    Rayscaper Alpha Version Available
    114 Posts 14 Posters 17.3k Views 14 Watching
      @pc10pc said:
      I'm on SU 21.1.332 and having the same issues with toolbar not showing up.
      Could you check if you can get it via these instructions? If that doesn’t help, send me a private message.
      Cheers,
      Thomas
      • majidM Offline
        majid
        I watched your YouTube video and seems the engine is great. Just installed and seems I have a problem. Maybe because I have no SCF plugin toolbar installed.
        PS: it solved, I installed the SCF plugin and now I have the Rayscraper!
        • majidM Offline
          majid
          It works charmingly!
            I'd love to see you try this on it....
            403 Forbidden
            (sketchucation.com)
            • majidM Offline
              majid
              403 Forbidden
              (sketchucation.com)
              Okay Rich,... I am working on it... 👍 13% progress..
              • majidM Offline
                majid
                29% without any denoising and I believe it is good enough.
                I stopped it on 49% progress and it seems good (despite without any denoising)
                49% progress
                  It's great to see a talented artist like you taking an interest in Rayscaper! I saw you sent me some feedback, so I will go and digest that.
                  Cheers,
                  Thomas
                  • jo-keJ Offline
                    jo-ke
                    due to the sunset of twilghtrender I stumbled across this new alternative.
                    downloaded and licensed it today.
                    looks promissing....
                    http://www.zz7.de
                    • jo-keJ Offline
                      jo-ke
                      Is there a tutorial for glass and emitter materials?
                      http://www.zz7.de
                        It has a Glass shader in the Material Type dropdown[1]
                        https://i.imgur.com/fijdO8c.png
                        and for the Disney shader you can enable Emmission for geometry[2]
                        • jo-keJ Offline
                          jo-ke
                          Thank you: glas, is solved.
                          emitter not. with "blackbody emission" I don't get the submenu
                          also hidden layers are rendered. how can I avoid this?
                          http://www.zz7.de
                            You should be able to to open the submenu by clicking the chevron or text (1). You can expand everything by clicking the plus button (2):
                            Hidden objects / tags / layers isn't supported yet in the alpha version. It will be there for the 1.0 version.
                            Cheers,
                            Thomas
                            • jo-keJ Offline
                              jo-ke
                              thank you. I didn't see this. solutions are so simple....
                              next problems:
                              is it possible to do an emitter with textures? like in my example the sign of the tramway?
                              why can't I get rid of the blue textures? they are textured in SU and all faces are frontfaces
                              http://www.zz7.de
                                This is also planned for one of the upcoming releases but it's not there yet.
                                Hmm, this usually means that the face doesn't have a material assigned to it. Or the image textures couldn't be found.
                                Can you select the material in the Rayscaper viewport with the material picker?
                                Once, selected can you try to reload the material via the reload button? This will refresh the material, resetting it to the latest changes made in SketchUp.
                                If all that fails, can you send me the scene? You can zip up the scene with all Rayscaper settings and textures using the following button on the Rayscaper toolbar:
                                You can either send me a private message or send it to thomas@rayscaper.com.
                                I appreciate your patience!
                                Cheers,
                                Thomas
                                • jo-keJ Offline
                                  jo-ke
                                  I installed your app at my notebook at home.
                                  unfortunately sketchup is crashing after using your plugin...
                                  maybe my notebook is to old...
                                  everytime i load a file worked with your app sketchup crushes.
                                  I removed your plugin and fortunately sketchup works again.
                                  so I have to ry tomorrow in the office.
                                  http://www.zz7.de
                                    Yikes, that's not good! Sorry about that.
                                    • Rayscaper creates a log file under your home directory named SUEX_Rayscaper.log (e.g., C:/Users/Thomas Loockx/SUEX_Rayscaper.log). Do you mind getting me that file?
                                    • What version of SU are you using?
