    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • panixiaP Offline
      panixia @Mike Amos
      @Mike-Amos well, in this case i started with a basic trace of photo references, I use components, so that I can use different photos for different pieces but then the components are nested in the main assembly so they end up in the right place..
      They also gave me a pretty bad photoscan, so I used that just to intersect it with a plane and extract the basic profile of the seating.
      I then smoothed the extracted curve with Curvizard and normalized it with Polyline Segmentor
      Then I created a base grid for the pattern with the proper real world measurements.
      I then created a repeated component with Curviloft Skin
      Same for the buttons
      And then create a different variation of that component for the sides
      And another variation for the corners
      then I joined all of them together.. please notice that In this stage I try to keep the quads as even as possible, because I'm gonna deform this stuff
      Then I extracted the diagonals for the sewing and used "Lines to Tubes" with quite low poly geometry.. and of course I did some cleanup with quadface tools for the overlapping geometry which will not be seen.
      I then created the base shape of the seating using Curviloft ad Quadface tools.. and extracted the grid were I need the upolstered thing..
      Then I use the QuadfaceTools "Unwrap Grid" feature to extract a flat grid from that.. which has the exact same lenght and topology of the seating that I'm going to replace.. and here is the flowify rig setup that I used to send the geometry to the curved surface.
      WARNING: you need to use "flowify without cuts" to avoid messy topolgy and keep quads.
      From this stage, it was just a matter of stitching and tweaking.. with the usual VertexTools, QFT, Artisan shenanigans
      Meanwhile I also added the studs.. I used profile builder assembly to place them and then manually repositioned some bits in the problematic areas
      And this is the updated version with the studs..
      I hope this was helpful to better understand the process..
      It's a bit different every time.. the shoe and the skatepark used a quite different process.. and the other sofas I posted before of that, is another different story.. 😬
      • HornOxxH Offline
        HornOxx
        A Great work! – & thanks for the many pictures of the doing process.
        never trust a skinny cook
          Agreed, a great resource. Thanks very much for that.
          • panixiaP Offline
            panixia
            I improved the upper stitching (which was too hard compared to the reference) with Vertex tools and the upper part of the tuft (which was too thin) using Artisan2 FFD (with a couple of tricks to make it work on multiple subgroups).
            I also increased the rounding of the frame profile using Artisan Move tool "normal" constraint.
            I think I'm done with this one.
            Time to unwrap it 😧
            • panixiaP Offline
              panixia
              "Work smarter not harder" 😁
              Another WIP from the same vintage furniture job, leveraging the power of components..
              Most of the armchair details are reusable for the sofa.
              • alvisA Offline
                alvis
                It's nice to see an orderly work process. And it seems like I'm already losing my position.
                panixiaP 1 Reply Last reply Reply Quote 1
                • panixiaP Offline
                  panixia @alvis
                  @alvis said in SubD examples and models:
                  Your work has always been a source of great inspiration and will always be.
                  • panixiaP Offline
                    panixia
                    I did some progress with this couple of models.. πŸ€—
                      Rich O Brien Moderator @panixia
                      @panixia said in SubD examples and models:
                      Time to unwrap it
                      I'll say a prayer πŸ™
                      • panixiaP Offline
                        panixia @Rich O Brien
                        @Rich-O-Brien LOL πŸ˜‚
                        I plan to unwrap separate meshes at mid poly stage and keep them consistent with the "tile trick"
                        then I'll do the final SubD
                        • panixiaP Offline
                          panixia
                          Trick or treat πŸŽƒ
                          HornOxxH 1 Reply Last reply πŸ‘» πŸ‘ Reply Quote 4
                          • HornOxxH Offline
                            HornOxx @panixia
                            @panixia Wunderbar! – such a beautiful model is a must-have at the moment ❀
                              ^ agreed, more to this method than meets the MK 1.
                              • BoxB Offline
                                People often think subd is purely for loose organic work and can't be used for specific sizes or accurate models
                                Here's an example of something that needed to have flat faces and an exact friction fit along with a smooth body to help with airflow.
                                The purpose.
                                I recently picked up a new sandblaster. This one is a pressure pot extractor system which basically means you put the air into a vacuum cleaner that has sand in it and it is a closed loop. This allow you to use it outside a booth, blasting cars, large panels etc
                                The downside of the system is it has a brush fitting around the head to contain the blasting media, which means you can’t see what is going on. When sandblasting glass you generally need to see what is going on because it’s a bit more like airbrushing than savage cleaning.
                                To that end I designed a new head for the thing that lets me look in while still capturing the media. A β€˜quick’ 3d print, and a bit of replaceable glass and tape and away we go.
                                The result.
                                1 Reply Last reply πŸ‘ πŸ‘ Reply Quote 3
                                  I agree, subdivision works for both organic forms and hard surface forms. You can be incredibly accurate in term of dimensions
                                  But at least tell the truth. This is for painting your toenails. πŸ’…
                                  1 Reply Last reply πŸ˜† Reply Quote 2
                                  • 82
                                  • 83
                                  • 2 / 83
