Did you try setting Offset to Strict?
Well it looks like I got some better results! I gave that a try, and everything looks a fair bit more equal now.
It's not perfect however. The points between the two sides on the top and the bottom are slightly off.
But I suppose in the grand scheme of things it doesn't matter that much. I still wonder what might be causing the inaccuracy though.Thank you for the tip!
The angles between the faces are different so the lengths of the curves would be different. You can see that more easily when the angles between are more different.
I expect you would have an easier time modeling this thing if you do so with the thing at a larger size.
I'm afraid I don't fully understand which lines you are referring to that have different angles. Are you talking about the yellow lines, green lines, or blue lines?
I'm referring to the angle between the triangular faces above the "belt" and the angle between the trapezoidal faces below the belt. They are different so the arc lengths will be different. I tried to simplify the illustration but making a 3D thing instead of a 3D object.
Ohhh gotcha. Yeah unfortunately there isn't much I can do about that since I can't change the angles of anything since it's based on a design someone else made. I'll just have to live with it.
Thank you for your time!
Yep. You'll have to blame Euclid or one of those other old dead guys who invented Geometry.
Morning, just a quick question ..
I purchased JPP only yesterday, but realised I should have bought the bundle - great value!
Is there any way of paying the difference so I can get the bundle rather than paying $12 + $40.
I understand this is my fault but just thought it was worth the question.
Many thanks.
@leedeetee it is easier for us to refund and then you buy what you need.
just send us an email support@sketchucation.com
@Rich-O-Brien said in [Plugin][$] RoundCorner - v3.3a - 18 Dec 18:
Thanks Rich, will do that now. Thanks very much.
Lee
NEW RELEASE: RoundCorner v3.4a - 31 Mar 24
Requirement: LibFredo6 v14.3b or above
RoundCorner 3.4a is a maintenance release for future compatibility
Home Page of RoundCorner for information and Download.
Hello,
I'm using the free license of RoundCorner and I have an issue I dont understand how to fix.
When I select the inside edges of this object, it just bridges/fills the entire hole even if I try just to round a single edge that's inside the "hole". Why is that?
@raptorscream Hi, this is a normal behaviour for RoundCorner in some circumstances. For example when you bevel coplanar edges that are a closed loop or part of it. I guess because the plugin somehow "erases" and then "draws" again some lines in the process. This causes Sketchup to automatically generate a face.
Just select and delete the unwanted surface.
