    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    481 Posts 92 Posters 355.9k Views 91 Watching
      laurent002
      Hello Fredo, I'm missing greatly in the dialogue box Master Toolbar Manager, in personnal commands and in Menu the accès to all sketchup tools to ad icons. When I open New personal Command (menu) the list is empty. I would realy need it.
      Why was it working in the olds version and know it doesn't ?
      If you could fix that it would be a great tool.
      fredo6F 1 Reply Last reply Reply Quote 0
      • fredo6F Offline
        fredo6 @laurent002
        @laurent002
        The limitation of functionality as of SU 2023 is due to a change of UI framework in Sketchup (called Qt), which does not allow any longer to access menus.
        It still work in older SU version and on Mac, all versions.
        N H 2 Replies Last reply Reply Quote 0
          laurent002
          @laurent002 said in [Plugin] LordOfTheToolbars - v2.8a - 10 Nov 24:
          It's very sad, it is realy missing in sketchup to ne able to organise and use any tools as we wish, any tools or fonction. And the question of having so many plugin creators, sometine with no icons, or not all tools, is a great limitation. You can't créât to many short cuts, to make your flow more cohérent. Going to the menu, then using icon, and adding a short cut, is moving your mouse all over your screen, going from one side to the other. It give sketchup a look of a very old sofware, when other software have a much better ergonomi. What sketchup should be so plugin designers and users would be able to juste work without having to thinks how to adapt there work to sketchup, but how to ajuste sketchup to there work.
          • F Offline
            FlorinAp
            After version 2.4a there is a very big compatibility issue with SU 2022 (and maybe also with previous SU versions.!), that makes SU barely usable - I've spent 6-8 hours trying to understand what the hell is wrong with my SU...
            Now maybe I would have to pair it with a LibFredo version..., but today I've spent my energy reserves.
            Sometimes (rarely) I use SU 2022, for compatibility with other plugins or for printing options that have disappeared starting with SU 2023.
            Anyway, a bug (any bug.!!) in LOTT affects the SU engine, so you have the choice to use it or throw it away completely.
            • fredo6F Offline
              fredo6 @FlorinAp
              @FlorinAp
              First thing would be to upgrade both LibFredo6 and LOTT to their latest published versions.
              Second, can you describe the 'bug' you have with SU2022?
              • F Offline
                FlorinAp @fredo6
                @fredo6 They already were in the latest version (otherwise I wouldn't come here to write).
                There was no "one single" bug - SU and the entire OS were almost frozen, you had to wait for a few minutes before you had any access to SU and also to the OS (W 11)... for about 1-2 minutes, and then the same cycle... (flashing and freezing... and couldn't use no other app).
                Experience (a lot of it) and intuition finally drove me to LOTT - and I made no other changes in my PC other than downgrade LOTT (LibFredo seems to be fine at the second to last version) - It has been a few hours and everything is alright (I mean as much as it can it can be after W7).
                This kind of problem started on many levels with SU (and its plugins) only after W7, but unfortunately, we are not in the driver's seat... and we have to move forward, everything was flawless but starting with W10... many headaches for users and developers, concerning many other software.
                • F Offline
                  FlorinAp @FlorinAp
                  @FlorinAp All these incompatibility issues between SU 2022 and W10-W11 have disappeared starting with SU 2023, and maybe at some point not everything can be compatible with everything... i understand that, but it is fair that at that point every developer should mention in its release notes where the compatibility ends.
                  If it helps - your release notes are very helpful.!
                  F fredo6F 2 Replies Last reply Reply Quote 0
                  • F Offline
                    FlorinAp @FlorinAp
                    @FlorinAp Sorry, i was a bit irritated after so many wasted hours, and I missed telling you something - everything was starting as soon as I would approach my mouse to any palette, if you wouldn't touch the palette... everything was fine.
                    Although SU 2022 would load very late and very slowly because of the vignette, but after that you are not allowed to touch any pallette; but if I disbaled the LOTT completely, SU would also load very fine and fast.
                    I hope it helps...!
                    • fredo6F Offline
                      fredo6 @FlorinAp
                      @FlorinAp
                      LOTT is compatible with SU2022. It even includes menu command.
