    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • BoxB
      @panixia said:
      Glad that it helped.
      One for the D'oh book.
      • panixiaP
        panixia
        Lol! 🀣
          @evilboris said:
          Can anybody help, I get this error with any object using round
          This is in SketchUp 8 as your profile indicates you are using?
          • E
            EvilBoris
            Can anybody help?, I get this error with any object using round
            Date: 13-Oct-21 15:39:35
            An error occurred in Round Push Pull
            Error in Analysis of model
            undefined method `normalize' for nil:NilClass
            jointpushpullalgo.rbe: 1408 -- block in round_compute_direction
            jointpushpullalgo.rbe: 1406 -- each
            jointpushpullalgo.rbe: 1406 -- round_compute_direction
            jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
            jointpushpullalgo.rbe: 1353 -- each
            jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
            jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
            jointpushpullalgo.rbe: 1111 -- each
            jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
            jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
            jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
            jointpushpulltool.rbe: 837 -- dragging_start
            jointpushpulltool.rbe: 1527 -- onLButtonDown
            I can do this with a new document and a cube and I get this error or in an existing model.
            • JQLJ
              JQL
              Cheers,
              I just found out about JPP Thickening. I use JPP for ages and never noticed it there and now it just solved an issue I had. Great! Just great!
              www.casca.pt
              Visit us on facebook!
              • fredo6F
                JPP Thickening is just Joint Push Pull without a button palette. Which issue did it solve?
                • JQLJ
                  JQL
                  I was trying to offset all faces of a surface exactly 20cm and both the regular JPP and Normal JPP failed while thickening seemed to work.
                  www.casca.pt
                  • Peter CzyP
                    Peter Czy
                    Hello, I've been working with this plugin for a long time.
                    This question comes up in our German forum:
                    Almost all surfaces (objects) can be thickened.
                    Is it also possible to make an object thinner
                    without leaving the side edges and surfaces remaining? If it is possible, please write us how it works.
                    Many Thanks
                    Peter
                    • BoxB
                      One of the setting with JPP is the second face, if you untick the that then moving inward will make things 'thinner' if that's what you mean.
                      If not, you need to show an example of what you mean.
                      • Peter CzyP
                        Peter Czy
                        It's right, the objects get thinner when I push inward. However, edges and surfaces remain that have to be laboriously erased on a complicated object.
                        I mean those edges and lines marked with red arrows.
                        Peter
                        • BoxB
                          Many questions, many possibilities.
                          Can you not Scale the object or Move the face.
                          The problem with questions like this is there is no single answer, so much depends on the shape and what you want the result to be.
                          Attaching a model would help.
                          • Peter CzyP
                            Peter Czy
                            Its only a simple testfileIt's just one question.
                            Use Joint Push Pull to thin an object without creating edges and faces.
                            If I just move the face, the thickness won't stay even. The same applies to scaling.
                            • BoxB
                              Often the tool you think you need isn't, a simple offset and follow me is another way to do what you want, PP to correct the ends if necessary.
                              The main point being that there are many ways to do things and some times it pays to think simply.
                              https://i.imgur.com/gKWTSDP.gif
                              • Peter CzyP
                                Peter Czy
                                Ok, thanks for the other option to change a model. That was of course a very simple test model.
                                The time required for your option is similar to that of deleting these surfaces / edges according to JPP.
                                In principle, we don't have an exact answer as to why these edges and faces remain when the object is thinned.
                                I am sure that only the developer fredo6 can answer that.
                                I will post this result in our German forum.
                                Thanks again.
                                Peter
                                • BoxB
                                  The reason the edges and faces exist is the nature of the tool, it is pushing back following the face and therefore creating extra geometry.
                                  This is not a bug of a fault in the software, it is doing what is expected.
                                  Use the undo option and jpp less.
                                    Pay attention to what is actually happening when you use JPP. It's extruding in the direction of the normals of the faces as it is designed to do. As Box indicates, it's doing what it is supposed to do even though that's not what you want. If you must use JPP to add the thickness and you want a different thickness, the easy thing to do would be to copy the original surface and run JPP to extrude to the desired thickness.
                                    • Peter CzyP
                                      Peter Czy
                                      Hello Dave and Box,
                                      Yes, I think the best option is to erase the face that has already been made too thick and recreate the reduced thickness.
                                      Thank you!
                                      Peter
                                      • javadvklJ
                                        javadvkl
                                        How can I purchase the plugin when my country is under U. S. sanctions? 😞
                                          @javadvkl said:
                                          Not much we can do about sanctions.
                                          • javadvklJ
                                            javadvkl
                                            @rich o brien said:
                                            @javadvkl said:
                                            Can you refer to a replacement for JointPushPull plugin? I've tried the classic JointPushPull already.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 30
                                            • 31
                                            • 25 / 31
