    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • HornOxxH
      HornOxx
      A Great work! โ€“ & thanks for the many pictures of the doing process.
      never trust a skinny cook
      Reply Quote 2
        Agreed, a great resource. Thanks very much for that.
        • panixiaP
          panixia
          I improved the upper stitching (which was too hard compared to the reference) with Vertex tools and the upper part of the tuft (which was too thin) using Artisan2 FFD (with a couple of tricks to make it work on multiple subgroups).
          I also increased the rounding of the frame profile using Artisan Move tool "normal" constraint.
          I think I'm done with this one.
          Time to unwrap it ๐Ÿ˜ง
          • panixiaP
            panixia
            "Work smarter not harder" ๐Ÿ˜
            Another WIP from the same vintage furniture job, leveraging the power of components..
            Most of the armchair details are reusable for the sofa.
            Reply Quote 2
            • alvisA
              alvis
              It's nice to see an orderly work process. And it seems like I'm already losing my position.
              panixiaP 1 Reply Last reply
              • panixiaP
                panixia @alvis
                @alvis said in SubD examples and models:
                Your work has always been a source of great inspiration and will always be.
                • panixiaP
                  panixia
                  I did some progress with this couple of models.. ๐Ÿค—
                    Rich O Brien Moderator @panixia
                    @panixia said in SubD examples and models:
                    Time to unwrap it
                    I'll say a prayer ๐Ÿ™
                    • panixiaP
                      panixia @Rich O Brien
                      @Rich-O-Brien LOL ๐Ÿ˜‚
                      I plan to unwrap separate meshes at mid poly stage and keep them consistent with the "tile trick"
                      then I'll do the final SubD
                      • panixiaP
                        panixia
                        Trick or treat ๐ŸŽƒ
                        HornOxxH 1 Reply Last reply ๐Ÿ‘ป ๐Ÿ‘
                        Reply Quote 4
                        • HornOxxH
                          HornOxx @panixia
                          @panixia Wunderbar! โ€“ such a beautiful model is a must-have at the moment โค
                            ^ agreed, more to this method than meets the MK 1.
                            • BoxB
                              People often think subd is purely for loose organic work and can't be used for specific sizes or accurate models
                              Here's an example of something that needed to have flat faces and an exact friction fit along with a smooth body to help with airflow.
                              The purpose.
                              I recently picked up a new sandblaster. This one is a pressure pot extractor system which basically means you put the air into a vacuum cleaner that has sand in it and it is a closed loop. This allow you to use it outside a booth, blasting cars, large panels etc
                              The downside of the system is it has a brush fitting around the head to contain the blasting media, which means you canโ€™t see what is going on. When sandblasting glass you generally need to see what is going on because itโ€™s a bit more like airbrushing than savage cleaning.
                              To that end I designed a new head for the thing that lets me look in while still capturing the media. A โ€˜quickโ€™ 3d print, and a bit of replaceable glass and tape and away we go.
                              The result.
                              1 Reply Last reply ๐Ÿ‘ ๐Ÿ‘
                              Reply Quote 3
                                I agree, subdivision works for both organic forms and hard surface forms. You can be incredibly accurate in term of dimensions
                                But at least tell the truth. This is for painting your toenails. ๐Ÿ’…
                                1 Reply Last reply ๐Ÿ˜†
                                Reply Quote 2
                                • panixiaP
                                  panixia
                                  A couple of spherical topology experiments
                                  Full-Quad-Full-Triangle-Full-Sphere.skp
                                  Corrugated_Sphere.skp
                                  Reply Quote 3
                                  • HornOxxH
                                    HornOxx @panixia
                                    A couple of spherical topology experiments)
                                    ...all of which are great!!! (I wonder how you made that second, very tricky ball)
                                    panixiaP HornOxxH 2 Replies Last reply
                                    • panixiaP
                                      panixia @HornOxx
                                      @HornOxx said in SubD examples and models:
                                      The attached model includes the main stages.
                                      • HornOxxH
                                        HornOxx @HornOxx
                                        Thanks, Panixia for adding your models above! (I had overlooked them and am very happy that you are giving us the opportunity to see them)
                                        โ€œTricky Ballโ€ was a significant understatementโ€”you first have to come up with the idea of editing a sphere in such a way that it looks like two interlocking hands rotated 90ยฐ! And then in such an accurate form. And I'm not even talking about your following amazing skills required to create those โ€œridgesโ€ around the sphere-shape! ๐Ÿ˜‰
                                        Respect! What a beautiful work.
                                        • panixiaP
                                          panixia @HornOxx
                                          That's exactly where the plugin I'm developing in my spare time comes into play ๐Ÿ˜ฌ
                                          HornOxxH 1 Reply Last reply ๐Ÿ˜ฒ ๐Ÿ‘
                                          • HornOxxH
                                            HornOxx @panixia
                                            Hey, I'm excited! ๐Ÿ˜‰ If you need a beta tester, let me know ๐Ÿ˜‰
                                            • 80
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 83 / 84
