    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 141.7k Views 39 Watching
    • B
      Buckyman
      Or do the carve first, Holes after??
      • H
        Hannahdesigns88
        When I try to download this visuhole plug in, it says its not a sketchup model and wont let me download it...or even begin to download. I have sketch up pro 2022 windows.
          Extensions cannot be opened by SketchUp. You need to use Extensions > Extension Manager to install the .RBZ file
          • BoxB
            To follow on from Rich's comment, it sounds like you have the download dialog set to 'Open with' rather than 'Save File' You need to set it to save file to get the RBZ to your computer to then get the extension manager to use it.
            • P
              ploniman
              it doesnt work as it should. tried several fonts but, always with little errors. see picure
              what to do?
              • BoxB
                Scale is the first most likely issue, how small is your model.
                Scale up by 100 and see if it works.
                  what to do?
                  [attachment=0:1pr1bp40]<!-- ia0 -->Bild 22.06.22 um 08.58.jpg<!-- ia0 -->[/attachment:1pr1bp40]
                  Scale the geometry so its oversized, run the tool and then scale it back down. SketchUp can struggle with forming geometry < 1mm.
                  • ezyuzinE
                    ezyuzin Extension Creator
                    Hello,
                    Is it possible to create holes with specific depth in multilayer objects
                    For sample, I was unable to find correct results
                    using drill and carve commands
                      To mimic an emboss across identical objects as per your setup could be done if the identical objects were components. Then a change in one is propagated to others.
                      But to emboss multiple objects based on selection I cannot see possible with Vishole if I understand your description correctly.
                      • ezyuzinE
                        It’s a pity that it’s impossible, it seems like a typical operation (because the plugin can punch holes through components). But I need to cut a hole of a given depth through several components
                        I found another plugin (BoolTool) that does this, less convenient than this plugin. But it works
                          mac13517a
                          Great Plugin, I love it a LOT!!!
                          I have a question: How can I remove a stencil???
                          Sometime I just require upgrade the stencil or simply remove the old stencil.
                          Kind regards,
                          • F
                            faustcan
                            Hello, where is the download link to Visuhole, please? I bought the licence for 8 plugins including this. Many thanks
                              Open ExtensionStore dialog in SketchUp
                              Click the Paste URL icon
                              https://i.imgur.com/glZOdES.png
                              In the input put pln=visuhole and click Install
                              https://i.imgur.com/URWwE2D.png
                              Restart SketchUp
                              • fredo6F
                                NEW RELEASE: VisuHole v1.5a - 01 Apr 24
                                Requirements:
                                • LibFredo6 v14.3b
                                • Sketchucation Plugintore v4.4.0
                                VisuHole 1.5a is a maintenance release for
                                • Future compatibility
                                Home Page of VisuHole for information and Download.
                                Main post of this VisuHole thread.
                                • I
                                  ivansmirnov333 Newcomers
                                  Visuhole.
                                  Hello! I'm trying to make a hole in the selection component. What do I do wrong?
                                  Screen Video: link
                                  TIGT 1 Reply Last reply
                                    TIG Moderator @ivansmirnov333
                                    @ivansmirnov333
                                    You give too much AND not enough information…
                                    Can you explain what the carious bits are, and what you are trying to do, and preferably attached a simple SKP showing the problem, with steps if necessary - currently your movie is unclear…
                                    I 1 Reply Last reply
                                    • I
                                      ivansmirnov333 Newcomers @TIG
                                      @TIG Sorry. New video with my explanations is here: link
                                      SKP is attached.
                                        @ivansmirnov333
                                        This really needs @fredo6 's expertise, but as far as I can see the vertical component with the holes is nested inside a component of several pieces.
                                        If you do not edit and select the appropriate context then the hole cutting doesn't occur in the component ?
                                        • I
                                          @TIG no, nothing changes too
                                          • I
                                            ivansmirnov333 Newcomers @ivansmirnov333
                                            @ivansmirnov333 anyone from support is here? Why my stencils aren't save? Every time I have to make the same new ones.
                                            TIGT Dave RD 2 Replies Last reply
                                            • 5 / 6
