    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 47.7k Views 32 Watching
    • guanjinG Offline
      guanjin @guanjin
      @guanjin said in [Plugin] Door-Lintel Update + Window-Sill:
      Thank you to Didier Bur for the source code, which successfully fixed the work in 2024 and modified the multi-faceted selection stretching.
      Thank you again, Didier Bur
      A 1 Reply Last reply Reply Quote 0
        lamngoaison
        i got a new problem. SU2025. any one fix it for SU2025 yet? please!!
        TIGT 1 Reply Last reply Reply Quote 0
          TIG Moderator @lamngoaison
          @lamngoaison
          The linked post contains a ZIP file posted a few days ago
          link
          Which can be converted to an RBZ by changing its filetype suffix.
          It worked in v2024, so should also work in v2025 ?
            lamngoaison @TIG
            @TIG thanks alot 😁
              memaridrue81
              hi Didier Bur,
              May I request an update for this extension for SketchUp 2023 and higher? it work well with my SKP 2022 but file crashes when I use it in skp 2023 😊
              Many thanks!
                lamngoaison @guanjin
                by unknown problem. it not work anymore in my SU2025. so bro, can you share this version of your with other. thanks alot!!!
                • sumasterS Offline
                  sumaster @guanjin
                  @guanjin
                  can you post a new updated script
                  thanks
                  Thank you,
                  SUmaster
                    The linked .ZIP file is still available in the earlier post.
                    Download it, then just change its filetype to .RBZ as previously explained.
                    Then install it...
                    sumasterS 1 Reply Last reply 👍 Reply Quote 0
                    • sumasterS Offline
                      sumaster @TIG
                      @TIG
                      yes thanks 👍
                      Thank you,
                      SUmaster
                        Anentt1 @guanjin
                        @guanjin how to use this code for fix the issue
                          luongtuan @Didier Bur
                          @Didier-Bur
                          Hello. Can you update SketchUp to 2026?
                            If it works in v2024 [see earlier posts] it'll probably work in v2026.
                            Try it.
                            To install an extension from a ZIP archive file rather than from an RBZ you will need either to change the file-type suffix, or even easier use the SketchUcation submenu item to install it from Archive, which works for both RBZ and ZIP archives...
                            • 4 / 4