                      74a63105-7aba-448a-b55b-b029826a1083-image.png c7c0cba5-07ae-48b2-8564-b79d2848e888-image.png
                      So what exactly is the problem.
                      Can you exit SU2022 with the Ruby console opened and relaunch SU2022. The Ruby console should open at startup and log potential errors.
                      • F Offline
                        FlorinAp @fredo6
                        @fredo6 I don't know what is the problem, but even with 2.4a SU 2022 is not usable, with 2.4a it just doesn't freeze my os anymore, but SU 2022 it is still mostly unusable, the only way to make it usable is to disable LOTT completely.
                        Since I wrote that everything is alright I haven't used it, I just left it there, opened in background, to understand now that I cant use it... if I don't disable LOTT.
                        I will try what you suggested...!
                        • F Offline
                          FlorinAp @FlorinAp
                          @FlorinAp Well man, below is the content from the ruby window, for me is an alien language, but maybe you can make sense of it...!
                          For me is not a big deal because now I use mostly SU 23 and 24 - it's just a sick incurable stubbornness to understand and fix everything I touch, so if it makes sense to you maybe you will be willing to share; I don't see nothing "Fredo" related, but it seems to be a conflict created by some Curic extensions....
                          "finished reading language file
                          tb_mode,single
                          tb_Settingout,true
                          tb_Draw,true
                          tb_Edit,true
                          tb_Array,true
                          tb_Wall,true
                          tb_Staircase,true
                          tb_Win,true
                          tb_Roof,true
                          tb_Site,true
                          tb_Structure,true
                          point_on_face,true
                          divide,true
                          align,true
                          perpendicular_line,true
                          fonplane,true
                          bestface,true
                          extrude1,true
                          extrude2,true
                          move_vertex,true
                          fillet,true
                          chamfer,true
                          extend,true
                          offset_edge,true
                          hline_faces,true
                          slopeedges,true
                          linear_array,true
                          rect_array,true
                          polar_array,true
                          path_array,true
                          wallsctrl,true
                          opening,true
                          hgroove,true
                          escalator,true
                          wframe,true
                          dframe,true
                          paneldivide,true
                          screen1,true
                          hlouvres,true
                          vlouvres,true
                          joists,true
                          roof1,true
                          hiproof,true
                          revsurf,true
                          mdeck,true
                          stairsctrl,true
                          profiles_on_plane,true
                          cutfill,true
                          siteb,true
                          fndctrl,true
                          columnctrl,true
                          contour,true
                          setlayer,true
                          mergelayer,true
                          framesel,true
                          scale,true
                          center1,true
                          ptsinfo,true
                          extrude3,true
                          profiles3d,true
                          extrude0,true
                          loading 1001bit pro menu >> true
                          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_projections/dbur_projections.rbe:5: warning: already initialized constant Math::PROJEPSILON
                          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_guidetools/dbur_guidetools.rbe:6: warning: previous definition of PROJEPSILON was here
                          true
                          Sketchup Version is = 17
                          88
                          "icon_thickness_mode.svg"
                          "c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_dio2/Resources/icon_thickness_mode.svg"
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/cmap/subtable.rb:13: warning: already initialized constant TTFunk::Table::Cmap::Subtable::ENCODING_MAPPINGS
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/cmap/subtable.rb:13: warning: previous definition of ENCODING_MAPPINGS was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:6: warning: already initialized constant TTFunk::Encoding::MacRoman::TO_UNICODE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:6: warning: previous definition of TO_UNICODE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:42: warning: already initialized constant TTFunk::Encoding::MacRoman::FROM_UNICODE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:42: warning: previous definition of FROM_UNICODE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:50: warning: already initialized constant TTFunk::Encoding::MacRoman::POSTSCRIPT_GLYPH_MAPPING
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:50: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:6: warning: already initialized constant TTFunk::Encoding::Windows1252::TO_UNICODE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:6: warning: previous definition of TO_UNICODE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:18: warning: already initialized constant TTFunk::Encoding::Windows1252::FROM_UNICODE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:18: warning: previous definition of FROM_UNICODE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:26: warning: already initialized constant TTFunk::Encoding::Windows1252::POSTSCRIPT_GLYPH_MAPPING
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:26: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:9: warning: already initialized constant TTFunk::Table::Glyf::Compound::ARG_1_AND_2_ARE_WORDS
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:9: warning: previous definition of ARG_1_AND_2_ARE_WORDS was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:10: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_SCALE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:10: warning: previous definition of WE_HAVE_A_SCALE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:11: warning: already initialized constant TTFunk::Table::Glyf::Compound::MORE_COMPONENTS
