    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • panixiaP
      panixia
      @rv1974 said:
      try direct:
      Yes, the page works, but the download button does nothing. πŸ˜•
        rv1974
        Everything works here, maybe its your ad blocker- try DL via smart phone. Let's discuss it in PMs, not in the thread
        • BoxB
          Hi Fredo
          There seems to be an issue with JPP Normal.
          It doesn't produce sides.
          This is running 2021.1.299 on Win 7 with Lib 11.9c and JPP 4.4e
          • boofredlayB
            boofredlay
            I just tested it with 2018 Pro and it works fine. Must be something with the newer SU version.
            • panixiaP
              panixia
              @box said:
              Hi Fredo
              That's 100% because you set "borders" to "none". πŸ‘
              • BoxB
                I was sure I had checked that, in fact I'm still sure that I changed to to None while trying to make it work.
                But you are absolutely correct, as soon as I set it to Contour or Grid it works perfectly.
                Sorry Fredo, all good.
                • panixiaP
                  panixia
                  Glad that it helped.
                  • BoxB
                    One for the D'oh book.
                    • panixiaP
                      panixia
                      Lol! 🀣
                        @evilboris said:
                        Can anybody help, I get this error with any object using round
                        This is in SketchUp 8 as your profile indicates you are using?
                        • E
                          EvilBoris
                          Can anybody help?, I get this error with any object using round
                          Date: 13-Oct-21 15:39:35
                          An error occurred in Round Push Pull
                          Error in Analysis of model
                          undefined method `normalize' for nil:NilClass
                          jointpushpullalgo.rbe: 1408 -- block in round_compute_direction
                          jointpushpullalgo.rbe: 1406 -- each
                          jointpushpullalgo.rbe: 1406 -- round_compute_direction
                          jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
                          jointpushpullalgo.rbe: 1353 -- each
                          jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
                          jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
                          jointpushpullalgo.rbe: 1111 -- each
                          jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
                          jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
                          jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
                          jointpushpulltool.rbe: 837 -- dragging_start
                          jointpushpulltool.rbe: 1527 -- onLButtonDown
                          I can do this with a new document and a cube and I get this error or in an existing model.
                          • JQLJ
                            JQL
                            Cheers,
                            I just found out about JPP Thickening. I use JPP for ages and never noticed it there and now it just solved an issue I had. Great! Just great!
                            www.casca.pt
                            Visit us on facebook!
                            • fredo6F
                              JPP Thickening is just Joint Push Pull without a button palette. Which issue did it solve?
                              • JQLJ
                                JQL
                                I was trying to offset all faces of a surface exactly 20cm and both the regular JPP and Normal JPP failed while thickening seemed to work.
                                www.casca.pt
                                • Peter CzyP
                                  Peter Czy
                                  Hello, I've been working with this plugin for a long time.
                                  This question comes up in our German forum:
                                  Almost all surfaces (objects) can be thickened.
                                  Is it also possible to make an object thinner
                                  without leaving the side edges and surfaces remaining? If it is possible, please write us how it works.
                                  Many Thanks
                                  Peter
                                  • BoxB
                                    One of the setting with JPP is the second face, if you untick the that then moving inward will make things 'thinner' if that's what you mean.
                                    If not, you need to show an example of what you mean.
                                    • Peter CzyP
                                      Peter Czy
                                      It's right, the objects get thinner when I push inward. However, edges and surfaces remain that have to be laboriously erased on a complicated object.
                                      I mean those edges and lines marked with red arrows.
                                      Peter
                                      • BoxB
                                        Many questions, many possibilities.
                                        Can you not Scale the object or Move the face.
                                        The problem with questions like this is there is no single answer, so much depends on the shape and what you want the result to be.
                                        Attaching a model would help.
                                        • Peter CzyP
                                          Peter Czy
                                          Its only a simple testfileIt's just one question.
                                          Use Joint Push Pull to thin an object without creating edges and faces.
                                          If I just move the face, the thickness won't stay even. The same applies to scaling.
                                          • BoxB
                                            Often the tool you think you need isn't, a simple offset and follow me is another way to do what you want, PP to correct the ends if necessary.
                                            The main point being that there are many ways to do things and some times it pays to think simply.
                                            https://i.imgur.com/gKWTSDP.gif
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 30
                                            • 31
                                            • 25 / 31
