    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 52.0k Views 32 Watching
    • Didier BurD Offline
      Didier Bur @aricfish
      @ SU2024 and Door-Lintel users:
      I don't have SU2024 installed on my PC.
      Maybe some developer (TIG ?) will update the plugin ?
      So here it is.
      Regards,
      # Name :          door_lintel
      # Description :   Draws a lintel above door between wall sides, and window as well
      # Author :        D. Bur
      # Usage :         select face and "Door by reveal" in context menu
      # Date :          May 2008
      # Type :          Tool
      # History:        1.0 (May 2008) - first version
      #                 1.1 (May 2008) - window added
      require 'sketchup.rb'
      # f=Sketchup.active_model.selection[0]
      def trad(word)
      	# tStrings = [["Door" "Porte"],["Window" "Fenetre"]]
      	tStrings={ "Door" => "Porte", "Window" => "Fenêtre"}
      	return word if Sketchup.get_locale != "fr"
      	return tStrings[word]
      def dbe_by_embrasure(type)
      	model=Sketchup.active_model
      	entities=Sketchup.active_model.active_entities
      	@dbe_door_height=2.m if not @dbe_door_height
      	@dbe_window_height=135.cm if not @dbe_window_height
      	@dbe_sill_height=1.m if not @dbe_sill_height
      	org_face=model.selection[0]
      	model.start_operation "Door-window by reveal"
      	  if model.selection.empty?
      		UI.messagebox("Empty selection: please select a vertical face.")
      		return
      	if (model.selection.length !=1)
      		UI.messagebox("Please select only ONE vertical face.")
      		return
      	if  (model.selection[0].class != Sketchup::Face)
      		UI.messagebox("Please select a vertical face.")
      		return
      	if org_face.normal.z>1e-012 or org_face.normal.z<-1e-012
      		UI.messagebox("Please select a VERTICAL face.")
      		return
      	if org_face.outer_loop.edges.length != 4
      		UI.messagebox("Please select a RECTANGULAR vertical face.")
      		return
      	 # Parse edges
      	edges=org_face.edges
      	@verticals={}
      	@horizontals={}
      	edges.each do |e|
      		if e.start.position.z==e.end.position.z
      			@horizontals[e]=e.start.position.z
      		else
      			@verticals[e]=e.start.position.distance e.end.position
      	# Dialog
      	#puts "type " + type.inspect
      	if type=="door"
      		return if !dbe_door_height()
      	else
      		return if !dbe_window_height()
      	# heights control
      	if type=="door"
      		height_ok=false
      		until height_ok
      			if @dbe_door_height<@verticals.values.max #or (@dbe_sill_height+@dbe_window_height)<@verticals.values.max
      				height_ok =true
      			else
      				UI.messagebox("Incorrect height for this door.\nPlease set it to a lower value than " +@verticals.values.max.to_s)
      	if type=="window"
      		heights_ok=false
      		until heights_ok
      			if (@dbe_sill_height+@dbe_window_height)<@verticals.values.max
      				heights_ok =true
      			else
      				UI.messagebox("Incorrect heights for this windows.\nSum of sill and window heights should'nt exceed "  + @verticals.values.max.to_s)
        # Highest edge & lintel height
        high_edge=@horizontals.index(@horizontals.values.max)
        bottom_edge=@horizontals.index(@horizontals.values.min)
        lintel_height=@verticals.values.max-@dbe_door_height if type=="door"
        lintel_height=@verticals.values.max-(@dbe_window_height+@dbe_sill_height) if type=="window"
        # New face of lintel
        p1=high_edge.start.position
        p2=high_edge.end.position
        p3=Geom::Point3d.new(p1.x,p1.y,(p1.z-lintel_height))
        p4=Geom::Point3d.new(p2.x,p2.y,(p2.z-lintel_height))
        # Mid point of lintel
        v=p2.vector_to p3
        v.length=v.length/2.0
        mid=p2.offset(v)
        # Opening width
        v_norm=org_face.normal
        touch=model.raytest([mid,v_norm])
        if touch
          same_object=true
          hitpoint=touch[0]
          hit_obj=touch[1]
          if hit_obj.length>1
            hit_face=hit_obj.last
            hit_parent=hit_obj[0]
            if not hit_parent.entities.include? org_face
              same_object=false
            else
            hit_parent=hit_obj.last
          width=mid.distance hitpoint
          if width > 200
            go=UI.messagebox("Suspicious door width found: " + width.to_s + "\nProceed ?",MB_OKCANCEL)
            return nil if go==2
          case hit_parent.typename
            when "Face"
              if org_face.normal!=hit_face.normal.reverse
                UI.messagebox("Opposite reveal not parallel to selected face. Aborting...")