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:11: warning: previous definition of MORE_COMPONENTS was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:12: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_AN_X_AND_Y_SCALE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:12: warning: previous definition of WE_HAVE_AN_X_AND_Y_SCALE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:13: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_TWO_BY_TWO
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:13: warning: previous definition of WE_HAVE_A_TWO_BY_TWO was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:14: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_INSTRUCTIONS
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:14: warning: previous definition of WE_HAVE_INSTRUCTIONS was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:20: warning: already initialized constant TTFunk::Table::Glyf::Compound::Component
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:20: warning: previous definition of Component was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/hmtx.rb:22: warning: already initialized constant TTFunk::Table::Hmtx::HorizontalMetric
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/hmtx.rb:22: warning: previous definition of HorizontalMetric was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/post/format10.rb:5: warning: already initialized constant TTFunk::Table::Post::Format10::POSTSCRIPT_GLYPHS
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/post/format10.rb:5: warning: previous definition of POSTSCRIPT_GLYPHS was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/sbix.rb:11: warning: already initialized constant TTFunk::Table::Sbix::BitmapData
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/sbix.rb:11: warning: previous definition of BitmapData was here
                          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_oi/loader.rbe:169: warning: already initialized constant CURIC::OI::PLUGIN
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi.rb:6: warning: previous definition of PLUGIN was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/cmap/subtable.rb:13: warning: already initialized constant TTFunk::Table::Cmap::Subtable::ENCODING_MAPPINGS
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/cmap/subtable.rb:13: warning: previous definition of ENCODING_MAPPINGS was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:6: warning: already initialized constant TTFunk::Encoding::MacRoman::TO_UNICODE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:6: warning: previous definition of TO_UNICODE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:42: warning: already initialized constant TTFunk::Encoding::MacRoman::FROM_UNICODE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:42: warning: previous definition of FROM_UNICODE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:50: warning: already initialized constant TTFunk::Encoding::MacRoman::POSTSCRIPT_GLYPH_MAPPING
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:50: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:6: warning: already initialized constant TTFunk::Encoding::Windows1252::TO_UNICODE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:6: warning: previous definition of TO_UNICODE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:18: warning: already initialized constant TTFunk::Encoding::Windows1252::FROM_UNICODE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:18: warning: previous definition of FROM_UNICODE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:26: warning: already initialized constant TTFunk::Encoding::Windows1252::POSTSCRIPT_GLYPH_MAPPING
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:26: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:9: warning: already initialized constant TTFunk::Table::Glyf::Compound::ARG_1_AND_2_ARE_WORDS
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:9: warning: previous definition of ARG_1_AND_2_ARE_WORDS was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:10: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_SCALE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:10: warning: previous definition of WE_HAVE_A_SCALE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:11: warning: already initialized constant TTFunk::Table::Glyf::Compound::MORE_COMPONENTS
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:11: warning: previous definition of MORE_COMPONENTS was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:12: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_AN_X_AND_Y_SCALE
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:12: warning: previous definition of WE_HAVE_AN_X_AND_Y_SCALE was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:13: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_TWO_BY_TWO
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:13: warning: previous definition of WE_HAVE_A_TWO_BY_TWO was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:14: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_INSTRUCTIONS
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:14: warning: previous definition of WE_HAVE_INSTRUCTIONS was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:20: warning: already initialized constant TTFunk::Table::Glyf::Compound::Component
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:20: warning: previous definition of Component was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/hmtx.rb:22: warning: already initialized constant TTFunk::Table::Hmtx::HorizontalMetric
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/hmtx.rb:22: warning: previous definition of HorizontalMetric was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/post/format10.rb:5: warning: already initialized constant TTFunk::Table::Post::Format10::POSTSCRIPT_GLYPHS
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/post/format10.rb:5: warning: previous definition of POSTSCRIPT_GLYPHS was here
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/sbix.rb:11: warning: already initialized constant TTFunk::Table::Sbix::BitmapData
                          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/sbix.rb:11: warning: previous definition of BitmapData was here
                          "RubyEncoder loader: C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_true_isolate/rgloader/rgloader27.mingw.x64.so"
                          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_axis/utils.rbe:123: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_space/utils.rbe:374: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/projection/projection.rbs:23: warning: already initialized constant Math::PROJEPSILON
                          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_projections/dbur_projections.rbe:5: warning: previous definition of PROJEPSILON was here
                          Tolerance default to 0.001
                          radius = xxx
                          segmentation = xxx
                          delete_corners = xxx
                          radius = xxx
                          segmentation = xxx
                          "Add help menu!"
