    2.2k Posts 487 Posters 931.5k Views 492 Watching
      LOAR @Rich O Brien
      @Rich-O-Brien @da800429 I had this same error, which was quite frustrating for a while. Eventually I closed all the sketchup windows I had open and only opened one model. Then the validation worked. So maybe it's something to do with multiple models being open that gets in the way of validation? Hope this helps
      • V Offline
        vitalisvitalis Newcomers
        hi,I just brought a fredo scaLE but bit aasks for license,what to do?
          Rich O Brien Moderator @vitalisvitalis
          @vitalisvitalis said in SCFLicense: Extension Licensing on Sketchucation:
          Following activation guide https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
            g_petinati
            Hi Fredo. I'm having an issue with my FREDO CORNER license.
            I get the message that "License Seats Exceeded".
            I reinstalled Sketchup, and did not release the license from the old installation. Is there a way to correct this issue?
            Thank you.
              labaruss
              Hi Fredo and others. Since I change the name of my computer the license fail of your tools. What shuld I do ? Thank you.
              fredo6F 1 Reply Last reply Reply Quote 0
                labaruss
                This post is deleted!
                • fredo6F Offline
                  fredo6 @labaruss
                  @labaruss
                  You can manage your licenses at this page, My Licenses at Sketchucation.
                    titty456
                    @Rich-O-Brien
                    I have purchased curviloft, but I encounter a problem with A04. How to solve it?
                    Fredo6 Plugins Information on 2024-05-03 18:38:51 +0800
                    • Platform: x64-mswin64_140 - Ruby: 2.7.2
                    • Sketchup: 23.0.397
                    • LibFredo6: v14.3d
                    • LibFredo6 Binary loaded
                    • Sketchucation ExtensionStore: 4.4.1
                    • SCFLicense: v6.4a - 74
                    • Fredo6 Plugins
                      Curviloft v1.9b
                      JointPushPull v4.4e
                      Signature File: 2024-05-03 18:31:59 +0800
                    TIGT 1 Reply Last reply Reply Quote 0
                      TIG Moderator @titty456
                      @titty456
                      An A04 error means it can't decode the signature file.
                      Have you tried deleting that file and redoing it again ?
                      Do you have any non-ASCII characters in your computer's user-name ?
                      In case it's a permissions issue have you installed SketchUp properly ?
                      You can 'Repair' it thus...
                      Log out of SketchUp.
                      Find the installer's exe file - usually in your Downloads folder.
                      Select the exe file's icon, right-click > context-menu > Run as administrator.
                      When prompted choose 'Repair'.
                      Reboot your computer and retry SketchUp.
                      Installing a complex app by double-clicking its icon is not the same - even if you are an admin.
                      Doing that can lead to all kinds of unpredictable issues - often relating to reading/writing files...
                        titty456
                        @TIG Thank you for your help!
                        My problem solved because my computer's name have non-ASCII characters.
                        thank you!
                          arkxell
                          Hello. I changed the name of my computer and now I can't use the paid plugins. And the problem is that I no longer remember the original name of the PC. How should I proceed?
                          • fredo6F Offline
                            fredo6 @arkxell
                            @arkxell
                            The best is to go to your My Licenses on Sketchucation page (just sign in) and release the licenses.
                            If the release seat button is not available, then tell me.
                            • X Offline
                              xxetq Newcomers
                                manoukkuijper Newcomers
                                I just bought it, why isn't it working?
                                  TIG Moderator @manoukkuijper
                                  @manoukkuijper
                                  You need to help us a bit more than this...
                                  You just bought what ?
                                  Let's assume it's a Fredo6 extension ??
                                  Have you downloaded/installed 'it' ?
                                  Have you downloaded/installed the latest LibFredo6, which it also needs ?
                                  Have you installed the SketchUcation Tools which will work the licensing code ?
                                  Have you restarted your computer to sync everything ?
                                  Have you read and understood the guidance for buying and saving your license file[s] onto your computer ?
                                  Have you tried to validate that license for the extension in it's submenu item under the Tools menu ?
                                  There's a lot you haven't told us...
                                  Please help us to help you...
                                    shamsa_amir @Gus R
                                    @Gus-R said in SCFLicense: Extension Licensing on Sketchucation:
                                    this morn
                                    hello , how can i get fredo ?
                                      TIG Moderator @shamsa_amir
                                      @shamsa_amir
                                      Fredo what ?
                                      Help us to help you.
                                      You can download Fredo's extensions from our PluginStore [Ruby icon in the top bar]
                                      Most of them will also need his FredoLib6 installing to work properly.
                                      After the installation of the downloaded RBZ files [using the native Extension Installer] you need to restart SketchUp to sync things.
                                      BUT you will also need the SketchUcation Toolset from the PluginStore installing to manage the licensing.
                                      As a beneficial side effect of having the SketchUcation Toolset installed, you can then use its ExtensionStore³ dialog to Auto-Install extensions without the download of the RBZ file...
                                      This has additional benefits, such as Update reminders and Plugin Management dialogs...
                                      • alexpacio2013A Offline
                                        alexpacio2013 @fredo6
                                        Hi cold today I have this problem with the ThruPaint license. I tried to reinstall the license but it gives me an error that it has expired and in my panel I can't find the TruPaint license. It seemed to me I seemed to have a validated Unlimited license. What should I do, thank you
                                        SketchUp_tc39P6a13x.png SketchUp_wXfxCbeaej.png SketchUp_uaaWH7gHtC.png SketchUp_dt1w5ZcuIX.png
                                        G 1 Reply Last reply Reply Quote 0
                                          Gábor @alexpacio2013
                                          @alexpacio2013 Are you sure you are trying to activate a valid ThruPaint licence? I can not see any ThruPaint licences purchased by your user.
                                          You can buy a proper ThruPaint licence Here
                                          • F Offline
                                            Fifo_78
                                            Hi everybuddy,
                                            I've purchaser and received my licenses files. I 've put them in the "AppData\Local\SCF Licenses" directory. Ok. But when I try to use the Manage License button in RoundCorner Plugin by ex, my SU2017 Freeze and I must to shutdown it! When I try to see my loaded license I find none in the Global License Status window!!
                                            Could you help please?
                                            Thanks in advance.
                                            Best regards.
                                            Fifo
                                            • 94
                                            • 95
                                            • 96
                                            • 97
                                            • 98
                                            • 109
                                            • 110
                                            • 96 / 110
