    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 38.7k Views 7 Watching
    • pixelcruncherP
      pixelcruncher Extension Creator @Mike Amos
      @Mike-Amos said in Rayscaper, My trip down the road to adjumacation.:
      @pixelcruncher
      Nothing actually 'bothers' me, the screen is reminiscent of Maxwell in most respects.
      That's an interesting observation; I've never used Maxell before πŸ™‚
      The hdri/texture corner is both bigger than it need to be while being too small to show much in the way of detail of the different options.
      Would clearer tabs help here? Or tabs at the top instead of sideways?
      When it comes to it, the single screen thing is getting old but I am looking into that but clearing screen clutter when elements are not requirted would be very helpful.
      Undocking these different parts of the Rayscaper window an placing them on =the second or third monitor would enable much more clarity for the render window itself. IMOHO, of course.
      I plan to do docking/undocking, but it's a bit of work because the user interface library I am using does not support it.
      Mike AmosM 1 Reply Last reply
        Mike Amos @pixelcruncher
        @pixelcruncher
        For some reason the mirror is not reflecting, suitably set up in Rayscaper, just not apparent in the render.9 17m 52s.jpg
          What render method are you using?
          Could it be the Max Depth for Approx GI need increasing if you are using Approx GI?
          • pixelcruncherP
            Hey @Mike-Amos
            Did what @Rich-O-Brien work? If the depth is insufficient, the render engine will cut paths short before reaching a light source, and the mirror will be black.
            How are you creating a mirror? Using the simple mirror material or something else?
            You can pack up the whole scene and send it my way (via the Create Archive option). Then I can have a look.
            Cheers,
            Thomas
              @pixelcruncher
              I tried all that, pretty Elf explanatory tbh.
              Nada.
              I shall try to pm the archive file.
              • pixelcruncherP
                @Mike-Amos Yup, send it my way. I will have a look.
                  @pixelcruncher
                  Via email.
                  • pixelcruncherP
                    @Mike-Amos Thanks for the scene. That was helpful.
                    The problem is that the color of the mirror is black, so it won't reflect anything:
                    Setting the color to white (or anything non-black) will result in a mirror:
                    Sorry, I butchered your camera setup to make it more evident that the mirror works now.
                    Cheers,
                    Thomas
                      @pixelcruncher
                      Thanks, I guess the 'problem' is that the render engines I have used preferred black as the colur in Sketchup.
                      I just defaulted to this from habit.
                      • pixelcruncherP
                        @pixelcruncher
                        No worries, I'm glad we got it sorted!
                          @pixelcruncher
                          Moving onwards, some of the lights appear to have gone AWOL but then, so has the skirting board.......
                          • pixelcruncherP
                            @Mike-Amos sounds like a bug. Let's fix that.
                            Do you mind sending me your most recent scene again?
                            • What is the name of the light component or components that disappeared?
                            • Is the skirting board modeled as geometry at the bottom of the wall? I will check that out as well once I have your model file.
                            Cheers,
                            Thomas
                              @pixelcruncher
                              The lights are directional lights, the skirting board is geometry that has been removed from Sketchup the model, pardon the pun.
                              I am concerned that memory handling is an issue and will probably remain that way until the basic hardware is fixed, should go off for repair this week. Crossed fingers included.
                                Mike Amos @Mike Amos
                                @Mike-Amos
                                OK, replaced the missing skirting board and put the lights back. Wotcha fink folks?
                                • Bryan KB
                                  Overall, really nice, but I would change the light temp (seems kinds of orange-ish yellow in this shot) and up the exposure just a but more.
                                  Just a little less orange in the light. Natural light is orange-ish yellow.
                                    Mike Amos @Bryan K
                                    @Bryan-K
                                    Ta mate, feedback always helpful. Building and rendering the scene can lead to missing/ignoring stuff.
                                    Rich O BrienR pixelcruncherP Bryan KB 3 Replies Last reply
                                      @Mike-Amos If the sun coming in the window is a directional light you should raise the angle values slightly to soften the shadow.
                                      I sometime mix both HDRIs and Directional Lights to get the light the way I want it.
                                      HDRs are great but some might offer you the background you want but not the light direction or power. Adding a directional to give you more artistic controls is sometimes a good hack.
                                      Be mindful of power values and balance it.
                                      A directional light with zero angle results in crisp clean shadows...
                                      Increasing it to 2-3 will soften edges....
                                      massimoM 1 Reply Last reply
                                      • massimoM
                                        massimo Moderator @Rich O Brien
                                        Rich's ones are good advices. Even if the best HDRIs, for example P.Guthrie's and CGSource's ones just to name two, don't need any extra sun because produce nice shadows, most of them need a bit of boost.
                                        Does Rayscaper have something like this however?
                                        I mean that you can move the sun in the physical sky until it will match the one in the HDRI. Because if not would be really difficult to align the two suns and this could lead to a fake result.
                                          Rich O Brien Moderator @massimo
                                          @massimo said in Rayscaper, My trip down the road to adjumacation.:
                                          No, it's guesswork if you want to align HDR sun and a directional light.
                                          massimoM Mike AmosM 2 Replies Last reply
                                          • massimoM
                                            @Rich-O-Brien Ok, maybe a suggestion for the next release then.πŸ˜‰
                                            Reply Quote 2
                                            • 2 / 9
