    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 19.2k Views 7 Watching
      pixelcruncher Extension Creator @Mike Amos
      This is my Rayscaper thread so, yes, in Rascaper.
      Makes sense, I didn't want to assume 😁
      There are 8 lights in that scene which should be OK along with an EXR.
      I would like to have a better, more informative method of identifying the lights being adjusted. Several are candles so the light has to be reduced for that. Perhaps a designator on the scree would help.
      That's a good idea. Overlaying the viewport with some widgets to indicate the lights. I will put it on my roadmap.
      Basically I am finding any real adjustment difficult to near impossible due to not being able to read the dialogue boxes. I will have at some stage to acquire a nother monitor but that will do nothing to fix this issue.
      This is good feedback. What is your display resolution, and are you using display scaling? I don't think Rayscaper respects display scaling right now, but I have to check the documentation of the user interface library I am using.
      TBH, while I render architectural pieces, I do not DO architectural renders. I have a leaning towards more realistic lighting levels which is out of synch with folk who want "More lights on everything".
      Gotcha!
      The stairs are more commonly found on yachts and small boats and are a space saving measure. Not popular with architectural purists who will simply say that "Never get that past inspection in America, etc".
      I know, a bit like those who want fridge freezers in a kitchen boxed in for the same reason. Not doing architectural renders and NOT in America let alone actually expecting these things to be built.
      No worries, I wasn't criticizing; I was just curious about the staircase.
      Cheers,
      Thomas
        Mike Amos @pixelcruncher
        @pixelcruncher
        G'day mate,
        The monitor is set at 2560 x 1330 at the moment. Good enough for most tasks.
        No criticism taken mate, we are discussing the topic and it's all good. Just covering off the things I do rather idiosynchratically. Being a 'do things my own way' personality.
        I am getting to grips with Rayscaper, it's taking a bit of adjustment from the ol' noggin but getting there bit by bit. Well worth the time tbh.
        Something that might help the screen issue I feel is in the way would be on demand dialogue boxes to reduce screen 'clutter'.
        Mike AmosM P 2 Replies Last reply Reply Quote 0
          Mike Amos @Mike Amos
          Further on, different view. I have managed to return the walls to the previous material.6 4m 49s GPU.png
          • Bryan KB Offline
            Wow! That is well done!
              Mike Amos @Bryan K
              @Bryan-K
              Thanks mate, some mat changes and a better hdr for the scene will help.
                @Mike-Amos Very well done. I'm pleased to see you are getting good results.
                  Do you also use display scaling, or is it at 100%? Also, do other applications behave well? A screenshot might help us see how it compares to other applications.
                  Great to hear!
                  In the latest release, I'm trying to hide more things, especially if they are not enabled. But can I hide even more things? Is there any screen in particular that is bothering you?
                  Cheers,
                  Thomas
                    @pixelcruncher
                    Nothing actually 'bothers' me, the screen is reminiscent of Maxwell in most respects.
                    The hdri/texture corner is both bigger than it need to be while being too small to show much in the way of detail of the different options.
                    When it comes to it, the single screen thing is getting old but I am looking into that but clearing screen clutter when elements are not requirted would be very helpful.
                    Undocking these different parts of the Rayscaper window an placing them on =the second or third monitor would enable much more clarity for the render window itself. IMOHO, of course.
                    Mike AmosM P 2 Replies Last reply Reply Quote 1
                      @Mike-Amos
                      Movement.
                          @Mike-Amos
                          Any thoughts folks?
                            @Mike-Amos
                            Take my opinion with a grain of salt. I'm a developer, not an artist...
                            I like the interior very much; it is very realistic and uses materials well. But I find the combo of the HDR and the glass in the front door weird. It's as if the house stands in the middle of the lake.
                            Cheers,
                            Thomas
                              @Mike-Amos said in Rayscaper, My trip down the road to adjumacation.:
                              @pixelcruncher
                              That's an interesting observation; I've never used Maxell before πŸ™‚
                              Would clearer tabs help here? Or tabs at the top instead of sideways?
                              I plan to do docking/undocking, but it's a bit of work because the user interface library I am using does not support it.
                                @pixelcruncher
                                For some reason the mirror is not reflecting, suitably set up in Rayscaper, just not apparent in the render.9 17m 52s.jpg
                                  What render method are you using?
                                  Could it be the Max Depth for Approx GI need increasing if you are using Approx GI?
                                    Hey @Mike-Amos
                                    Did what @Rich-O-Brien work? If the depth is insufficient, the render engine will cut paths short before reaching a light source, and the mirror will be black.
                                    How are you creating a mirror? Using the simple mirror material or something else?
                                    You can pack up the whole scene and send it my way (via the Create Archive option). Then I can have a look.
                                    Cheers,
                                    Thomas
                                      @pixelcruncher
                                      I tried all that, pretty Elf explanatory tbh.
                                      Nada.
                                      I shall try to pm the archive file.
                                        @Mike-Amos Yup, send it my way. I will have a look.
                                          @pixelcruncher
                                          Via email.
                                            @Mike-Amos Thanks for the scene. That was helpful.
                                            The problem is that the color of the mirror is black, so it won't reflect anything:
                                            Setting the color to white (or anything non-black) will result in a mirror:
                                            Sorry, I butchered your camera setup to make it more evident that the mirror works now.
                                            Cheers,
                                            Thomas
                                            • 2 / 9