                          "create new"
                          "created"
                          #Sketchup::Menu:0x000001d455838b98
                          (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                          "Add help menu!"
                          "created"
                          "created"
                          (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open"
                          • N Offline
                            nicolasberthier @fredo6
                            @fredo6
                            I exeprience the same problem in SU24 last updat.
                            Is there any way that the Menu search dialogue can be unblocked ? I would realy appreciate it to be available again on SU24.
                            Thanks !
                            • O Offline
                              optimaforever
                              I have a problem with the MINDSIGHT STUDIOS plugins suddenly not appearing in my toolbars. I realized they also disappear from the Master Toolbar Manager.
                              The plugins are still loaded and accessible from their native toolbars.Capture d'écran 2024-11-25 145538.pngCapture d'écran 2024-11-25 150903.png
                              • fredo6F Offline
                                NEW RELEASE: LordOfTheToolbars v2.9a - 13 Dec 24
                                Requirements
                                • LibFredo6: v14.7a or above
                                LordOfTheToolbars 2.9a is a maintenance release including:
                                • Fix related to an issue preventing VRay commands to execute.
                                Home Page of LordOfTheToolbars for information and Download.
                                Main post of this LordOfTheToolbars thread.
                                alexpacio2013A Y 3 Replies Last reply Reply Quote 0
                                • alexpacio2013A Offline
                                  alexpacio2013 @fredo6
                                  @fredo6 It works great, congratulations for your speed and competence, thanks
                                  • Y Offline
                                    yyxp1989 Newcomers @fredo6
                                    Hello @fredo6 I have a problem that I can't solve. Could you help me? LordOfTheToolbars v2.9a It worked fine during the first run and I can add tools icon.
                                    However, I couldn't use the Master Toolbar Manager after restarting SketchUp.I can't drag the icon. It doesn't work.
                                    The problem remained the same even after reinstalling it.
                                    SU Version: 2024.0.594-64bit
                                    LibFredo6_v14.9a
                                    • fredo6F Offline
                                      fredo6 @yyxp1989
                                      @yyxp1989
                                      I cannot read what is in the black window
                                      Y 1 Reply Last reply Reply Quote 0
                                      • Y Offline
                                        @fredo6 I switched back to SketchUp 2023, and everything works fine. Thank you for your work.
                                        The issue occurs in SU2024.0.594, which may be a compatibility problem. The Master Toolbar Manager window does not respond to operations.
                                        Click Show DEV Tools
                                          @fredo6
                                          With the latest version of Lord of thr Toolbar the compatibility problem with vay 7 has been solved but now I find another problem, often when I open sketchup, it crashes, The crash happens just when it goes to open the menu bars created with Lord of the toolbar. I found that by disabling Lord of the Toolbar, Sketchup opens perfectly. I don't understand which one is due to incompatibility with other plugins or from something else. To open sketchup I have to disable Lord of the toolbar AND re-enable it when it is open, through the Sketchauction plugin manager.
                                            AISmebel
                                            Hello Fredo. Do you think it will be possible to return the "Menu" tool in the new SU 2025?
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 23 / 25
