    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • panixiaP Offline
      panixia
      Addictive.. πŸ˜…
        Brilliant and inspiring. Thanks for posting this.
        panixiaP 1 Reply Last reply Reply Quote 2
        • panixiaP Offline
          panixia @Mike Amos
          @Mike-Amos thank you.. I'll share the last couple of models when I'm done πŸ‘
          • panixiaP Offline
            panixia
            I had to put the shoe modeling on hold because I had to do this for work today 😰
              🀀 flawless
              • panixiaP Offline
                panixia @Rich O Brien
                @Rich-O-Brien flowify is the key for this sort of stuff..
                  It would help to see the workflow for that last especially, if/when you have time.
                  panixiaP 1 Reply Last reply Reply Quote 0
                  • panixiaP Offline
                    panixia @Mike Amos
                    @Mike-Amos well, in this case i started with a basic trace of photo references, I use components, so that I can use different photos for different pieces but then the components are nested in the main assembly so they end up in the right place..
                    They also gave me a pretty bad photoscan, so I used that just to intersect it with a plane and extract the basic profile of the seating.
                    I then smoothed the extracted curve with Curvizard and normalized it with Polyline Segmentor
                    Then I created a base grid for the pattern with the proper real world measurements.
                    I then created a repeated component with Curviloft Skin
                    Same for the buttons
                    And then create a different variation of that component for the sides
                    And another variation for the corners
                    then I joined all of them together.. please notice that In this stage I try to keep the quads as even as possible, because I'm gonna deform this stuff
                    Then I extracted the diagonals for the sewing and used "Lines to Tubes" with quite low poly geometry.. and of course I did some cleanup with quadface tools for the overlapping geometry which will not be seen.
                    I then created the base shape of the seating using Curviloft ad Quadface tools.. and extracted the grid were I need the upolstered thing..
                    Then I use the QuadfaceTools "Unwrap Grid" feature to extract a flat grid from that.. which has the exact same lenght and topology of the seating that I'm going to replace.. and here is the flowify rig setup that I used to send the geometry to the curved surface.
                    WARNING: you need to use "flowify without cuts" to avoid messy topolgy and keep quads.
                    From this stage, it was just a matter of stitching and tweaking.. with the usual VertexTools, QFT, Artisan shenanigans
                    Meanwhile I also added the studs.. I used profile builder assembly to place them and then manually repositioned some bits in the problematic areas
                    And this is the updated version with the studs..
                    I hope this was helpful to better understand the process..
                    It's a bit different every time.. the shoe and the skatepark used a quite different process.. and the other sofas I posted before of that, is another different story.. 😬
                    • HornOxxH Offline
                      HornOxx
                      A Great work! – & thanks for the many pictures of the doing process.
                      never trust a skinny cook
                        Agreed, a great resource. Thanks very much for that.
                        • panixiaP Offline
                          panixia
                          I improved the upper stitching (which was too hard compared to the reference) with Vertex tools and the upper part of the tuft (which was too thin) using Artisan2 FFD (with a couple of tricks to make it work on multiple subgroups).
                          I also increased the rounding of the frame profile using Artisan Move tool "normal" constraint.
                          I think I'm done with this one.
                          Time to unwrap it 😧
                          • panixiaP Offline
                            panixia
                            "Work smarter not harder" 😁
                            Another WIP from the same vintage furniture job, leveraging the power of components..
                            Most of the armchair details are reusable for the sofa.
                            • alvisA Offline
                              alvis
                              It's nice to see an orderly work process. And it seems like I'm already losing my position.
                              panixiaP 1 Reply Last reply Reply Quote 1
                              • panixiaP Offline
                                panixia @alvis
                                @alvis said in SubD examples and models:
                                Your work has always been a source of great inspiration and will always be.
                                • panixiaP Offline
                                  panixia
                                  I did some progress with this couple of models.. πŸ€—
                                    Rich O Brien Moderator @panixia
                                    @panixia said in SubD examples and models:
                                    Time to unwrap it
                                    I'll say a prayer πŸ™
                                    • panixiaP Offline
                                      @Rich-O-Brien LOL πŸ˜‚
                                      I plan to unwrap separate meshes at mid poly stage and keep them consistent with the "tile trick"
                                      then I'll do the final SubD
                                      • panixiaP Offline
                                        panixia
                                        Trick or treat πŸŽƒ
                                        HornOxxH 1 Reply Last reply πŸ‘» πŸ‘ Reply Quote 4
                                        • HornOxxH Offline
                                          HornOxx @panixia
                                          @panixia Wunderbar! – such a beautiful model is a must-have at the moment ❀
                                            ^ agreed, more to this method than meets the MK 1.
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 82
                                            • 83
                                            • 60 / 83
