    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 630.3k Views 155 Watching
      rv1974
      Everything works here, maybe its your ad blocker- try DL via smart phone. Let's discuss it in PMs, not in the thread
      • BoxB Offline
        Hi Fredo
        There seems to be an issue with JPP Normal.
        It doesn't produce sides.
        This is running 2021.1.299 on Win 7 with Lib 11.9c and JPP 4.4e
        • boofredlayB Offline
          boofredlay
          I just tested it with 2018 Pro and it works fine. Must be something with the newer SU version.
          • panixiaP Offline
            panixia
            @box said:
            Hi Fredo
            That's 100% because you set "borders" to "none". πŸ‘
            • BoxB Offline
              I was sure I had checked that, in fact I'm still sure that I changed to to None while trying to make it work.
              But you are absolutely correct, as soon as I set it to Contour or Grid it works perfectly.
              Sorry Fredo, all good.
              • panixiaP Offline
                panixia
                Glad that it helped.
                • BoxB Offline
                  One for the D'oh book.
                  • panixiaP Offline
                    panixia
                    Lol! 🀣
                      @evilboris said:
                      Can anybody help, I get this error with any object using round
                      This is in SketchUp 8 as your profile indicates you are using?
                      • E Offline
                        EvilBoris
                        Can anybody help?, I get this error with any object using round
                        Date: 13-Oct-21 15:39:35
                        An error occurred in Round Push Pull
                        Error in Analysis of model
                        undefined method `normalize' for nil:NilClass
                        jointpushpullalgo.rbe: 1408 -- block in round_compute_direction
                        jointpushpullalgo.rbe: 1406 -- each
                        jointpushpullalgo.rbe: 1406 -- round_compute_direction
                        jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
                        jointpushpullalgo.rbe: 1353 -- each
                        jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
                        jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
                        jointpushpullalgo.rbe: 1111 -- each
                        jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
                        jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
                        jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
                        jointpushpulltool.rbe: 837 -- dragging_start
                        jointpushpulltool.rbe: 1527 -- onLButtonDown
                        I can do this with a new document and a cube and I get this error or in an existing model.
                        • JQLJ Offline
                          JQL
                          Cheers,
                          I just found out about JPP Thickening. I use JPP for ages and never noticed it there and now it just solved an issue I had. Great! Just great!
                          www.casca.pt
                          Visit us on facebook!
                          • fredo6F Offline
                            JPP Thickening is just Joint Push Pull without a button palette. Which issue did it solve?
                            • JQLJ Offline
                              JQL
                              I was trying to offset all faces of a surface exactly 20cm and both the regular JPP and Normal JPP failed while thickening seemed to work.
                              www.casca.pt
                              • Peter CzyP Offline
                                Peter Czy
                                Hello, I've been working with this plugin for a long time.
                                This question comes up in our German forum:
                                Almost all surfaces (objects) can be thickened.
                                Is it also possible to make an object thinner
                                without leaving the side edges and surfaces remaining? If it is possible, please write us how it works.
                                Many Thanks
                                Peter
                                • BoxB Offline
                                  One of the setting with JPP is the second face, if you untick the that then moving inward will make things 'thinner' if that's what you mean.
                                  If not, you need to show an example of what you mean.
                                    Peter Czy
                                    It's right, the objects get thinner when I push inward. However, edges and surfaces remain that have to be laboriously erased on a complicated object.
                                    I mean those edges and lines marked with red arrows.
                                    Peter
                                    • BoxB Offline
                                      Many questions, many possibilities.
                                      Can you not Scale the object or Move the face.
                                      The problem with questions like this is there is no single answer, so much depends on the shape and what you want the result to be.
                                      Attaching a model would help.
                                        Peter Czy
                                        Its only a simple testfileIt's just one question.
                                        Use Joint Push Pull to thin an object without creating edges and faces.
                                        If I just move the face, the thickness won't stay even. The same applies to scaling.
                                        • BoxB Offline
                                          Often the tool you think you need isn't, a simple offset and follow me is another way to do what you want, PP to correct the ends if necessary.
                                          The main point being that there are many ways to do things and some times it pays to think simply.
                                          https://i.imgur.com/gKWTSDP.gif
                                            Peter Czy
                                            Ok, thanks for the other option to change a model. That was of course a very simple test model.
                                            The time required for your option is similar to that of deleting these surfaces / edges according to JPP.
                                            In principle, we don't have an exact answer as to why these edges and faces remain when the object is thinned.
                                            I am sure that only the developer fredo6 can answer that.
                                            I will post this result in our German forum.
                                            Thanks again.
                                            Peter
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 30
                                            • 31
                                            • 25 / 31
