    Rayscaper Alpha Version Available
    114 Posts 14 Posters 4.4k Views 14 Watching
      Here's an interior render of a guggenheim-ish type scene...
      Rayscaper is still earlier in development so I'm reluctant to push it. It does have certain shading artifacts that I've let Thomas know about.
      But overall I think it's very capable. I love the Polyhaven integration.
      • soloS Offline
        Is there a shadow catcher material?
        • ntxdaveN Offline
          ntxdave
          Thanks Rich. I as hoping for something like a room or office setting but I understand that it is early in the cycle. Wish it would work with SU 2020.
          Press F1...thank me later
          • P Online
            Not yet, but it's planned, should be there in a couple of weeks.
            Here's the planned road map for 1.0: https://rayscaper.com/docs/roadmap/
            Cheers,
            Thomas
            • ntxdaveN Offline
              ntxdave
              Thanks for sharing the release plans. πŸ‘ πŸ‘
              Just hoping I will be able to use with SU 2020 and that it will be something I can afford. πŸ˜„
              • P Online
                Yes, I'm looking into supporting SU2020. It will be part of one of the upcoming releases.
                And yes, I plan to offer great software that everyone can afford. Of course with a discount for premium members.
                Cheers,
                Thomas
                  pc10pc Newcomers
                  I'm on SU 21.1.332 and having the same issues with toolbar not showing up.
                  • P Online
                    @pc10pc said:
                    Could you check if you can get it via these instructions? If that doesn’t help, send me a private message.
                    Cheers,
                    Thomas
                    • majidM Offline
                      majid
                      I watched your YouTube video and seems the engine is great. Just installed and seems I have a problem. Maybe because I have no SCF plugin toolbar installed.
                      PS: it solved, I installed the SCF plugin and now I have the Rayscraper!
                      • majidM Offline
                        majid
                        It works charmingly!
                          I'd love to see you try this on it....
                          https://sketchucation.com/forums/viewtopic.php?f=81&t=76396&p=693038#p692999
                          • majidM Offline
                            majid
                            Okay Rich,... I am working on it... πŸ‘ 13% progress..
                            • majidM Offline
                              majid
                              29% without any denoising and I believe it is good enough.
                              I stopped it on 49% progress and it seems good (despite without any denoising)
                              49% progress
                              • P Online
                                It's great to see a talented artist like you taking an interest in Rayscaper! I saw you sent me some feedback, so I will go and digest that.
                                Cheers,
                                Thomas
                                • jo-keJ Offline
                                  jo-ke
                                  due to the sunset of twilghtrender I stumbled across this new alternative.
                                  downloaded and licensed it today.
                                  looks promissing....
                                  http://www.zz7.de
                                  • jo-keJ Offline
                                    jo-ke
                                    Is there a tutorial for glass and emitter materials?
                                    http://www.zz7.de
                                      It has a Glass shader in the Material Type dropdown[1]
                                      https://i.imgur.com/fijdO8c.png
                                      and for the Disney shader you can enable Emmission for geometry[2]
                                      • jo-keJ Offline
                                        jo-ke
                                        Thank you: glas, is solved.
                                        emitter not. with "blackbody emission" I don't get the submenu
                                        also hidden layers are rendered. how can I avoid this?
                                        http://www.zz7.de
                                        • P Online
                                          You should be able to to open the submenu by clicking the chevron or text (1). You can expand everything by clicking the plus button (2):
                                          Hidden objects / tags / layers isn't supported yet in the alpha version. It will be there for the 1.0 version.
                                          Cheers,
                                          Thomas
                                          • jo-keJ Offline
                                            jo-ke
                                            thank you. I didn't see this. solutions are so simple....
                                            next problems:
                                            is it possible to do an emitter with textures? like in my example the sign of the tramway?
                                            why can't I get rid of the blue textures? they are textured in SU and all faces are frontfaces
                                            http://www.zz7.de
                                            • 2 / 6
