    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • N Offline
      natas_ha
      I bought the licence and installed the rbz file but nothing is happening. When I open Sketchup it constantly telling me that I need to install the LibFredo plug in but I already did it. How to continue with this?
      Rich O BrienR TIGT 2 Replies Last reply Reply Quote 0
      • Rich O BrienR Online
        Rich O Brien Moderator @natas_ha
        @natas_ha
        Libfredo is a helper library for many of Fredo's other extensions. On its own it serves no real purpose
          TIG Moderator @natas_ha
          @natas_ha
          Which of Fredo's extensions did you license ?
          Do you have the latest version of his helper extension LibFredo6 installed ?
          Did you restart to sync everything ?
          Also do you also have the latest version of the SketchUcation tools installed - for the licensing...
          If none of this helps repost and someone will ask you for more details...
          N 1 Reply Last reply Reply Quote 0
          • N Offline
            natas_ha @TIG
            @TIG FredoCorner_v2.7a this extension and I bought the Perpetual licence. I installed the rbz file and nothing is happening. It gives me constantly this:Screenshot 2024-11-08 150415.jpg
              Dave R @natas_ha
              @natas_ha are you sure you bought the license for FredoCorner and not RoundCorner? Many people have gotten confused and tried to use the license for one on the other. They are different extensions and require different licenses.
              Did you install LibFredo6 using the Sketchucation ExtensionStore and then restart SketchUp?
              • fredo6F Offline
                NEW RELEASE: LibFredo6 v14.7a - 09 Nov 24
                LibFredo6 14.7a is a major release. It includes changes related to:
                • ThruPaint v2.8a
                • New plugins
                • Future compatibility
                • Bug Fixing
                F 1 Reply Last reply Reply Quote 0
                • F Offline
                  FlorinAp @fredo6
                  @fredo6 This one has at least one bug - doesn't allow Lord of the Toolbars to add/remove icons, neither in the toolbars and neither in palettes.!
                  Edit: For SU 2023.!
                  fredo6F 1 Reply Last reply Reply Quote 0
                  • fredo6F Offline
                    fredo6 @FlorinAp
                    @FlorinAp
                    You are correct. I simply forgot to publish LOTT to adjust with necessary changes in LibFredo6.
                    LOTT is now published as v2.8a.
                      a4jp.com
                      Can you make it so we can add time to the clock? I opened the clock on old projects but I want to add the time I have worked on those files before.
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v14.8a - 26 Nov 24
                        LibFredo6 14.8a is a major release. It includes changes related to:
                        • FredoBatch v1.1a
                        • Bug Fixing
                        I 1 Reply Last reply Reply Quote 0
                          Rachel23
                          I'm disappointed. I downloaded it and it said its expired. So i bought your extension for 15 dollars and then redownloaded it and it still says expired and I've relogged in many times.
                            Rich O Brien Moderator @Rachel23
                            @Rachel23 Licenses need to be activated per https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                            • N Offline
                              Nicolla
                              Hi guys.
                              I downloaded recent update but it messed something up with Joint Push Pull
                              I can't make shell and thicken the most simplest shapes, like the cube with 3 faces removed
                              Have you noticed this too and how can I solve it? Thanks πŸ™‚
                              TIGT 1 Reply Last reply Reply Quote 0
                                TIG Moderator @Nicolla
                                @Nicolla
                                If you try it with the Ruby Console [Extensions > Developer submenu] open do you see any error messages, or do you get any other error message dialogs when trying it ?
                                If you attach a simple SKP, with the problems you are experiencing, and a step by step of instructions, it would help us understand your problems...
                                • I Offline
                                  ideas_arte @fredo6
                                  @fredo6
                                  Extension Errors Report
                                  SketchUp: 24.0.484
                                  OS: Windows 10
                                  Ruby: 3.2.2
                                  Extension: Fredo6 LibFredo6 (14.8a - 26 Nov 24)
                                  Error: NoMethodError (undefined method split' for ["Animator"]:Array) c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in block in super_flatten'
                                  c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in super_flatten'
                                  c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:860:in load_from_config' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins'
                                  c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins'
                                  c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process'
                                  C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in <module:LibFredo6_Loader>' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                                  • fredo6F Offline
                                    fredo6 @ideas_arte
                                    @ideas_arte
                                    Can you check the version of Animator you have in your enviroment.
                                    The best is to invoke the menu Window > LibFredo6 Settngs > Fredo6 Plugin information for Sketchucation Support.
                                    • I Offline
                                      ideas_arte @fredo6
                                      @fredo6
                                      Fredo6 Plugins Information on 2024-12-05 14:25:10 -0600
                                      • Sketchup: 24.0.484
                                      • LibFredo6: v14.8a
                                      • LibFredo6 Binary loaded
                                      • Sketchucation ExtensionStore: 4.4.1
                                      • SCFLicense: v6.4a - 74
                                      • Fredo6 Plugins
                                        FredoTools v4.5c
                                        ThruPaint v2.8a
                                        TopoShaper v2.7a
                                        Signature File: absent
                                      • I Offline
                                        ideas_arte @ideas_arte
                                        @ideas_arte
                                        I had to desable the Animator:
                                        • fredo6F Offline
                                          fredo6 @ideas_arte
                                          @ideas_arte
                                          Do you know what version of Animator you had. You may try with installing its latest version.
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v14.9a - 06 Dec 24
                                            LibFredo6 14.9a is a major release. It includes changes related to:
                                            • FredoBatch v1.2a
                                            • Bug Fixing
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 109
                                            • 110
                                            • 53 / 110
