    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 916.9k Views 155 Watching
    • panixiaP Offline
      panixia
      @rv1974 said:
      some script for Max. If you could develop it for SU.. it'd have a huge advantage because
      SU allows to 'hack' the context hierarchy.
      Which script is that? Is free?
      In Max I'm able to do 99% of that stuff without any script at all just using regular editpoly edge mode (just select the loop, set "normal" constraint, extrude/scale and then pull up and down without constraints).
      But that corner options look intriguing btw.. ❓
      I did a similar request to Thomas, because I feel that normal constraint is one of the few mayor tool still missing in the QFT/VT/SubD workflow.
      Not sure this edge job is suitable for JPP itself which is more of a shell/push/face extrude tool.
      But never put limits to the Fredo power.. Maybe some normal face extrude logic is reusable on edges? πŸ˜„
        rv1974
        https://www.scriptspot.com/3ds-max/scripts/extend-borders
        Yes it'd be natural to expect tool like this from Fredo or TT. I also saw Whaat is working on all-quad Artisan 2.
        • panixiaP Offline
          panixia
          Thank you. Too bad the download link doesn't work anymore. πŸ˜•
            rv1974
            works perfectly here.
            try direct:
            https://www.racoon-artworks.de/resource_extendborders.php
            p.s. his ShapeConnect is also interesting:
            • panixiaP Offline
              panixia
              @rv1974 said:
              try direct:
              Yes, the page works, but the download button does nothing. πŸ˜•
                rv1974
                Everything works here, maybe its your ad blocker- try DL via smart phone. Let's discuss it in PMs, not in the thread
                • BoxB Offline
                  Hi Fredo
                  There seems to be an issue with JPP Normal.
                  It doesn't produce sides.
                  This is running 2021.1.299 on Win 7 with Lib 11.9c and JPP 4.4e
                  • boofredlayB Offline
                    boofredlay
                    I just tested it with 2018 Pro and it works fine. Must be something with the newer SU version.
                    • panixiaP Offline
                      panixia
                      @box said:
                      Hi Fredo
                      That's 100% because you set "borders" to "none". πŸ‘
                      • BoxB Offline
                        I was sure I had checked that, in fact I'm still sure that I changed to to None while trying to make it work.
                        But you are absolutely correct, as soon as I set it to Contour or Grid it works perfectly.
                        Sorry Fredo, all good.
                        • panixiaP Offline
                          panixia
                          Glad that it helped.
                          • BoxB Offline
                            One for the D'oh book.
                            • panixiaP Offline
                              panixia
                              Lol! 🀣
                                @evilboris said:
                                Can anybody help, I get this error with any object using round
                                This is in SketchUp 8 as your profile indicates you are using?
                                • E Offline
                                  EvilBoris
                                  Can anybody help?, I get this error with any object using round
                                  Date: 13-Oct-21 15:39:35
                                  An error occurred in Round Push Pull
                                  Error in Analysis of model
                                  undefined method `normalize' for nil:NilClass
                                  jointpushpullalgo.rbe: 1408 -- block in round_compute_direction
                                  jointpushpullalgo.rbe: 1406 -- each
                                  jointpushpullalgo.rbe: 1406 -- round_compute_direction
                                  jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
                                  jointpushpullalgo.rbe: 1353 -- each
                                  jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
                                  jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
                                  jointpushpullalgo.rbe: 1111 -- each
                                  jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
                                  jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
                                  jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
                                  jointpushpulltool.rbe: 837 -- dragging_start
                                  jointpushpulltool.rbe: 1527 -- onLButtonDown
                                  I can do this with a new document and a cube and I get this error or in an existing model.
                                  • JQLJ Offline
                                    JQL
                                    Cheers,
                                    I just found out about JPP Thickening. I use JPP for ages and never noticed it there and now it just solved an issue I had. Great! Just great!
                                    www.casca.pt
                                    Visit us on facebook!
                                    • fredo6F Offline
                                      JPP Thickening is just Joint Push Pull without a button palette. Which issue did it solve?
                                      • JQLJ Offline
                                        JQL
                                        I was trying to offset all faces of a surface exactly 20cm and both the regular JPP and Normal JPP failed while thickening seemed to work.
                                        www.casca.pt
                                        • Peter CzyP Offline
                                          Peter Czy
                                          Hello, I've been working with this plugin for a long time.
                                          This question comes up in our German forum:
                                          Almost all surfaces (objects) can be thickened.
                                          Is it also possible to make an object thinner
                                          without leaving the side edges and surfaces remaining? If it is possible, please write us how it works.
                                          Many Thanks
                                          Peter
                                          • BoxB Offline
                                            One of the setting with JPP is the second face, if you untick the that then moving inward will make things 'thinner' if that's what you mean.
                                            If not, you need to show an example of what you mean.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 30
                                            • 31
                                            • 25 / 31
