    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    103 Posts 39 Posters 127.2k Views 39 Watching
    • Rich O BrienR Online
      @ploniman said:
      it doesnt work as it should. tried several fonts but, always with little errors. see picure
      what to do?
      [attachment=0:1pr1bp40]<!-- ia0 -->Bild 22.06.22 um 08.58.jpg<!-- ia0 -->[/attachment:1pr1bp40]
      Scale the geometry so its oversized, run the tool and then scale it back down. SketchUp can struggle with forming geometry < 1mm.
      • ezyuzinE Offline
        ezyuzin Extension Creator
        Hello,
        Is it possible to create holes with specific depth in multilayer objects
        For sample, I was unable to find correct results
        using drill and carve commands
          To mimic an emboss across identical objects as per your setup could be done if the identical objects were components. Then a change in one is propagated to others.
          But to emboss multiple objects based on selection I cannot see possible with Vishole if I understand your description correctly.
          • ezyuzinE Offline
            It’s a pity that it’s impossible, it seems like a typical operation (because the plugin can punch holes through components). But I need to cut a hole of a given depth through several components
            I found another plugin (BoolTool) that does this, less convenient than this plugin. But it works
              mac13517a
              Great Plugin, I love it a LOT!!!
              I have a question: How can I remove a stencil???
              Sometime I just require upgrade the stencil or simply remove the old stencil.
              Kind regards,
              • F Offline
                faustcan
                Hello, where is the download link to Visuhole, please? I bought the licence for 8 plugins including this. Many thanks
                  Open ExtensionStore dialog in SketchUp
                  Click the Paste URL icon
                  https://i.imgur.com/glZOdES.png
                  In the input put pln=visuhole and click Install
                  https://i.imgur.com/URWwE2D.png
                  Restart SketchUp
                  • fredo6F Offline
                    NEW RELEASE: VisuHole v1.5a - 01 Apr 24
                    Requirements:
                    • LibFredo6 v14.3b
                    • Sketchucation Plugintore v4.4.0
                    VisuHole 1.5a is a maintenance release for
                    • Future compatibility
                    Home Page of VisuHole for information and Download.
                    Main post of this VisuHole thread.
                    • I Offline
                      ivansmirnov333 Newcomers
                      Visuhole.
                      Hello! I'm trying to make a hole in the selection component. What do I do wrong?
                      Screen Video: link
                      TIGT 1 Reply Last reply Reply Quote 1
                      • TIGT Online
                        TIG Moderator @ivansmirnov333
                        @ivansmirnov333
                        You give too much AND not enough information…
                        Can you explain what the carious bits are, and what you are trying to do, and preferably attached a simple SKP showing the problem, with steps if necessary - currently your movie is unclear…
                        I 1 Reply Last reply Reply Quote 0
                        • I Offline
                          ivansmirnov333 Newcomers @TIG
                          @TIG Sorry. New video with my explanations is here: link
                          SKP is attached.
                          • TIGT Online
                            @ivansmirnov333
                            This really needs @fredo6 's expertise, but as far as I can see the vertical component with the holes is nested inside a component of several pieces.
                            If you do not edit and select the appropriate context then the hole cutting doesn't occur in the component ?
                            • I Offline
                              @TIG no, nothing changes too
                              I 1 Reply Last reply Reply Quote 1
                              • I Offline
                                ivansmirnov333 Newcomers @ivansmirnov333
                                @ivansmirnov333 anyone from support is here? Why my stencils aren't save? Every time I have to make the same new ones.
                                TIGT Dave RD 2 Replies Last reply Reply Quote 0
                                • TIGT Online
                                  @ivansmirnov333
                                  Sounds like it might be a permissions issue.
                                  Perhaps @fredo6 can comment further...
                                  If you are on a PC installing SketchUp correctly or Repairing it can sometimes fix it - but @fredo6 might want you to delete one of his folders used to store things like templates...
                                  To effect a SketchUp 'Repair' do the following...
                                  Close SketchUp.
                                  Find it's installer exe file [usually in Downloads] or get afresh one downloaded.
                                  Select the exe file and right-click > context-menu > Run as administrator
                                  In the dialog that opens choose 'Repair'.
                                  When it completes restart SketchUp and retest...
                                  Installing by double clicking the exe file to 'Run' ir is not the same, even if your user-account has admin-powers - it can cause unpredictable issues with folder and file permissions etc...
                                  A Repair will not adversely affect any customization or installed extensions etc...
                                    Dave R @ivansmirnov333
                                    @ivansmirnov333 from the first post in the thread:
                                    @fredo6 said in [Plugin][$] VisuHole - v1.5a - 01 Apr 24:
                                    In the current version, Stencils must be picked in the model.
                                    This implies that your stencils must be present in the model. You could create components of your stencils and save them into a local collection.
                                    • 6 / 6
