    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.2m Views 120 Watching
    • fredo6F
      If you installed Twilight and it is a compatible version, it should automatically appear in the list of Rendering software in Animator.
      Can you run Twilight in Sketchup (independently of Animator)?
      Can you give me the version of Twilight.
        jerrylambe
        Hi All,
        Ref: macOS Sonoma 14.2.1 (23C71)
        After Mac (Studio) update along with macOS Sonoma 14.2.1 I can’t seem to get FFmpeg to load, to create videos within Animator. Would rather record inside SU than using screen record etc. Would appreciate any help/ideas? > Love this pLugin.
        Many Thanks,
        Jerry
          rown2000
          is Twilight Render V2, Hobby, x64 for Windows. it´s a free version
          • fredo6F
            There may be a new version of FFmpeg compatible with Sonoma, as this upgrade of MacOS is causing several problems in many software, including Sketchup. Did you download and install a recent version, marked compatible?
            I'll check on my side when I have time, although I did not upgrade to Sonoma.
              jerrylambe
              I think I downloaded the latest version not 100% certain and not sure if it was Sonoma friendly? Doing several presentations (using Animator) at the moment and getting by with Screen Recording - so no rush. Many thanks!
              N 1 Reply Last reply
              • N
                nick2196 @jerrylambe
                Is there a way to save the frames as jpg instead of png? I am rendering using vray, and saving as png does not save the background information. I am hoping the animation could show the background so I can show how the exterior looks thru windows.
                • fredo6F
                  New Release: Animator - v4.0a - 02 Apr 24
                  Requirement: LibFredo6 v14.3b
                  Animator 4.0a is a maintenance release for:
                  • Future compatibility
                  See plugin home page of Animator for Download of RBZ from the PluginStore.
                  See Main Post of the Animator thread for more information.
                  J R Rich O BrienR 3 Replies Last reply
                    jerrylambe @fredo6
                    @fredo6 Surperb News! Many Thanks Fredo.
                      rown2000 @fredo6
                      @fredo6
                      ¿es compatible con SU 2024?
                        Rich O Brien Moderator @fredo6
                        [Plugin Beta] Animator - v4.0a - 02 Apr 24:
                        The future is now the present
                          rown2000
                          Is it possible to add the free version of Twilight Render to the list of rendering software? this would be incredible
                          The more I use it, the more I think this software is the best in sketchup.
                          Thanks fredo
                          ntxdaveN 1 Reply Last reply
                          • ntxdaveN
                            ntxdave @rown2000
                            @rown2000
                            Since Twilight Render is going away it would also be neat if you could add Rayscaper to the list.
                            Press F1...thank me later
                            fredo6F 1 Reply Last reply
                            • fredo6F
                              fredo6 @ntxdave
                              @ntxdave said in [Plugin Beta] Animator - v4.0a - 02 Apr 24:
                              @rown2000
                              I have to investigate if Rayscaper offers an API....
                              R ntxdaveN 2 Replies Last reply
                                rown2000 @fredo6
                                @fredo6
                                And wouldn't twight light be easier to add to the already existing pro version?
                                • ntxdaveN
                                  ntxdave @fredo6
                                  @fredo6 I think @pixelcruncher is going to contact you. I have suggested it to him and I saw a response in another thread where he said he was going to contact you. 👍
                                  • V
                                    VD20
                                    Hi, I am using animator on SU2024, for a landscape project, and I have made several films each of which contains clips of about 8 to 15 seconds.
                                    The issue I am having is, that I am not able to render frames or video clips of all the films in one go overnight.
                                    Every film has to be given separate command to render.
                                    So am I missing something or this function of rendering all films in one go is not there at all?
                                    V 2 Replies Last reply
                                    • V
                                      VD20 @VD20
                                      @VD20
                                      So as a temporary remedy, I started up 3 instances of SketchUp with the same file loaded and rendered different clips at the same time to save time.
                                      I hope @fredo6 comes up with a solution for this.
                                      link text
                                      This is the project I completed for the time being to show a concept.
                                      • C
                                        Calcifer
                                        Hello Fredo,
                                        Thank you again for the plugin. Regarding the output of images / render: I am currently working on a very heavy project with complex elements. I found a way to work around the restrictions on exporting directly with Vray, although very time consuming: I group all the moving parts, then copy paste each position (through the positioner) into a new file. I end up with a lot of scenes, one for each frame and the non moving parts are on a different layer. I litteraly can see the animation as going through each scene. Obviously, at this point, the animation is ''locked''.
                                        The major advantage with that is that I can use GPU render, can use render elements on V-Ray etc...
                                        My question is: would it be possible to automate that process, create an option to export all the moving parts in different scene. I understand it can create hundreds if not thousands of scenes but it would be so helpful.
                                        I can imagine there would be a technical limit (like, exporting 200 scenes max). Then it would require to create multiple files (one for scenes 001 to 200, then 201 to 400 etc), but in theory, such an option would be fantastic.
                                        Thank you!
                                        • Rich O BrienR Rich O Brien referenced this topic on
                                        • fredo6F
                                          Animator 4.1a is a maintenance release for:
                                          • Extension of Validity
                                          • fredo6F
                                            New Release: Animator - v4.2a - 28 Feb 25
                                            Requirement: LibFredo6 v15.1a
                                            Animator 4.2a is a major release for:
                                            • improvements of Video Generation
                                            • some bug fixing
                                            You can now interrupt a video generation to finish it later.
                                            Simarly, if the video generation is interrupted by a crash (or freeze) of Sketchup or the rendering software, you can resume the video generation from the last frames processed. No need to generate all frames again.
                                            See this video for more details.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 25 / 30
