    2.3k Posts 515 Posters 2.3m Views 520 Watching
      junphuc17945 @TIG
      @TIG my old pc, not installed new Fredo version, so i can not release license
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @junphuc17945
        @junphuc17945
        As Rich explained in the post just before yours...
        Send an email at support@sketchucation.com and he'll walk you through fixing it.
          Lprawita Newcomers
          I just bought the $50 license and I tried to activate it.
          I got an error message like this:
            Rich O Brien Moderator @Lprawita
            @Lprawita
            That is your network blocking access to our server.
            Please whitelist *.sketchucation.com or activate on a less strict network
            D 1 Reply Last reply Reply Quote 0
              dhcu321 Newcomers @Rich O Brien
              @Rich-O-Brien
              Hello, I really need your help.
              First of all, I'm sorry that i'm not good at english.
              I have two problems.
              The first one is that Joint Push Pull License ID 165592; is not cancelled.
              Can you release it?
              The second one is to register for a license on a new PC, but I got an A04 error code.
              How can I fix it?
              Thank you.
                Rich O Brien Moderator @dhcu321
                @dhcu321
                Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp (on both devices separately) and copy/paste the output
                of both devices into your reply.
                  mencalada Newcomers
                  Hola porfavor envio este correo para socilicitar la etension del plugin Joint Push Pull
                    DietVillaa Newcomers
                    Hello, can you also release seat Seat ID: 190451; HW ID: RR1728036983.0J; Date of activation: 04/10/2024, thank you! hoping for your fast repoonse!
                      Rich O Brien Moderator @DietVillaa
                      @DietVillaa
                      @dhcu321 Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp (on both devices separatel...
                      sketchucation (community.sketchucation.com)
                        Thank you for your reply.
                        These problems occurred on the same PC.
                        I think this error occurred while logging into Windows.
                        Let me know if you need any more information.
                        @Rich-O-Brien
                        Fredo6 Plugins Information on 2024-10-21 11:22:07 +0900
                        • Platform: x64-mswin64_140 - Ruby: 2.7.2
                        • Sketchup: 22.0.354
                        • LibFredo6: v14.4c
                        • LibFredo6 Binary loaded
                        • Sketchucation ExtensionStore: 4.4.1
                        • SCFLicense: v6.4a - 74
                        • Fredo6 Plugins
                          Curviloft v2.0a
                          FredoScale v3.6a
                          JointPushPull v4.8a
                          RoundCorner v3.4a
                          Signature File: 2024-06-24 10:24:45 +0900
                          @dhcu321 Please update Libfredo to latest release
                          SketchUp Plugins | PluginStore | SketchUcation
                          SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                          (sketchucation.com)
                            Javier_ELARQ Newcomers
                            Hola, como hago para obtener la licencia?
                              Darius
                              Hello,
                              Have 3 seats on an extension, vant use the 1st one, only two releasable ones. How can I use the first one ? aaa.png
                                Rich O Brien Moderator @Darius
                                @Darius Update Sketchucation Tools and Libfredo on that device to enable online releasing for that device.
                                Or open SketchUp on that device and release a seat using the License dialog.
                                  Darius @Rich O Brien
                                  @Rich-O-Brien Problem is that we have 3 working seats, but the none of it uses 1st license. Is there a way to release it manually ?
                                    @Darius said in SCFLicense: Extension Licensing on Sketchucation:
                                    Sorry, your message is unclear. You have working seats that use the license file is describing a proper use case.
                                    If you go to any of the devices you can release the seat from its License dialog. Since I don't know what extension you are talking about I can't give more details.
                                    If you want to email us at support@sketchucation.com we'll try help.
                                      celestinf
                                      Bonjour,
                                      Je me permets de vous écire car j'ai fais l'acquisition en 2023 de plusieurs licences que je vois bien dans mon espace License. J'ai du changer de disque dur et réinstaller l'ensemble des éléments de mon pc. Lorsque je lance par exemple le fredoscale depuis sketchup j'ai le message me disant d'acheter ou utiliser ma license. Je vais donc charger dans mon espace License la License que je valide ensuite par sketchup et j'obtient le message "erreur dans la validation de licence, requete à sketchupaction ERROR_A0B.
                                      Pouvez vous me donner la procédure afin que je puisse corriger cela?
                                      Merci à vous
                                        Rich O Brien Moderator @celestinf
                                        @celestinf said in SCFLicense: Extension Licensing on Sketchucation:
                                        Bonjour,
                                        Hello I take the liberty of writing to you because I acquired several licenses in 2023 that I can see in my License space. I had to change my hard drive and reinstall all the elements of my pc. When I launch the fredoscale from sketchup, for example, I get the message telling me to buy or use my license. So I'm going to load the License in my License space that I then validate by sketchup and I get the message "error in license validation, request to sketchupaction ERROR_A0B. Can you give me the procedure so that I can correct this? Thank you
                                        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                        C 1 Reply Last reply Reply Quote 0
                                          chiklopes
                                          Hello,
                                          I bought FredoBundle in 2022, permanent licenses, and it was working fine. But now I receive a message that is "Not Licensed". Try to validate it but without success. the folder with the licenses still there but somehow it doesn't recognise the files....
                                          try to download my licenses again but still not recognize them.
                                          I update all the Fredo plugins using ExtensionStore v4.2.9, but still not working
                                          please, any help on that? thanks
                                            Rich O Brien Moderator @chiklopes
                                            @chiklopes said in SCFLicense: Extension Licensing on Sketchucation:
                                            Please update Sketchucation Tools to 4.4.1 it has the latest licensing system
                                            Sketchucation Tools | SketchUcation
                                            (sketchucation.com)
                                            You can upgrade Sketchucation Tools directly from within our ExtensionStore. Restart SketchUp after installation and re-license.
                                            • 95
                                            • 96
                                            • 97
                                            • 98
                                            • 99
                                            • 115
                                            • 116
                                            • 97 / 116
