    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    554 Posts 119 Posters 1.8m Views 119 Watching
      kws
      sorry fredo , i had appologised & thought replied to my post saying i had got it working it once period extended (it was down to having an earlier version of your reference tool )
      • N Offline
        Nilmadi Newcomers
        I'm using Fredo6 Animator in SketchUp Pro 2022 along with V-Ray 5 to render an animation of about 5000 frames.
        The problem is that with every rendered frame, the RAM usage increases slightly, and it never goes down. After around 500 frames, the memory usage gets so high that the process slows down significantly or crashes altogether.
        I have plenty of RAM, so the issue doesn't seem to be hardware-related. I suspect the memory is not being released properly after each frame is rendered.
        Is there any way to force Fredo6 or V-Ray to release memory after each frame? Or maybe a known workaround or setting that helps avoid this memory buildup during long renders?
        Any help or guidance would be really appreciated!
        • fredo6F Offline
          Animator has no control over VRay inner processing. Anyway, it's not surprising that the memory usage increases for a long job.
          I would suggest you render by piece, say 100 frames. This feature is available in the latest version of Animator, with VRay 6 or 7. You may also use the cloud rendering.
          alexpacio2013A 1 Reply Last reply Reply Quote 1
          • alexpacio2013A Offline
            alexpacio2013 @fredo6
            @fredo6 Is it possible with Animator to perform an automatic batch that automates the rendering with V-Ray 7 of all active scenes, including the transition between scenes?
            • fredo6F Offline
              Not in the current version. However, I think VRay has this function by default
                alexpacio2013
                I haven't found this function in the V-Ray batch command. Basically, the batch function follows the renders of all active scenes but not the transition between them.
                • fredo6F Offline
                  Did you look in the Animation settings?
                  alexpacio2013A 2 Replies Last reply Reply Quote 0
                    @fredo6 Yes, the option you're referring to is only for SketchUp exports of images, including the transitions between scenes, but not for V-Ray batch.
                      @fredo6 Looking more carefully in the manual, I found how to create scene animations from V-Ray, but it doesn't include object animation—only the transition between scenes. It would be nice to have the transitions in batch with Fredo Animator.
                      link --->>
                      fredo6F 1 Reply Last reply Reply Quote 0
                      • fredo6F Offline
                        fredo6 @alexpacio2013
                        @alexpacio2013 said in [Plugin Beta] Animator - v4.4a - 01 Jun 25:
                        If you wish to have the objects animated, then it means you rely on Animator. Neither Sketchup nor VRay can move objects between scenes.
                        With the latest version of Animator and VRay 6 or 7, you can use the VRay batch mode, or the VRay cloud for remote rendering.
                          @fredo6 Yes, I've seen it, but the problem is that you can't do object animation and scene transitions with Animator simultaneously. In practice, you have to make two videos and then work with a video editor, which doesn't seem like a good solution to me. It would have been nice if Animator's batch mode also included transitions, with an option.
                          • fredo6F Offline
                            New Release: Animator - v4.5a - 22 Jul 25
                            Requirement: LibFredo6 v15.4
                            Animator 4.5a is a maintenance release for:
                            • Fix for Thea Render (reverse Animation mode). You need also to upgrade Thea.
                            See plugin home page of Animator for Download of RBZ from the PluginStore.
                            See Main Post of the Animator thread for more information.
                              jamesmeng
                              Hi, I find one error in animator plugin, in fact I find it at the version v4.4.
                              the speed factor is not correct. previously I will set 0.75 factor for speed that mean if you create a 10seconds video and set factor as 0.75, normally the final video should be 13.3seconds. however for new version of animator if you set 0.75 it becomes 24.1 seconds.
                              if it does a bug, please correct it as before.
                              • fredo6F Offline
                                With Animator v4.5a, I cannot reproduce the issue, whether in interactive mode or when generation the video.
                                Could you be more precise and tell me where you set the speed factor.
                                J 1 Reply Last reply Reply Quote 0
                                  jamesmeng @fredo6
                                  @fredo6
                                  Please see above image. for previous verisons (before v4.4) for example if you choose 0.75 (frame tate I choose 45f/s I don't know if it affects the speed), and if your video last 100 seconds, then the video generated will be 133seconds, that mean 100/133=0.75 (this is exactly the factor you choose).
                                  however after I install v4.4 version, and choose the 0.75 factor, the generated video will last 241seconds, and even I input 0.95 factor, the video last 170seconds around. I think maybe there is something you can adjust in your program. to make the speed factor back to normal.
                                  • fredo6F Offline
                                    I released v4.5a. Did you try with this version?
                                    J 2 Replies Last reply Reply Quote 0
                                      jamesmeng @fredo6
                                      @fredo6 Yes I tried v4.5a but same problem.
                                        jamesmeng @fredo6
                                        @fredo6
                                        you can see my version now is v4.5a
                                        I just created one 36 seconds video and choose 0.75 with 45p/s I finally get 1 minute and 26second video:
                                        • fionmacoolF Offline
                                          fionmacool
                                          I love this plugin, but I find the elements get moved due to some glitch- What often happens is that an element gets repositioned to the end of it's path. This means that it will travel the right direction and distance but start and end at incorrect positions. Is there a simple way to correct an element position? The plugin doesn't seem to like it if I manually move an element.
                                          My workaround is to copy all the elements in one sketchup file and paste them into another file so that I can start re-building the animation timeline again.
                                          Please excuse me if this has been answered elsewhere. Thanks.
                                          Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                                          • fredo6F Offline
                                            It is better to use the Positioner to save position of objects.
                                            fionmacoolF 1 Reply Last reply Reply Quote 0
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 23 / 28
