incorrect positions. Is there a simple way to correct an element position? The plugin doesn't seem to like it if I manually move an element.
                                  My workaround is to copy all the elements in one sketchup file and paste them into another file so that I can start re-building the animation timeline again.
                                  Please excuse me if this has been answered elsewhere. Thanks.
                                  Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                                  • fredo6F
                                    It is better to use the Positioner to save position of objects.
                                    fionmacoolF 1 Reply Last reply
                                    • fionmacoolF
                                      fionmacool @fredo6
                                      @fredo6 Thanks Fredo. Much appreciated.
                                        jamesmeng
                                        hi Fredo, I want to buy the license but it say that I need to install sektchucation extensionstore v3.1.
                                        how to install it?
                                          jamesmeng
                                          I get it, the plugin name is "SketchUcationTools" not extensionstore. better change the name on the tip. because most people search for extensionstore and get nothing.
                                            jamesmeng
                                            hi Fredo,
                                            I find timer's possible reason. when I use the computer with old CPU (I7 4790), the video's time will be slow when you set 0.75 factor. however when I use the computer with relative new version CPU, the time will be normal.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 27 / 30
