    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 34.0k Views 7 Watching
    • pixelcruncherP
      pixelcruncher Extension Creator @Mike Amos
      The monitor is set at 2560 x 1330 at the moment. Good enough for most tasks.
      Do you also use display scaling, or is it at 100%? Also, do other applications behave well? A screenshot might help us see how it compares to other applications.
      I am getting to grips with Rayscaper, it's taking a bit of adjustment from the ol' noggin but getting there bit by bit. Well worth the time tbh.
      Great to hear!
      Something that might help the screen issue I feel is in the way would be on demand dialogue boxes to reduce screen 'clutter'.
      In the latest release, I'm trying to hide more things, especially if they are not enabled. But can I hide even more things? Is there any screen in particular that is bothering you?
      Cheers,
      Thomas
      Mike AmosM 1 Reply Last reply
        Mike Amos @pixelcruncher
        @pixelcruncher
        Nothing actually 'bothers' me, the screen is reminiscent of Maxwell in most respects.
        The hdri/texture corner is both bigger than it need to be while being too small to show much in the way of detail of the different options.
        When it comes to it, the single screen thing is getting old but I am looking into that but clearing screen clutter when elements are not requirted would be very helpful.
        Undocking these different parts of the Rayscaper window an placing them on =the second or third monitor would enable much more clarity for the render window itself. IMOHO, of course.
        Mike AmosM pixelcruncherP 2 Replies Last reply
          Mike Amos @Mike Amos
          @Mike-Amos
          Movement.
              @Mike-Amos
              Any thoughts folks?
              • pixelcruncherP
                @Mike-Amos
                Take my opinion with a grain of salt. I'm a developer, not an artist...
                I like the interior very much; it is very realistic and uses materials well. But I find the combo of the HDR and the glass in the front door weird. It's as if the house stands in the middle of the lake.
                Cheers,
                Thomas
                • pixelcruncherP
                  @Mike-Amos said in Rayscaper, My trip down the road to adjumacation.:
                  @pixelcruncher
                  That's an interesting observation; I've never used Maxell before πŸ™‚
                  Would clearer tabs help here? Or tabs at the top instead of sideways?
                  I plan to do docking/undocking, but it's a bit of work because the user interface library I am using does not support it.
                    @pixelcruncher
                    For some reason the mirror is not reflecting, suitably set up in Rayscaper, just not apparent in the render.9 17m 52s.jpg
                      What render method are you using?
                      Could it be the Max Depth for Approx GI need increasing if you are using Approx GI?
                      • pixelcruncherP
                        Hey @Mike-Amos
                        Did what @Rich-O-Brien work? If the depth is insufficient, the render engine will cut paths short before reaching a light source, and the mirror will be black.
                        How are you creating a mirror? Using the simple mirror material or something else?
                        You can pack up the whole scene and send it my way (via the Create Archive option). Then I can have a look.
                        Cheers,
                        Thomas
                          @pixelcruncher
                          I tried all that, pretty Elf explanatory tbh.
                          Nada.
                          I shall try to pm the archive file.
                          • pixelcruncherP
                            @Mike-Amos Yup, send it my way. I will have a look.
                              @pixelcruncher
                              Via email.
                              • pixelcruncherP
                                @Mike-Amos Thanks for the scene. That was helpful.
                                The problem is that the color of the mirror is black, so it won't reflect anything:
                                Setting the color to white (or anything non-black) will result in a mirror:
                                Sorry, I butchered your camera setup to make it more evident that the mirror works now.
                                Cheers,
                                Thomas
                                  @pixelcruncher
                                  Thanks, I guess the 'problem' is that the render engines I have used preferred black as the colur in Sketchup.
                                  I just defaulted to this from habit.
                                  • pixelcruncherP
                                    @pixelcruncher
                                    No worries, I'm glad we got it sorted!
                                      @pixelcruncher
                                      Moving onwards, some of the lights appear to have gone AWOL but then, so has the skirting board.......
                                      • pixelcruncherP
                                        @Mike-Amos sounds like a bug. Let's fix that.
                                        Do you mind sending me your most recent scene again?
                                        • What is the name of the light component or components that disappeared?
                                        • Is the skirting board modeled as geometry at the bottom of the wall? I will check that out as well once I have your model file.
                                        Cheers,
                                        Thomas
                                          @pixelcruncher
                                          The lights are directional lights, the skirting board is geometry that has been removed from Sketchup the model, pardon the pun.
                                          I am concerned that memory handling is an issue and will probably remain that way until the basic hardware is fixed, should go off for repair this week. Crossed fingers included.
                                            @Mike-Amos
                                            OK, replaced the missing skirting board and put the lights back. Wotcha fink folks?
                                            • 2 / 9
