    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 34.0k Views 7 Watching
      Mike Amos @Mike Amos
      Mike AmosM 1 Reply Last reply
        @Mike-Amos
        Any thoughts folks?
        • pixelcruncherP
          pixelcruncher Extension Creator @Mike Amos
          @Mike-Amos
          Take my opinion with a grain of salt. I'm a developer, not an artist...
          I like the interior very much; it is very realistic and uses materials well. But I find the combo of the HDR and the glass in the front door weird. It's as if the house stands in the middle of the lake.
          Cheers,
          Thomas
          • pixelcruncherP
            @Mike-Amos said in Rayscaper, My trip down the road to adjumacation.:
            @pixelcruncher
            Nothing actually 'bothers' me, the screen is reminiscent of Maxwell in most respects.
            That's an interesting observation; I've never used Maxell before πŸ™‚
            The hdri/texture corner is both bigger than it need to be while being too small to show much in the way of detail of the different options.
            Would clearer tabs help here? Or tabs at the top instead of sideways?
            When it comes to it, the single screen thing is getting old but I am looking into that but clearing screen clutter when elements are not requirted would be very helpful.
            Undocking these different parts of the Rayscaper window an placing them on =the second or third monitor would enable much more clarity for the render window itself. IMOHO, of course.
            I plan to do docking/undocking, but it's a bit of work because the user interface library I am using does not support it.
              Mike Amos @pixelcruncher
              @pixelcruncher
              For some reason the mirror is not reflecting, suitably set up in Rayscaper, just not apparent in the render.9 17m 52s.jpg
                What render method are you using?
                Could it be the Max Depth for Approx GI need increasing if you are using Approx GI?
                • pixelcruncherP
                  Hey @Mike-Amos
                  Did what @Rich-O-Brien work? If the depth is insufficient, the render engine will cut paths short before reaching a light source, and the mirror will be black.
                  How are you creating a mirror? Using the simple mirror material or something else?
                  You can pack up the whole scene and send it my way (via the Create Archive option). Then I can have a look.
                  Cheers,
                  Thomas
                    @pixelcruncher
                    I tried all that, pretty Elf explanatory tbh.
                    Nada.
                    I shall try to pm the archive file.
                    • pixelcruncherP
                      @Mike-Amos Yup, send it my way. I will have a look.
                        @pixelcruncher
                        Via email.
                        • pixelcruncherP
                          @Mike-Amos Thanks for the scene. That was helpful.
                          The problem is that the color of the mirror is black, so it won't reflect anything:
                          Setting the color to white (or anything non-black) will result in a mirror:
                          Sorry, I butchered your camera setup to make it more evident that the mirror works now.
                          Cheers,
                          Thomas
                            @pixelcruncher
                            Thanks, I guess the 'problem' is that the render engines I have used preferred black as the colur in Sketchup.
                            I just defaulted to this from habit.
                            • pixelcruncherP
                              @pixelcruncher
                              No worries, I'm glad we got it sorted!
                                @pixelcruncher
                                Moving onwards, some of the lights appear to have gone AWOL but then, so has the skirting board.......
                                • pixelcruncherP
                                  @Mike-Amos sounds like a bug. Let's fix that.
                                  Do you mind sending me your most recent scene again?
                                  • What is the name of the light component or components that disappeared?
                                  • Is the skirting board modeled as geometry at the bottom of the wall? I will check that out as well once I have your model file.
                                  Cheers,
                                  Thomas
                                    @pixelcruncher
                                    The lights are directional lights, the skirting board is geometry that has been removed from Sketchup the model, pardon the pun.
                                    I am concerned that memory handling is an issue and will probably remain that way until the basic hardware is fixed, should go off for repair this week. Crossed fingers included.
                                      @Mike-Amos
                                      OK, replaced the missing skirting board and put the lights back. Wotcha fink folks?
                                      • Bryan KB
                                        Overall, really nice, but I would change the light temp (seems kinds of orange-ish yellow in this shot) and up the exposure just a but more.
                                        Just a little less orange in the light. Natural light is orange-ish yellow.
                                          Mike Amos @Bryan K
                                          @Bryan-K
                                          Ta mate, feedback always helpful. Building and rendering the scene can lead to missing/ignoring stuff.
                                          Rich O BrienR pixelcruncherP Bryan KB 3 Replies Last reply
                                            @Mike-Amos If the sun coming in the window is a directional light you should raise the angle values slightly to soften the shadow.
                                            I sometime mix both HDRIs and Directional Lights to get the light the way I want it.
                                            HDRs are great but some might offer you the background you want but not the light direction or power. Adding a directional to give you more artistic controls is sometimes a good hack.
                                            Be mindful of power values and balance it.
                                            A directional light with zero angle results in crisp clean shadows...
                                            Increasing it to 2-3 will soften edges....
                                            massimoM 1 Reply Last reply
                                            • 2 / 9
