    [Tutorial] Animator Quick Start
    renderpluginsextensions
    136 Posts 39 Posters 899.0k Views 40 Watching
    • C
      CHD123
      Is there an option for animation on a track?
      Does that mean that the camera travels on a certain line and passes between all the rooms?
      • fredo6F
        Camera Along Track is not implemented yet.
        • C
          CHD123
          Any idea when it's going to be?
            If you create a object to follow a path then use Camera Tracking Object and position your view you get that 'tour' effect
            Just hide the tracking object for the export.
            • C
              CHD123
              ?איך עושים עקוב אחר המצלמה
                https://i.imgur.com/WseM7iU.png
                I use the Temp exit feature in Animator to then use the native Position Camera tool.
                Then return to the Animator timeline add a New Camera and set it with this...
                https://i.imgur.com/SrVV0kD.png
                It's a bit funky to do but it does work
                  Migmat
                  PDF ANIMATOR TUTORIAL
                  . After discussing it with Fredo6, I'm now publishing it in this post, as it seems the most fitting choice.
                  Here's the link to the explanatory video and tutorial (in the video's description) in their Spanish version, published in my video youtube channel.
                  I'm currently working on the English version. This order is necessary due to layout considerations, as English tends to use fewer words. I hope it aids other designers in creating excellent animations with this superb plugin. I trust it will be helpful to you and that you'll share it with fellow users.
                  TUTORIAL de ANIMATOR EN PDF
                  ESPAÑOL:Finalmente he terminado el Tutorial de Animator y el video de explicacion y, tras consultarlo con Fredo6, procedo a publicarlo en este post, porque me parece el mas adecuado.
                  Este es el enlace al video explicativo y al tutorial (en la descripcion del video) en su version en Español publicado en mi canal de Youtube.
                  https://youtu.be/Ne5k4S_DZWw
                  Estoy preparando la version en ingles. Debe hacerse en este orden debido a temas de maquetación, puesto que en ingles se usan menos palabras. Espero que ayude a otros diseñadores a hacer buenas animaciones con este magnifico plugin. Espero que os sea util y que lo difundais a otros usuarios
                    Migmat
                    HERE THE ENGLISH VERSION OF THE PDF TUTORIAL OF ANIMATOR
                    I'm getting ready for the English version.
                    ENGLISH:At last, I'm pleased to introduce the tutorial and video for the ANIMATOR Plugin, designed for use with Sketchup, enabling the creation of impressive animations. It's taken quite a few hours of work, though the tutorial is intended as a basic introduction. The link to the tutorial can be found below, offering a 54-page PDF outlining the core features of ANIMATOR, alongside a few examples of more intricate animations. There's a chance it might contain a few oversights, for which I apologise. Despite being in beta for a while, the plugin remains a highly valuable tool for animating Sketchup projects. The animations boast impressive resolution, with nearly all film parameters under control. I hope this aids you in your animation pursuits and I encourage you to share the guide, assisting fellow users keen on animation. Thank you.
                    LINKS TO ENGLISH TUTORIAL ANIMATOR
                    https://drive.google.com/file/d/1s_fRc6RN8NbZNK9aJLdu2IbHNe_zq9Oc/view?usp=sharing
                    If you experiment problems with the link, let me know, please
                      Migmat
                      Here the NEW versión of the english tutorial because I miss the Last part of the tuto (Animation Technics) that was included in the Spanish version.
                      Here the new link:
                      NEW ENGLISH TUTORIAL VERSION LINK
                      https://drive.google.com/file/d/1ur6USmBRxGFV-X_5ByE6xRRPJHLJfD2r/view?usp=drive_link
                      Also I give you again the link of the explanatory videos of all the examples That are included in the tuto:
                      YOUTUBE VIDEO LINK
                      https://youtu.be/Ne5k4S_DZWw?si=lZ3bQdOZwKFtaYe6
                      ntxdaveN 1 Reply Last reply
                      • F
                        fredounou Newcomers
                        Bonjour Fredo,
                        Merci pour ce super plugin. J'ai un problème lorsque je veux faire un rendu Vray sur le cloud avec Animator. Animator crée un fichier d'export .vrscene que j'uploade sur Chaos Cloud. Mais à chaque fois l'export fait disparaitre le relief des textures (le bump).
                        Dans mon rendu il y a un plan d'eau avec un bump, et sur le rendu le relief de l'eau disparait, il n'y a plus qu'un miroir plat qui reflete le ciel.
                        Merci beaucoup
                        • ntxdaveN
                          ntxdave
                          Does anyone know of a way to modify/control the transition from one clip to another. I have several clips but you just get a quick change from a clip to the next one. I would like to see some capability like fade out the current/ending clip and then starting the next clip.
                          Press F1...thank me later
                          • ntxdaveN
                            ntxdave @Migmat
                            @Migmat said in [Tutorial] Animator Quick Start:
                            Here the new link:
                            I have not been able to download/read the pdf file.
                            • Rich O BrienR Rich O Brien pinned this topic on
                            • 7 / 7
