    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 55.7k Views 32 Watching
    • guanjinG
      guanjin
      Thank you to Didier Bur for the source code, which successfully fixed the work in 2024 and modified the multi-faceted selection stretching.
      guanjinG L sumasterS 4 Replies Last reply
      • guanjinG
        guanjin @guanjin
        This post is deleted!
        • guanjinG
          guanjin @guanjin
          @guanjin said in [Plugin] Door-Lintel Update + Window-Sill:
          Thank you again, Didier Bur
          A 1 Reply Last reply
          • L
            lamngoaison
            i got a new problem. SU2025. any one fix it for SU2025 yet? please!!
            TIGT 1 Reply Last reply
              TIG Moderator @lamngoaison
              @lamngoaison
              The linked post contains a ZIP file posted a few days ago
              link
              Which can be converted to an RBZ by changing its filetype suffix.
              It worked in v2024, so should also work in v2025 ?
              L 1 Reply Last reply
              • L
                lamngoaison @TIG
                @TIG thanks alot 😁
                  memaridrue81
                  hi Didier Bur,
                  May I request an update for this extension for SketchUp 2023 and higher? it work well with my SKP 2022 but file crashes when I use it in skp 2023 😊
                  Many thanks!
                  • L
                    lamngoaison @guanjin
                    by unknown problem. it not work anymore in my SU2025. so bro, can you share this version of your with other. thanks alot!!!
                    • sumasterS
                      sumaster @guanjin
                      @guanjin
                      can you post a new updated script
                      thanks
                      Thank you,
                      SUmaster
                        The linked .ZIP file is still available in the earlier post.
                        Download it, then just change its filetype to .RBZ as previously explained.
                        Then install it...
                        sumasterS 1 Reply Last reply 👍
                        • sumasterS
                          sumaster @TIG
                          @TIG
                          yes thanks 👍
                          Thank you,
                          SUmaster
                            Anentt1 @guanjin
                            @guanjin how to use this code for fix the issue
                            • L
                              luongtuan @Didier Bur
                              @Didier-Bur
                              Hello. Can you update SketchUp to 2026?
                                If it works in v2024 [see earlier posts] it'll probably work in v2026.
                                Try it.
                                To install an extension from a ZIP archive file rather than from an RBZ you will need either to change the file-type suffix, or even easier use the SketchUcation submenu item to install it from Archive, which works for both RBZ and ZIP archives...
                                • 4 / 4
