    2.3k Posts 515 Posters 2.8m Views 520 Watching
      MateusArq2024 Newcomers
      I already bought the license but I can't validate it, due to the erroro
        Rich O Brien Moderator @MateusArq2024
        @MateusArq2024 Please whitelist *.sketchucation.com or switch to a less strict network.
        M 1 Reply Last reply
          MateusArq2024 Newcomers @Rich O Brien
          @Rich-O-Brien thank you!
          • Q
            QZHOU Newcomers
            Hello,
            what is the problem of my license, I have try many times. 5b600b653cc132d6872b4551a581adb.png 081e6864baccbdc5aefb6373b4b495f.png
            TIGT 1 Reply Last reply
              TIG Moderator @QZHOU
              @QZHOU
              You need to install the latest versions of the extension, LibFredo6 and the SketchUcation toolset [for the licensing].
              That error message says the signature-file cannot be read.
              You may have changed your computer's name, which invalidates it.
              It suggests you open the signature-file's folder and delete it.
              After a restart a new signature file is made to suit the current setup.
              The validate your license[s]...
              Note that errors like this can also occur if your computer's name contains non-ASCII characters - going against the advise of Windows.
              I suspect that you are Chinese - so have you got any special-characters in your computer-name ?
              This can break licensing setups like this...
              Try renaming your computer following these rules...
              A-Za-z0-9 - are OK
              The following are not OK...
              period (.)
              backslash (\)
              forward slash (/)
              colon (:)
              asterisk (*)
              question mark (?)
              quotation mark (")
              less than sign (<)
              greater than sign (>)
              vertical bar (|)
              And ay other special characters or non-ASCII foreign alphabet letters will also cause issues,
              • noorhalimmahatN
                noorhalimmahat
                Hi Fredo. is this licences work for sketchup Pro2018?
                  alexkhaterfredrik
                  why do i keep getting ERROR_A0C Computer mismatch?!
                    Rich O Brien Moderator @alexkhaterfredrik
                    @alexkhaterfredrik said in SCFLicense: Extension Licensing on Sketchucation:
                    Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                    You either renamed your device or copied license files from device to device
                    Run the command above so we can see your setup
                      analuiizaa
                      Someone can help me with this?? my licese does not work!!!!
                        Rich O Brien Moderator @analuiizaa
                        @analuiizaa Sure, please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command and copy/paste the text into your reply.
                        Or share the error messages you are encountering.
                          djcregan
                          HI
                          I have sketchup 24 and a Fredoscale perpetual licence, after getting a message saying my trial was up I tried loading my licence, however it wont let me a nd say "Error in the License Validation Response from Sketchucation: License seats exceeded"
                          I recently replaced my old work computer but I cant see how I can release the licence for it. Please help
                            Rich O Brien Moderator @djcregan
                            @djcregan said in SCFLicense: Extension Licensing on Sketchucation:
                            You can manage seats at https://sketchucation.com/webshop/my-licences.php
                            D 1 Reply Last reply
                              TIG Moderator @noorhalimmahat
                              @noorhalimmahat
                              Yes, but you need to install [and the restart] using the latest versions of the extension[s], LibFredo6 and the SketchUcation tools [for the licensing]...
                                djcregan @Rich O Brien
                                Yes
                                I fully understand this
                                I have Removed the plugin, reinstalled it, even removed and reinstalled Libfredo. I think I will just buy it again as its costing me more the 15 dollars to f.. about trying to sort. Annoying though.
                                  Yes
                                  Send me an email at support@sketchucation.com and we'll walk you through it.
                                  There's no need to repurchase that's wasting money if the fix is relatively easy.
                                  • K
                                    khan1986 Newcomers
                                    hello i got my license file but when i activate it . it show communication error with sketchucation.
                                      Rich O Brien Moderator @khan1986
                                      @khan1986 said in SCFLicense: Extension Licensing on Sketchucation:
                                      We replied to your email earlier regarding this. Server communication errors are client side. Most likely a strict network policy, firewall or admin privileges are the root cause.
                                      We refunded your purchase and disabled your license per your request via email.
                                        junphuc17945 @TIG
                                        @TIG my old pc, not installed new Fredo version, so i can not release license
                                          TIG Moderator @junphuc17945
                                          @junphuc17945
                                          As Rich explained in the post just before yours...
                                          Send an email at support@sketchucation.com and he'll walk you through fixing it.
                                          • L
                                            Lprawita Newcomers
                                            I just bought the $50 license and I tried to activate it.
                                            I got an error message like this:
                                            • 94
                                            • 95
                                            • 96
                                            • 97
                                            • 98
                                            • 115
                                            • 116
                                            • 96 / 116
