    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 951.0k Views 155 Watching
      rv1974
      works perfectly here.
      try direct:
      https://www.racoon-artworks.de/resource_extendborders.php
      p.s. his ShapeConnect is also interesting:
      • panixiaP
        panixia
        @rv1974 said:
        try direct:
        Yes, the page works, but the download button does nothing. πŸ˜•
          rv1974
          Everything works here, maybe its your ad blocker- try DL via smart phone. Let's discuss it in PMs, not in the thread
          • BoxB
            Hi Fredo
            There seems to be an issue with JPP Normal.
            It doesn't produce sides.
            This is running 2021.1.299 on Win 7 with Lib 11.9c and JPP 4.4e
            • boofredlayB
              boofredlay
              I just tested it with 2018 Pro and it works fine. Must be something with the newer SU version.
              • panixiaP
                panixia
                @box said:
                Hi Fredo
                That's 100% because you set "borders" to "none". πŸ‘
                • BoxB
                  I was sure I had checked that, in fact I'm still sure that I changed to to None while trying to make it work.
                  But you are absolutely correct, as soon as I set it to Contour or Grid it works perfectly.
                  Sorry Fredo, all good.
                  • panixiaP
                    panixia
                    Glad that it helped.
                    • BoxB
                      One for the D'oh book.
                      • panixiaP
                        panixia
                        Lol! 🀣
                          @evilboris said:
                          Can anybody help, I get this error with any object using round
                          This is in SketchUp 8 as your profile indicates you are using?
                          • E
                            EvilBoris
                            Can anybody help?, I get this error with any object using round
                            Date: 13-Oct-21 15:39:35
                            An error occurred in Round Push Pull
                            Error in Analysis of model
                            undefined method `normalize' for nil:NilClass
                            jointpushpullalgo.rbe: 1408 -- block in round_compute_direction
                            jointpushpullalgo.rbe: 1406 -- each
                            jointpushpullalgo.rbe: 1406 -- round_compute_direction
                            jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
                            jointpushpullalgo.rbe: 1353 -- each
                            jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
                            jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
                            jointpushpullalgo.rbe: 1111 -- each
                            jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
                            jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
                            jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
                            jointpushpulltool.rbe: 837 -- dragging_start
                            jointpushpulltool.rbe: 1527 -- onLButtonDown
                            I can do this with a new document and a cube and I get this error or in an existing model.
                            • JQLJ
                              JQL
                              Cheers,
                              I just found out about JPP Thickening. I use JPP for ages and never noticed it there and now it just solved an issue I had. Great! Just great!
                              www.casca.pt
                              Visit us on facebook!
                              • fredo6F
                                JPP Thickening is just Joint Push Pull without a button palette. Which issue did it solve?
                                • JQLJ
                                  JQL
                                  I was trying to offset all faces of a surface exactly 20cm and both the regular JPP and Normal JPP failed while thickening seemed to work.
                                  www.casca.pt
                                  • Peter CzyP
                                    Peter Czy
                                    Hello, I've been working with this plugin for a long time.
                                    This question comes up in our German forum:
                                    Almost all surfaces (objects) can be thickened.
                                    Is it also possible to make an object thinner
                                    without leaving the side edges and surfaces remaining? If it is possible, please write us how it works.
                                    Many Thanks
                                    Peter
                                    • BoxB
                                      One of the setting with JPP is the second face, if you untick the that then moving inward will make things 'thinner' if that's what you mean.
                                      If not, you need to show an example of what you mean.
                                      • Peter CzyP
                                        Peter Czy
                                        It's right, the objects get thinner when I push inward. However, edges and surfaces remain that have to be laboriously erased on a complicated object.
                                        I mean those edges and lines marked with red arrows.
                                        Peter
                                        • BoxB
                                          Many questions, many possibilities.
                                          Can you not Scale the object or Move the face.
                                          The problem with questions like this is there is no single answer, so much depends on the shape and what you want the result to be.
                                          Attaching a model would help.
                                          • Peter CzyP
                                            Peter Czy
                                            Its only a simple testfileIt's just one question.
                                            Use Joint Push Pull to thin an object without creating edges and faces.
                                            If I just move the face, the thickness won't stay even. The same applies to scaling.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 30
                                            • 31
                                            • 25 / 31
