    Rayscaper Alpha Version Available
    114 Posts 14 Posters 21.8k Views 14 Watching
    • ntxdaveN
      ntxdave
      Thanks for the feedback. I thought I had done something wrong. 2020 is the latest version I have and Rich's model was 2020 so I expected everything to go smoothly. πŸ˜„
      BTW: When I comes time to document the plugin, I would suggest you look at [ur=https://skatter.help.lindale.io/getting-startedl]Skatter Help[/url]. They have a great (IMO) site for learning how to used the features of their plugin. πŸ˜„
      Press F1...thank me later
      • ntxdaveN
        ntxdave
        I just saw your documentation on the Rayscaper website. You can ignore my documentation comment in my previous post. I think it is headed in a great direction. πŸ˜„ Rayscaper Documentation
        Even though it is still a work in progress, you should have them post a link to it on the SketchUcation plugin page. It would let potential users see where you are headed.
        • ntxdaveN
          ntxdave
          On yesterday's post, I should have also included the SketchUp View>Toolbars window that showed that Rayscaper also did not show up there as an option. I am sure you know (found it out) as well but I am showing it here incase others may also be trying it. πŸ˜„
          • pixelcruncherP
            BTW: When I comes time to document the plugin, I would suggest you look at Skatter Help. They have a great (IMO) site for learning how to used the features of their plugin. πŸ˜„
            Edit I would also suggest that you check back to 2017. I see a number of users on this forum that are still using 2017. I would also suggest you post an interior and an exterior render. πŸ˜„
            Hey Dave,
            I figured out that supporting SU2020 requires another Rayscaper build (because it requires re-compilation against a different Ruby version). This is a bit more work, can you try it out with SU2021 or higher?
            Thanks for the pointer to the Skatter docs, that's indeed great documentation. As you already noticed, I started creating my own documentation here: https://rayscaper.com/docs/
            Yeah, I should post more renders, the problem is that I am not an artist/creator. So my strategy is to keep fixing bugs and making improvements until someone comes along and finds it good enough to create a good render πŸ˜‰
            Regards,
            Thomas
            • ntxdaveN
              ntxdave
              @pixelcruncher said:
              @ntxdave said:
              Hey Dave,
              No, 2020 is the latest version I have.
                https://i.imgur.com/4TfqTPi.png
                • ntxdaveN
                  ntxdave
                  Nice Rich πŸ‘
                  Do you have an interior and/or exterior model that you could render and post in this thread?
                    Here's an interior render of a guggenheim-ish type scene...
                    Rayscaper is still earlier in development so I'm reluctant to push it. It does have certain shading artifacts that I've let Thomas know about.
                    But overall I think it's very capable. I love the Polyhaven integration.
                    • soloS
                      Is there a shadow catcher material?
                      • ntxdaveN
                        ntxdave
                        Thanks Rich. I as hoping for something like a room or office setting but I understand that it is early in the cycle. Wish it would work with SU 2020.
                        • pixelcruncherP
                          Not yet, but it's planned, should be there in a couple of weeks.
                          Here's the planned road map for 1.0: https://rayscaper.com/docs/roadmap/
                          Cheers,
                          Thomas
                          • ntxdaveN
                            ntxdave
                            Thanks for sharing the release plans. πŸ‘ πŸ‘
                            Just hoping I will be able to use with SU 2020 and that it will be something I can afford. πŸ˜„
                            • pixelcruncherP
                              Yes, I'm looking into supporting SU2020. It will be part of one of the upcoming releases.
                              And yes, I plan to offer great software that everyone can afford. Of course with a discount for premium members.
                              Cheers,
                              Thomas
                              • P
                                pc10pc Newcomers
                                I'm on SU 21.1.332 and having the same issues with toolbar not showing up.
                                • pixelcruncherP
                                  @pc10pc said:
                                  Could you check if you can get it via these instructions? If that doesn’t help, send me a private message.
                                  Cheers,
                                  Thomas
                                  • majidM
                                    majid
                                    I watched your YouTube video and seems the engine is great. Just installed and seems I have a problem. Maybe because I have no SCF plugin toolbar installed.
                                    PS: it solved, I installed the SCF plugin and now I have the Rayscraper!
                                    • majidM
                                      majid
                                      It works charmingly!
                                        I'd love to see you try this on it....
                                        403 Forbidden
                                        (sketchucation.com)
                                        • majidM
                                          majid
                                          403 Forbidden
                                          (sketchucation.com)
                                          Okay Rich,... I am working on it... πŸ‘ 13% progress..
                                          • majidM
                                            majid
                                            29% without any denoising and I believe it is good enough.
                                            I stopped it on 49% progress and it seems good (despite without any denoising)
                                            49% progress
                                            • 2 / 6
