    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • fredo6F
      @iggi,
      Can you send me the model.
      I think it has to do with the original circular profile sections, which are not generated parallel to the axes.
        rv1974
        Fredo wouldn't it be fantastic to add context-free JPP mode for edges? It would demand some smart path selection tool similar to the one in profile builder.
        http://www.scriptspot.com/files/straightencorners_cmprspd.gif
        • fredo6F
          That's a different plugin, because the extrusion is based on contour lines, not faces.
          Interesting anyway.
          Which software is it?
            rv1974
            some script for Max. If you could develop it for SU.. it'd have a huge advantage because
            SU allows to 'hack' the context hierarchy.
            • panixiaP
              panixia
              Which script is that? Is free?
              In Max I'm able to do 99% of that stuff without any script at all just using regular editpoly edge mode (just select the loop, set "normal" constraint, extrude/scale and then pull up and down without constraints).
              But that corner options look intriguing btw.. ❓
              I did a similar request to Thomas, because I feel that normal constraint is one of the few mayor tool still missing in the QFT/VT/SubD workflow.
              Not sure this edge job is suitable for JPP itself which is more of a shell/push/face extrude tool.
              But never put limits to the Fredo power.. Maybe some normal face extrude logic is reusable on edges? πŸ˜„
                rv1974
                https://www.scriptspot.com/3ds-max/scripts/extend-borders
                Yes it'd be natural to expect tool like this from Fredo or TT. I also saw Whaat is working on all-quad Artisan 2.
                • panixiaP
                  panixia
                  Thank you. Too bad the download link doesn't work anymore. πŸ˜•
                    rv1974
                    works perfectly here.
                    try direct:
                    https://www.racoon-artworks.de/resource_extendborders.php
                    p.s. his ShapeConnect is also interesting:
                    • panixiaP
                      panixia
                      @rv1974 said:
                      try direct:
                      Yes, the page works, but the download button does nothing. πŸ˜•
                        rv1974
                        Everything works here, maybe its your ad blocker- try DL via smart phone. Let's discuss it in PMs, not in the thread
                        • BoxB
                          Hi Fredo
                          There seems to be an issue with JPP Normal.
                          It doesn't produce sides.
                          This is running 2021.1.299 on Win 7 with Lib 11.9c and JPP 4.4e
                          • boofredlayB
                            boofredlay
                            I just tested it with 2018 Pro and it works fine. Must be something with the newer SU version.
                            • panixiaP
                              panixia
                              @box said:
                              Hi Fredo
                              That's 100% because you set "borders" to "none". πŸ‘
                              • BoxB
                                I was sure I had checked that, in fact I'm still sure that I changed to to None while trying to make it work.
                                But you are absolutely correct, as soon as I set it to Contour or Grid it works perfectly.
                                Sorry Fredo, all good.
                                • panixiaP
                                  panixia
                                  Glad that it helped.
                                  • BoxB
                                    One for the D'oh book.
                                    • panixiaP
                                      panixia
                                      Lol! 🀣
                                        @evilboris said:
                                        Can anybody help, I get this error with any object using round
                                        This is in SketchUp 8 as your profile indicates you are using?
                                        • E
                                          EvilBoris
                                          Can anybody help?, I get this error with any object using round
                                          Date: 13-Oct-21 15:39:35
                                          An error occurred in Round Push Pull
                                          Error in Analysis of model
                                          undefined method `normalize' for nil:NilClass
                                          jointpushpullalgo.rbe: 1408 -- block in round_compute_direction
                                          jointpushpullalgo.rbe: 1406 -- each
                                          jointpushpullalgo.rbe: 1406 -- round_compute_direction
                                          jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
                                          jointpushpullalgo.rbe: 1353 -- each
                                          jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
                                          jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
                                          jointpushpullalgo.rbe: 1111 -- each
                                          jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
                                          jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
                                          jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
                                          jointpushpulltool.rbe: 837 -- dragging_start
                                          jointpushpulltool.rbe: 1527 -- onLButtonDown
                                          I can do this with a new document and a cube and I get this error or in an existing model.
                                          • JQLJ
                                            JQL
                                            Cheers,
                                            I just found out about JPP Thickening. I use JPP for ages and never noticed it there and now it just solved an issue I had. Great! Just great!
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 30
                                            • 31
                                            • 25 / 31
