    Piano with Rayscaper
    rayscapersketchuprender
    20 Posts 9 Posters 2.4k Views 9 Watching
      Having some fun with Rayscaper
      Gus RG ntxdaveN Mike AmosM 3 Replies Last reply Reply Quote 6
      • Gus RG Offline
        Gus R @Rich O Brien
        @Rich-O-Brien Very nice. I've been using that tile pattern a lot lately to set up some UV's in Sketchup for D5 Render. Have you watched the documentary "The Making of a Steinway Piano" yet?
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • ntxdaveN Offline
          ntxdave @Rich O Brien
          @Rich-O-Brien Very nice Rich. πŸ‘πŸ‘
          Now tell me how you get that pattern.
          Press F1...thank me later
          N 1 Reply Last reply Reply Quote 0
            Wow, that's a fantastic render. Love the realism, and the great use of depth-of-field.
              Rich O Brien Moderator @Gus R
              @Gus-R said in Piano with Rayscaper:
              No, but I just did. AI can't do what those folks can. There's a lot to be said talented craftspeople. Such a nice job too.
              I couldn't get SketchUp to make the black keys properly so I just horsed in basic stuff. I hoped the high DOF would hide the shortcuts.
              I did the famous Robatto Piano render in Blender so I could help Thomas start to dial in some stuff for RayScaper. I actually saw the original image on X and thought it was a good excerise for lighting and camera position.
              RayScaper still does need some work regarding normals and light/dof values but its still impressive and fun to use. Fast too
              @ntxdave said in Piano with Rayscaper:
              It's the Checkerboard material SketchUp ships with under Patterns
              ntxdaveN 1 Reply Last reply Reply Quote 2
              • ntxdaveN Offline
                @Rich-O-Brien said in Piano with Rayscaper:
                Thanks Rich. I should have thought of that. Duh! πŸ€ͺ
                  Rich O Brien Moderator @ntxdave
                  @ntxdave I’m convinced F1 is broken on your keyboard. 🀐
                  Gus RG ntxdaveN P 3 Replies Last reply Reply Quote 0
                  • Gus RG Offline
                    Gus R @Rich O Brien
                    @Rich-O-Brien
                    Rich,
                    Where is this famous Robatto Piano render? 😊
                    Edit: wait a minute. I just noticed my name on the piano. I'm getting old!
                    • ntxdaveN Offline
                      Well you have to be using your keyboard and SketchUp to get that result. πŸ€ͺ
                        pixelcruncher Extension Creator @Rich O Brien
                        @Rich-O-Brien @Gus-R
                        Not following, what's the backstory behind the name Robatto?
                          Rich O Brien Moderator @pixelcruncher
                          @pixelcruncher Just some cranky guy that makes very detailed models and yummy renders
                          (www.instagram.com)
                          • Gus RG Offline
                            Gus R @Rich O Brien
                            (www.instagram.com)
                            Me? Cranky? πŸ˜‡
                            P 1 Reply Last reply Reply Quote 1
                              pixelcruncher Extension Creator @Gus R
                              @Gus-R don’t know about your mood but the renders are yummy indeed!
                                @pixelcruncher said in Piano with Rayscaper:
                                How do I share this file so others with RayScaper can test render times etc?
                                Extensions > RayScaper > Create Archive
                                Will that allow someone to open the SKP file and RayScaper will load the materials and HDR?
                                HornOxxH alvisA 2 Replies Last reply Reply Quote 1
                                • HornOxxH Offline
                                  HornOxx @Rich O Brien
                                  @Rich-O-Brien wunderbar! πŸ‘
                                  never trust a skinny cook
                                    Mike Amos @Rich O Brien
                                    @Rich-O-Brien
                                    Top notch.
                                    • alvisA Offline
                                      alvis @Rich O Brien
                                      @Rich-O-Brien Nice
                                      • tuna1957T Online
                                        tuna1957
                                        Most excellent ! Always like these β€œnon standard” views in renders.
                                        • N Offline
                                          nlipovac @ntxdave
                                          @ntxdave This is an online generator, I made a few for when I do UV mapping.
                                          https://uvchecker.vinzi.xyz/
                                            Rich O Brien Moderator @nlipovac
                                            @nlipovac said in Piano with Rayscaper:
                                            You made that?
