    NEW Forum Software Issues
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    78 Posts 17 Posters 16.5k Views 19 Watching
      Rich O Brien Moderator @gullfo
      @gullfo I am thinking we stick it in here...
      alt text
      Discreet and easily accessible. Hopefully as easy to do as it is to type it. 🙄
      Gus RG 1 Reply Last reply
      • Gus RG
        Gus R @Rich O Brien
        @Rich-O-Brien
        This is funny.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
          @Gus-R I've now downvoted your post and if others follow suit we can make that post more controversial than the previous. Stacking controversy on controversy....😵
          • Gus RG
            Gus R @Rich O Brien
            @Rich-O-Brien 👾
            • alsomarA
              alsomar Extension Creator @gullfo
              @gullfo said in NEW Forum Software Issues:
              ok, that did it - adding 3 posts enabled the signature and site link options.
              Good to know, thank you!
              Alejandro Soriano Visuals · All my links
              • orgelfO
                orgelf
                Hello,
                as Gàbo (sorry I don't have the good accent on the a on my keyboard) asked me , I post my problem here.
                I have a topic here https://community.sketchucation.com/topic/150841/orgelf-s-works-second-topic/579 . Today, about 3 hours ago, I wanted to post some pictures but after some uploads I had an error message
                Error message
                And even if I tried to post another message , I had the same error message.
                I tried again few minutes ago, I could upload about 10 pictures and I had the same error message again.
                Hope this will help. Bye
                http://www.orgelf.com
                  I know I am not 100% but this thing is driving me batt schlits.
                  Is there a method of modifying the appearance of this forum please?
                    @Mike-Amos What exactly are you unhappy with?
                    Mike AmosM 1 Reply Last reply
                      Mike Amos @Rich O Brien
                      @Rich-O-Brien
                      Not unhappy per se, just older and a bit inflexible. Ity will take a while to get to grips with.
                      I cannot find anything as easily as the old forum and the appearance is just weird to my eyes, no borders to break up the page for example.
                      Doubtless when the old grey cell sorts it out it will be fine just a bit of a shock tbh.
                      Reply Quote 3
                      • G
                        Gábor @orgelf
                        @orgelf Hi,
                        Thank you for describing the problem. Based on what you wrote, I think you might had bumped into one of the forum's limitations.
                        The limitation settings for images currently are:
                        • Max image size: 10000 KiB
                        • Max image width X height: 5000 X 5000 pixels
                        • Max upload rate: 10 images per minute
                        Is it possible you reached one of these limits the other day?
                        These are in place to prevent spam.
                        orgelfO 1 Reply Last reply
                          @Mike-Amos The current vibe is a skeleton which we will improve over time.
                          There's many aspects that I am not a fan of either. But the previous was too old and had many security issues we needed to constantly patch. This is huge improvement over that.
                          Once we get a handle on the current quirks we are seeing then we can start polishing.
                          Reply Quote 3
                          • orgelfO
                            orgelf @Gábor
                            @Gábor said in NEW Forum Software Issues:
                            @orgelf Hi,
                            yes, the 10 pictures per minute limitation. thanks
                            majidM 1 Reply Last reply
                            • majidM
                              majid @orgelf
                              Does the new
                              design work well on cellphones/tablets?
                                Rich O Brien Moderator @majid
                                @majid looks like this on iPhone XR
                                • majidM
                                  majid @Rich O Brien
                                  @Rich-O-Brien And what about answering a post on cellphone?
                                    @majid I'm replying from my phone with this
                                    • majidM
                                      majid @Rich O Brien
                                      • majidM
                                        majid @majid
                                        I have no access to "other languages" sub forums.
                                        How may I and if there is a plan to get them back?
                                        • Dan RathbunD
                                          Dan Rathbun
                                          The migration to the new software has broken all the code snippets (both inline and code blocks.)
                                          Punctuation characters have been replaced with HTML Character entity codes.
                                          So, this new forum uses markdown instead of bbCode ?
                                          I'm not here much anymore.
                                          TIGT 1 Reply Last reply
                                            TIG Moderator @Dan Rathbun
                                            @Dan-Rathbun
                                            Thanks for the info, but we all ready know that, and @Gábor is working on a fix for it...
                                            Currently new posts are unaffected, but any existing posts containing 'code'/'ruby' snippets are FUBAR!
                                            Dan RathbunD 1 Reply Last reply
                                            • 3 / 4
