    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 136.3k Views 39 Watching
    • BoxB Offline
      Scale is the first most likely issue, how small is your model.
      Scale up by 100 and see if it works.
        @ploniman said:
        it doesnt work as it should. tried several fonts but, always with little errors. see picure
        what to do?
        [attachment=0:1pr1bp40]<!-- ia0 -->Bild 22.06.22 um 08.58.jpg<!-- ia0 -->[/attachment:1pr1bp40]
        Scale the geometry so its oversized, run the tool and then scale it back down. SketchUp can struggle with forming geometry < 1mm.
        • ezyuzinE Offline
          ezyuzin Extension Creator
          Hello,
          Is it possible to create holes with specific depth in multilayer objects
          For sample, I was unable to find correct results
          using drill and carve commands
            To mimic an emboss across identical objects as per your setup could be done if the identical objects were components. Then a change in one is propagated to others.
            But to emboss multiple objects based on selection I cannot see possible with Vishole if I understand your description correctly.
            • ezyuzinE Offline
              It’s a pity that it’s impossible, it seems like a typical operation (because the plugin can punch holes through components). But I need to cut a hole of a given depth through several components
              I found another plugin (BoolTool) that does this, less convenient than this plugin. But it works
                mac13517a
                Great Plugin, I love it a LOT!!!
                I have a question: How can I remove a stencil???
                Sometime I just require upgrade the stencil or simply remove the old stencil.
                Kind regards,
                • F Offline
                  faustcan
                  Hello, where is the download link to Visuhole, please? I bought the licence for 8 plugins including this. Many thanks
                    Open ExtensionStore dialog in SketchUp
                    Click the Paste URL icon
                    https://i.imgur.com/glZOdES.png
                    In the input put pln=visuhole and click Install
                    https://i.imgur.com/URWwE2D.png
                    Restart SketchUp
                    • fredo6F Offline
                      NEW RELEASE: VisuHole v1.5a - 01 Apr 24
                      Requirements:
                      • LibFredo6 v14.3b
                      • Sketchucation Plugintore v4.4.0
                      VisuHole 1.5a is a maintenance release for
                      • Future compatibility
                      Home Page of VisuHole for information and Download.
                      Main post of this VisuHole thread.
                      • I Offline
                        ivansmirnov333 Newcomers
                        Visuhole.
                        Hello! I'm trying to make a hole in the selection component. What do I do wrong?
                        Screen Video: link
                        TIGT 1 Reply Last reply Reply Quote 1
                        • TIGT Online
                          TIG Moderator @ivansmirnov333
                          @ivansmirnov333
                          You give too much AND not enough information…
                          Can you explain what the carious bits are, and what you are trying to do, and preferably attached a simple SKP showing the problem, with steps if necessary - currently your movie is unclear…
                          I 1 Reply Last reply Reply Quote 0
                          • I Offline
                            ivansmirnov333 Newcomers @TIG
                            @TIG Sorry. New video with my explanations is here: link
                            SKP is attached.
                            • TIGT Online
                              @ivansmirnov333
                              This really needs @fredo6 's expertise, but as far as I can see the vertical component with the holes is nested inside a component of several pieces.
                              If you do not edit and select the appropriate context then the hole cutting doesn't occur in the component ?
                              • I Offline
                                @TIG no, nothing changes too
                                I 1 Reply Last reply Reply Quote 1
                                • I Offline
                                  ivansmirnov333 Newcomers @ivansmirnov333
                                  @ivansmirnov333 anyone from support is here? Why my stencils aren't save? Every time I have to make the same new ones.
                                  TIGT Dave RD 2 Replies Last reply Reply Quote 0
                                  • TIGT Online
                                    @ivansmirnov333
                                    Sounds like it might be a permissions issue.
                                    Perhaps @fredo6 can comment further...
                                    If you are on a PC installing SketchUp correctly or Repairing it can sometimes fix it - but @fredo6 might want you to delete one of his folders used to store things like templates...
                                    To effect a SketchUp 'Repair' do the following...
                                    Close SketchUp.
                                    Find it's installer exe file [usually in Downloads] or get afresh one downloaded.
                                    Select the exe file and right-click > context-menu > Run as administrator
                                    In the dialog that opens choose 'Repair'.
                                    When it completes restart SketchUp and retest...
                                    Installing by double clicking the exe file to 'Run' ir is not the same, even if your user-account has admin-powers - it can cause unpredictable issues with folder and file permissions etc...
                                    A Repair will not adversely affect any customization or installed extensions etc...
                                      Dave R @ivansmirnov333
                                      @ivansmirnov333 from the first post in the thread:
                                      @fredo6 said in [Plugin][$] VisuHole - v1.5a - 01 Apr 24:
                                      In the current version, Stencils must be picked in the model.
                                      This implies that your stencils must be present in the model. You could create components of your stencils and save them into a local collection.
                                        bobvdm
                                        It's a great app!
                                        I only have one problem on a certain surface it will not cut rectengular/square holes.
                                        Only when I rotate them it wil cut a hole.
                                        Round, oval, diamond whatever shapes seem to work ok.
                                        Do you have any idea?
                                        It was the same in al the earlier versions, now using the latest update.
                                        Many thanks in advance!
                                        Bob
                                        VisuHole_NoHole1.mp4
                                        • 5 / 6
