    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • BoxB
      Hi Fredo
      There seems to be an issue with JPP Normal.
      It doesn't produce sides.
      This is running 2021.1.299 on Win 7 with Lib 11.9c and JPP 4.4e
      • boofredlayB
        boofredlay
        I just tested it with 2018 Pro and it works fine. Must be something with the newer SU version.
        • panixiaP
          panixia
          @box said:
          Hi Fredo
          That's 100% because you set "borders" to "none". πŸ‘
          • BoxB
            I was sure I had checked that, in fact I'm still sure that I changed to to None while trying to make it work.
            But you are absolutely correct, as soon as I set it to Contour or Grid it works perfectly.
            Sorry Fredo, all good.
            • panixiaP
              panixia
              Glad that it helped.
              • BoxB
                One for the D'oh book.
                • panixiaP
                  panixia
                  Lol! 🀣
                    @evilboris said:
                    Can anybody help, I get this error with any object using round
                    This is in SketchUp 8 as your profile indicates you are using?
                    • E
                      EvilBoris
                      Can anybody help?, I get this error with any object using round
                      Date: 13-Oct-21 15:39:35
                      An error occurred in Round Push Pull
                      Error in Analysis of model
                      undefined method `normalize' for nil:NilClass
                      jointpushpullalgo.rbe: 1408 -- block in round_compute_direction
                      jointpushpullalgo.rbe: 1406 -- each
                      jointpushpullalgo.rbe: 1406 -- round_compute_direction
                      jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
                      jointpushpullalgo.rbe: 1353 -- each
                      jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
                      jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
                      jointpushpullalgo.rbe: 1111 -- each
                      jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
                      jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
                      jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
                      jointpushpulltool.rbe: 837 -- dragging_start
                      jointpushpulltool.rbe: 1527 -- onLButtonDown
                      I can do this with a new document and a cube and I get this error or in an existing model.
                      • JQLJ
                        JQL
                        Cheers,
                        I just found out about JPP Thickening. I use JPP for ages and never noticed it there and now it just solved an issue I had. Great! Just great!
                        www.casca.pt
                        Visit us on facebook!
                        • fredo6F
                          JPP Thickening is just Joint Push Pull without a button palette. Which issue did it solve?
                          • JQLJ
                            JQL
                            I was trying to offset all faces of a surface exactly 20cm and both the regular JPP and Normal JPP failed while thickening seemed to work.
                            www.casca.pt
                            • Peter CzyP
                              Peter Czy
                              Hello, I've been working with this plugin for a long time.
                              This question comes up in our German forum:
                              Almost all surfaces (objects) can be thickened.
                              Is it also possible to make an object thinner
                              without leaving the side edges and surfaces remaining? If it is possible, please write us how it works.
                              Many Thanks
                              Peter
                              • BoxB
                                One of the setting with JPP is the second face, if you untick the that then moving inward will make things 'thinner' if that's what you mean.
                                If not, you need to show an example of what you mean.
                                • Peter CzyP
                                  Peter Czy
                                  It's right, the objects get thinner when I push inward. However, edges and surfaces remain that have to be laboriously erased on a complicated object.
                                  I mean those edges and lines marked with red arrows.
                                  Peter
                                  • BoxB
                                    Many questions, many possibilities.
                                    Can you not Scale the object or Move the face.
                                    The problem with questions like this is there is no single answer, so much depends on the shape and what you want the result to be.
                                    Attaching a model would help.
                                    • Peter CzyP
                                      Peter Czy
                                      Its only a simple testfileIt's just one question.
                                      Use Joint Push Pull to thin an object without creating edges and faces.
                                      If I just move the face, the thickness won't stay even. The same applies to scaling.
                                      • BoxB
                                        Often the tool you think you need isn't, a simple offset and follow me is another way to do what you want, PP to correct the ends if necessary.
                                        The main point being that there are many ways to do things and some times it pays to think simply.
                                        https://i.imgur.com/gKWTSDP.gif
                                        • Peter CzyP
                                          Peter Czy
                                          Ok, thanks for the other option to change a model. That was of course a very simple test model.
                                          The time required for your option is similar to that of deleting these surfaces / edges according to JPP.
                                          In principle, we don't have an exact answer as to why these edges and faces remain when the object is thinned.
                                          I am sure that only the developer fredo6 can answer that.
                                          I will post this result in our German forum.
                                          Thanks again.
                                          Peter
                                          • BoxB
                                            The reason the edges and faces exist is the nature of the tool, it is pushing back following the face and therefore creating extra geometry.
                                            This is not a bug of a fault in the software, it is doing what is expected.
                                            Use the undo option and jpp less.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 30
                                            • 31
                                            • 25 / 31
