    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.2m Views 120 Watching
      rown2000 @fredo6
      @fredo6
      ΒΏes compatible con SU 2024?
        Rich O Brien Moderator @fredo6
        [Plugin Beta] Animator - v4.0a - 02 Apr 24:
        Animator 4.0a is a maintenance release for:
        Future compatibility
        The future is now the present
          rown2000
          Is it possible to add the free version of Twilight Render to the list of rendering software? this would be incredible
          The more I use it, the more I think this software is the best in sketchup.
          Thanks fredo
          ntxdaveN 1 Reply Last reply
          • ntxdaveN
            ntxdave @rown2000
            @rown2000
            Since Twilight Render is going away it would also be neat if you could add Rayscaper to the list.
            Press F1...thank me later
            fredo6F 1 Reply Last reply
            • fredo6F
              fredo6 @ntxdave
              @ntxdave said in [Plugin Beta] Animator - v4.0a - 02 Apr 24:
              @rown2000
              I have to investigate if Rayscaper offers an API....
              R ntxdaveN 2 Replies Last reply
                rown2000 @fredo6
                @fredo6
                And wouldn't twight light be easier to add to the already existing pro version?
                • ntxdaveN
                  ntxdave @fredo6
                  @fredo6 I think @pixelcruncher is going to contact you. I have suggested it to him and I saw a response in another thread where he said he was going to contact you. πŸ‘
                  • V
                    VD20
                    Hi, I am using animator on SU2024, for a landscape project, and I have made several films each of which contains clips of about 8 to 15 seconds.
                    The issue I am having is, that I am not able to render frames or video clips of all the films in one go overnight.
                    Every film has to be given separate command to render.
                    So am I missing something or this function of rendering all films in one go is not there at all?
                    V 2 Replies Last reply
                    • V
                      VD20 @VD20
                      @VD20
                      So as a temporary remedy, I started up 3 instances of SketchUp with the same file loaded and rendered different clips at the same time to save time.
                      I hope @fredo6 comes up with a solution for this.
                      link text
                      This is the project I completed for the time being to show a concept.
                      • C
                        Calcifer
                        Hello Fredo,
                        Thank you again for the plugin. Regarding the output of images / render: I am currently working on a very heavy project with complex elements. I found a way to work around the restrictions on exporting directly with Vray, although very time consuming: I group all the moving parts, then copy paste each position (through the positioner) into a new file. I end up with a lot of scenes, one for each frame and the non moving parts are on a different layer. I litteraly can see the animation as going through each scene. Obviously, at this point, the animation is ''locked''.
                        The major advantage with that is that I can use GPU render, can use render elements on V-Ray etc...
                        My question is: would it be possible to automate that process, create an option to export all the moving parts in different scene. I understand it can create hundreds if not thousands of scenes but it would be so helpful.
                        I can imagine there would be a technical limit (like, exporting 200 scenes max). Then it would require to create multiple files (one for scenes 001 to 200, then 201 to 400 etc), but in theory, such an option would be fantastic.
                        Thank you!
                        • Rich O BrienR Rich O Brien referenced this topic on
                        • fredo6F
                          New Release: Animator - v4.0a - 02 Apr 24
                          Requirement: LibFredo6 v14.3b
                          Animator 4.1a is a maintenance release for:
                          • Extension of Validity
                          See plugin home page of Animator for Download of RBZ from the PluginStore.
                          See Main Post of the Animator thread for more information.
                          • fredo6F
                            New Release: Animator - v4.2a - 28 Feb 25
                            Requirement: LibFredo6 v15.1a
                            Animator 4.2a is a major release for:
                            • improvements of Video Generation
                            • some bug fixing
                            You can now interrupt a video generation to finish it later.
                            Simarly, if the video generation is interrupted by a crash (or freeze) of Sketchup or the rendering software, you can resume the video generation from the last frames processed. No need to generate all frames again.
                            See this video for more details.
                            • O
                              Ollie12345 Newcomers
                              Is there any way of getting V-ray cloud rendering to be compatible with the Animator plugin?
                              • fredo6F
                                Not in current version.
                                But I finished to implement both Batch mode and Cloud mode and will publish soon a new version of Animator. Actually, I just need to have the team from Chaos clarify a few points.
                                • fredo6F
                                  New Release: Animator - v4.3a - 15 Mar 25
                                  Requirement: LibFredo6 v15.2a
                                  Animator 4.3a is a major release for:
                                  • Introduction of Batch and Cloud mode for VRay rendering
                                  • some bug fixing
                                  The rendering with VRay has 2 additional modes
                                  • Batch: This allows to register the frames and generate them in Batch, which is slightly faster and allow to continue working in Sketchup.
                                  • Cloud: Automate the submission of the animation to Chaos Cloud web site. When, the job is completed, just finish the process to generate the video file(s).
                                  • fredo6F
                                    New Release: Animator - v4.3d - 17 Mar 25
                                    Animator 4.3d is a maintenance release for:
                                    • Bug fixing for VRay rendering
                                      jamesmeng
                                      hi I installed the animator latest version, and open it why it have note that let me to update the newest version of animator?
                                      • fredo6F
                                        Can you be more precise on the message.
                                        • B
                                          bahman00 Newcomers
                                          @fredo6 said in [Plugin Beta] Animator - v4.3d - 17 Mar 25:
                                          hi to all
                                          this version expire 31may25
                                          when appear new trial?
                                            jamesmeng
                                            I already installed the newest version of Animator V4.3D, When I try to open it, it said " this version of animator has expired please upgrade to the latest version....." I open the link of sketchucation, but it is still for V4.3D download. however I already install it.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 26 / 30