                                    • jo-keJ Offline
                                      jo-ke
                                      I am using 23.1.340 64 bits
                                      arguments; SUEX_Rayscaper
                                      Current dir; C;\ProgramData\SketchUp\SketchUp 2023\SketchUp
                                      File verbosity level; 0
                                      date       time         ( uptime  ) [ thread name/id ]                   file;line     v|
                                      2024-01-04 20;15;43.430 (   0.034s) [main thread     ]             loguru.cpp;770   INFO| Logging to 'C;\Users\Kehlj/SUEX_Rayscaper.log', mode; 'w', verbosity; 0
                                      2024-01-04 20;15;43.613 (   0.218s) [main thread     ]      AppController.cpp;73    INFO| Running Rayscaper version 0.7.3
                                      2024-01-04 20;15;43.614 (   0.218s) [main thread     ]      AppController.cpp;74    INFO| System info; Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz (4 cores), 31 GB ram
                                      2024-01-04 20;15;43.614 (   0.218s) [main thread     ]      AppController.cpp;75    INFO| OS info; Windows 10 (64-bit)
                                      2024-01-04 20;15;43.614 (   0.219s) [main thread     ]      AppController.cpp;80    INFO| Host app; SketchUp Pro, 23.1.340
                                      2024-01-04 20;15;43.614 (   0.219s) [main thread     ]SketchupWindowFloater.c;28    INFO| Found SketchUp window handle (title; SketchUp); 0000000000511A04
                                      2024-01-04 20;15;43.629 (   0.233s) [main thread     ]       Orchestrator.cpp;90    INFO| All workers stopped
                                      2024-01-04 20;17;31.214 ( 107.818s) [main thread     ]       Orchestrator.cpp;90    INFO| All workers stopped
                                      2024-01-04 20;17;32.864 ( 109.468s) [main thread     ]             loguru.cpp;485   INFO| atexit
                                      http://www.zz7.de
                                        Thanks for sharing the log!
                                        Based on the PC specs I see in the log, Rayscaper should just work fine for your laptop. Also from the logs it looks like the application runs fine for 109 seconds and then just exits, so no crash (note: I'm not disputing it's not crashing on your laptop, just that it seems like it didn't crash based on this log file).
                                        A couple of questions:
                                        • Does SU crash for you immediately if you start up, or if you load a specific file, or if you start rendering that file?
                                        • Does it work for any other files, or for the default empty scene?
                                        • Do you mind reproducing the crash again and sending me another log file?
                                        Appreciate your help!
                                        Cheers,
                                        Thomas
                                        • jo-keJ Offline
                                          jo-ke
                                          I am back in my office and have the same issue.
                                          I can not open again the file of the tramway, that I saved with the render settings a day before.
                                          When I open an empty skp file it works, when I open the tramwayfile su imidiatly crashs.
                                          I'll send you my file via email, to inspect.
                                          here is the protocol:
                                          2024-01-05 09;16;43.616 (   0.026s) [main thread     ]             loguru.cpp;770   INFO| Logging to 'C;\Users\KehlJ/SUEX_Rayscaper.log', mode; 'w', verbosity; 0
                                          2024-01-05 09;16;43.778 (   0.188s) [main thread     ]      AppController.cpp;73    INFO| Running Rayscaper version 0.7.3
                                          2024-01-05 09;16;43.779 (   0.189s) [main thread     ]      AppController.cpp;74    INFO| System info; Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz (4 cores), 15 GB ram
                                          2024-01-05 09;16;43.779 (   0.189s) [main thread     ]      AppController.cpp;75    INFO| OS info; Windows 10 (64-bit)
                                          2024-01-05 09;16;43.779 (   0.189s) [main thread     ]      AppController.cpp;80    INFO| Host app; SketchUp Pro, 23.1.340
                                          2024-01-05 09;16;43.779 (   0.189s) [main thread     ]SketchupWindowFloater.c;28    INFO| Found SketchUp window handle (title; SketchUp); 0000000000030BF2
                                          2024-01-05 09;16;43.788 (   0.198s) [main thread     ]       Orchestrator.cpp;90    INFO| All workers stopped
                                          2024-01-05 09;16;44.019 (   0.428s) [                ]   AssLibController.cpp;74    INFO| Loaded 1133 assets in 248.82 millis
                                          http://www.zz7.de
                                          • jo-keJ Offline
                                            jo-ke
                                            I created a new scene, imported the same model, hit the refresh but some faces still remained blue.
                                            I've sent you the file to review what's wrong.
                                            http://www.zz7.de
                                            • 2 / 6
