    2.2k Posts 487 Posters 933.7k Views 492 Watching
      Rich O Brien Moderator @alexkhaterfredrik
      @alexkhaterfredrik said in SCFLicense: Extension Licensing on Sketchucation:
      why do i keep getting ERROR_A0C Computer mismatch?!
      Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
      You either renamed your device or copied license files from device to device
      Run the command above so we can see your setup
        analuiizaa
        Someone can help me with this?? my licese does not work!!!!
          Rich O Brien Moderator @analuiizaa
          @analuiizaa Sure, please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command and copy/paste the text into your reply.
          Or share the error messages you are encountering.
            djcregan
            HI
            I have sketchup 24 and a Fredoscale perpetual licence, after getting a message saying my trial was up I tried loading my licence, however it wont let me a nd say "Error in the License Validation Response from Sketchucation: License seats exceeded"
            I recently replaced my old work computer but I cant see how I can release the licence for it. Please help
              Rich O Brien Moderator @djcregan
              @djcregan said in SCFLicense: Extension Licensing on Sketchucation:
              You can manage seats at https://sketchucation.com/webshop/my-licences.php
              D 1 Reply Last reply Reply Quote 0
                TIG Moderator @noorhalimmahat
                @noorhalimmahat
                Yes, but you need to install [and the restart] using the latest versions of the extension[s], LibFredo6 and the SketchUcation tools [for the licensing]...
                  djcregan @Rich O Brien
                  Yes
                  I fully understand this
                  I have Removed the plugin, reinstalled it, even removed and reinstalled Libfredo. I think I will just buy it again as its costing me more the 15 dollars to f.. about trying to sort. Annoying though.
                    Yes
                    Send me an email at support@sketchucation.com and we'll walk you through it.
                    There's no need to repurchase that's wasting money if the fix is relatively easy.
                      khan1986 Newcomers
                      hello i got my license file but when i activate it . it show communication error with sketchucation.
                        Rich O Brien Moderator @khan1986
                        @khan1986 said in SCFLicense: Extension Licensing on Sketchucation:
                        We replied to your email earlier regarding this. Server communication errors are client side. Most likely a strict network policy, firewall or admin privileges are the root cause.
                        We refunded your purchase and disabled your license per your request via email.
                          junphuc17945 @TIG
                          @TIG my old pc, not installed new Fredo version, so i can not release license
                          TIGT 1 Reply Last reply Reply Quote 0
                            TIG Moderator @junphuc17945
                            @junphuc17945
                            As Rich explained in the post just before yours...
                            Send an email at support@sketchucation.com and he'll walk you through fixing it.
                              Lprawita Newcomers
                              I just bought the $50 license and I tried to activate it.
                              I got an error message like this:
                                Rich O Brien Moderator @Lprawita
                                @Lprawita
                                That is your network blocking access to our server.
                                Please whitelist *.sketchucation.com or activate on a less strict network
                                  dhcu321 Newcomers @Rich O Brien
                                  @Rich-O-Brien
                                  Hello, I really need your help.
                                  First of all, I'm sorry that i'm not good at english.
                                  I have two problems.
                                  The first one is that Joint Push Pull License ID 165592; is not cancelled.
                                  Can you release it?
                                  The second one is to register for a license on a new PC, but I got an A04 error code.
                                  How can I fix it?
                                  Thank you.
                                    Rich O Brien Moderator @dhcu321
                                    @dhcu321
                                    Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp (on both devices separately) and copy/paste the output
                                    of both devices into your reply.
                                      mencalada Newcomers
                                      Hola porfavor envio este correo para socilicitar la etension del plugin Joint Push Pull
                                        DietVillaa Newcomers
                                        Hello, can you also release seat Seat ID: 190451; HW ID: RR1728036983.0J; Date of activation: 04/10/2024, thank you! hoping for your fast repoonse!
                                          Rich O Brien Moderator @DietVillaa
                                          @DietVillaa
                                          @dhcu321 Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp (on both devices separatel...
                                          sketchucation (community.sketchucation.com)
                                            Thank you for your reply.
                                            These problems occurred on the same PC.
                                            I think this error occurred while logging into Windows.
                                            Let me know if you need any more information.
                                            @Rich-O-Brien
                                            Fredo6 Plugins Information on 2024-10-21 11:22:07 +0900
                                            • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                            • Sketchup: 22.0.354
                                            • LibFredo6: v14.4c
                                            • LibFredo6 Binary loaded
                                            • Sketchucation ExtensionStore: 4.4.1
                                            • SCFLicense: v6.4a - 74
                                            • Fredo6 Plugins
                                              Curviloft v2.0a
                                              FredoScale v3.6a
                                              JointPushPull v4.8a
                                              RoundCorner v3.4a
                                              Signature File: 2024-06-24 10:24:45 +0900
                                            • 100
                                            • 101
                                            • 102
                                            • 103
                                            • 104
                                            • 109
                                            • 110
                                            • 102 / 110