                return nil
            else
              if same_object==false
                UI.messagebox("Cannot find opposite wall,\nobstructive "+hit_parent.typename+" found on layer "+hit_parent.layer.name+ ".\nPlease hide it and retry.")
                return
        else
          UI.messagebox("No opposite wall to connect lintel.")
          return nil
        new_face=entities.add_face p1,p2,p4,p3
        if touch and same_object==true
          v2=new_face.normal
          v2.length=width
          new_face.pushpull width
          else
          UI.messagebox("Cannot pushpull lintel.")
        #Redraw these fucking remaining edges to better kill them
        e1=entities.add_line(p1.offset(v2),p2.offset(v2))
        e2=entities.add_line(p1.offset(v2),p3.offset(v2))
        e3=entities.add_line(p2.offset(v2),p4.offset(v2))
        e1.erase!
        e2.erase!
        e3.erase!
        if type=="window"
          # New face of sill
          p1=bottom_edge.start.position
          p2=bottom_edge.end.position
          p3=Geom::Point3d.new(p1.x,p1.y,(p1.z+@dbe_sill_height))
          p4=Geom::Point3d.new(p2.x,p2.y,(p2.z+@dbe_sill_height))
          # Mid point of sill
          v=p2.vector_to p3
          mid=p2.offset(v)
          # Opening width
          if touch
            same_object=true
            hitpoint=touch[0]
            hit_obj=touch[1]
            if hit_obj.length>1
              #if not hit_parent.entities.include? org_face
                #same_object=false
              #end
            else
          if width > 200
            go=UI.messagebox("Suspicious window width found: " + width.to_s + "\nProceed ?",MB_OKCANCEL)
            return nil if go==2
            when "Face"
              if v_norm!=hit_face.normal.reverse
                return nil
            else
                return
        else
          UI.messagebox("No opposite wall to connect linter.")
          return nil
          v2=new_face.normal
          v2.length=width
          else
          UI.messagebox("Cannot pushpull sill.")
        e1.erase!
        e2.erase!
        e3.erase!
        end # if window
        model.commit_operation
      def dbe_door_height
      	prompt=["Door height: "]
      	value=[@dbe_door_height]
      	results=inputbox prompt,value,"Door height"
      	puts results.inspect
      	return false if !results
      	@dbe_door_height=results[0]
      def dbe_window_height
      	prompts=["Sill height:  ","Window height:  "]
      	values=[@dbe_sill_height,@dbe_window_height]
      	results=inputbox prompts,values,"Window heights"
      	@dbe_sill_height=results[0]
      	@dbe_window_height=results[1]
      def valid_door_selection
        s=Sketchup.active_model.selection
        return false if s.length!=1
        return false if s[0].typename!="Face"
        return false if s[0].normal.z>1e-012 or s[0].normal.z<-1e-012
        return false  if s[0].outer_loop.edges.length != 4
        return true
      # add menu items
      if !file_loaded?(__FILE__ )
        dbe_menu=UI.menu("Tools").add_submenu("Door/Window by reveal")
        dbe_menu.add_item("Door") { dbe_by_embrasure "door"}
        dbe_menu.add_item("Window") { dbe_by_embrasure "window" }
        dbe_menu.add_separator
         # Context menu
          UI.add_context_menu_handler do |menu|
              if( valid_door_selection )
              		menu.add_separator
                  menu.add_item("Door by reveal") { dbe_by_embrasure "door" }
                  menu.add_item("Window by reveal") { dbe_by_embrasure "window" }
                  menu.add_separator
      file_loaded(__FILE__ )
      DB
      guanjinG 1 Reply Last reply Reply Quote 0
      • guanjinG Offline
        guanjin @Didier Bur
        @Didier-Bur
        It seems that no one has fixed this plugin😞
        TIGT 1 Reply Last reply Reply Quote 0
          TIG Moderator @guanjin
          @guanjin
          It doesn't work in v2024 [various errors], e.g.
          Error: #<NoMethodError: undefined method 'index' for {#Sketchup::Edge:0x0000019daaeab1b0=>0.0, #Sketchup::Edge:0x0000019daaeab160=>39.37007874015748}:Hash>
          C:/Users/TIG/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/GEIS_door_lintel2.rb: 100:in 'dbe_by_embrasure'
          C:/Users/TIG/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/GEIS_door_lintel2.rb: 274:in `block in <top (required)>'
          @Didier-Bur also obfuscates his code, so without arduously repacking it back into RB code it'd be difficult to say what the issues are...
          • guanjinG Offline
            guanjin
            So many experts, no one can fix this plugin
            The forum is no longer the same as before
            1 Reply Last reply Reply Quote -2
              @Didier-Bur needs to fix this - it's his baby...
              Didier BurD 1 Reply Last reply Reply Quote 0
                Didier Bur @TIG
                Hi all,
                My baby is quite old now 😉
                Here is the non-encrypted version. Please unpack in your Plugins dir.
                No update because I haven't SU2024.
                Regards,DBUR_Lines2Tubes.zip
                DB
                  Didier Bur @Didier Bur
                  Me again,
                  Same goes for door_lintel.rb
                  door_lintel_uncrypted.zip
                  DB
                    JGA
                    Didier, thanks for sharing.
                    Regards,
                    JGA
                    1 Reply Last reply Reply Quote -1
                    • guanjinG Offline
                      guanjin
                      Thank you to Didier Bur for the source code, which successfully fixed the work in 2024 and modified the multi-faceted selection stretching.
                      guanjinG L sumasterS 4 Replies Last reply Reply Quote 0
                      • guanjinG Offline
                        guanjin @guanjin
                        This post is deleted!
                        • guanjinG Offline
                          guanjin @guanjin
                          @guanjin said in [Plugin] Door-Lintel Update + Window-Sill:
                          Thank you again, Didier Bur
                          A 1 Reply Last reply Reply Quote 0
                            lamngoaison
                            i got a new problem. SU2025. any one fix it for SU2025 yet? please!!
                              TIG Moderator @lamngoaison
                              @lamngoaison
                              The linked post contains a ZIP file posted a few days ago
                              link
                              Which can be converted to an RBZ by changing its filetype suffix.
                              It worked in v2024, so should also work in v2025 ?
                                lamngoaison @TIG
                                @TIG thanks alot 😁
                                  memaridrue81
                                  hi Didier Bur,
                                  May I request an update for this extension for SketchUp 2023 and higher? it work well with my SKP 2022 but file crashes when I use it in skp 2023 😊
                                  Many thanks!
                                    lamngoaison @guanjin
                                    by unknown problem. it not work anymore in my SU2025. so bro, can you share this version of your with other. thanks alot!!!
                                    • sumasterS Offline
                                      sumaster @guanjin
                                      @guanjin
                                      can you post a new updated script
                                      thanks
                                      Thank you,
                                      SUmaster
                                        The linked .ZIP file is still available in the earlier post.
                                        Download it, then just change its filetype to .RBZ as previously explained.
                                        Then install it...
                                        sumasterS 1 Reply Last reply 👍 Reply Quote 0
                                        • sumasterS Offline
                                          sumaster @TIG
                                          @TIG
                                          yes thanks 👍
                                          Thank you,
                                          SUmaster
                                            Anentt1 @guanjin
                                            @guanjin how to use this code for fix the issue
                                            • 4 / 4
