    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 917.1k Views 122 Watching
    • G
      gabichiele
      @rich o brien said:
      @gabichiele said:
      Hello there,
      When I try to download FredoTools it says "the file doesn't exist". I already have LibFredo6 installed. Am I doing something wrong?
      Cheers.
      Gabriela
      There was a glitch in the matrix last night and the server holding the rbz files decided to go on holidays.
      It came back early this morning looking tanned, relaxed and ready for a fight ๐Ÿ‘
      Yay! That's wonderful, thank you!
      • V
        veronikalietavova Newcomers
        Hello there,
        I have the latest version of FredoTools-v 4.3a and lately the plugin ThruPaint stopped working correctly. It seems like "it is running" but the icons are invisible. It only shows the plugins toolbars background. Here is also the screenshot of the toolbar. I tried to check for any updates, see if that might be the solution of this, but "Check Fredo6 Plugins for update" window is not opening as well. ๐Ÿ˜• Thanks for any advice in advance.
        • fredo6F
          @veronikalietavova said:
          Hello there,
          Could you please open the Ruby Console before launching the tools and advise whether there are error messages displayed.
            sirflor
            Will we See Fredo-Plugins for Ketchup on iPad ever?
            (it is more a hope than a believe)
            • fredo6F
              @sirflor said:
              Will we see Fredo-Plugins for Sketchup on iPad ever?
              It's more a conjecture....
              Two possibilities:
              ...when Ipad and other web versions of SketchUp support plugins. But also, this assumes that I write the plugins in this framework, whcih would likely be very different of the Ruby-based environment of Sketchup desktop.
              1. Trimble integrates the features within Sketchup Ipad and Web.
              • O
                oZanimal
                Some features not working.
                • Elements Stats (shows the frames but not the texts)
                • Report on Areas
                • Label with Areas
                Fredo6 Fredo Tools 4.3a - 03/06/22
                SketchUp Pro 2022.0.354 64-bit
                Windows 10 Pro 22H2
                The "Fredo Tools - Elements Stats - appearance.png" attached file is a printscreen of how it is working on my SketchUp test file (TESTE.skp).
                The others one are about versions of SketchUp and Fredo Tools.
                SketchUp version.
                SketchUp Extension Manager
                ![How "Elements Stats" feature appears to me.](/uploads/imported_attachments/yKjf_FredoTools-ElementsStats-appearance.png "How "Elements Stats" feature appears to me.")
                • fredo6F
                  • Report on Areas
                  • Label with Areas
                  Could you upgrade to LibFredo6 v13.6a. This should solve the problem.
                    Jw81
                    Dear Fredo:
                    Hi, I would like to know if the license perpetual/ one time purchase? "Fredo6Bundle2022 - A bundle of 8 plugins"
                      The licenses, including those in the bundle are perpetual, and only need to be purchased once.
                      Each license also lets you validate it on up to three different computers, so for example, you can use it at your home, in the office and on a laptop...
                      • fredo6F
                        NEW RELEASE: FredoTools v4.4a - 13 Nov 23
                        Requirement: LibFredo6 v12.5a or above
                        FredoTools 4.4a fixes a bug in SolidVolume, whereby the volumes of scaled objects could be mis-computed. It also adds the capability to compute the volume of pusedo-solids.
                        See FredoTools plugin home page for Download.
                        See also main post of this thread for User Discussion.
                          mstumpo
                          Surface on tools stopped working on SU 2023. I see on the site that I can use the normal TOS for later versions of SU but can't seem to find a link for that. Really need that plugin to work on a project.
                            Tools on Surface is working fine for me in SketchUp 2023. Share your .skp file so we can see what you are working with and what might be causing the problem.
                              mstumpo
                              File is attached. I re-downloaded the RBZ and license file, removed p[lug-in and re-added back. I don't see a place to use the license file and the plug-in is not complaining that a license was not found.
                              Tools on surface not working.skp
                                mstumpo
                                In addition, while checking my sketchucation license status it shows Tools On Surface as 0/3 as if it was not licensed. Maybe that's the issue?
                                  You need to save the license file[s] somewhere sensible - I use a special licensing folder in my Documents.
                                  Then you validate the license for that extension by using the validate button etc in the Tools > Fredo6 Collection > ExtensionName > License... submenu for that extension, which opens a dialog...
                                    PS: Also make sure that you have installed the latest version of the extension, LibFredo6 and the SketchUcation toolset [for the licensing], and have restarted SketchUp...
                                      mstumpo
                                      Tools On Surface not displayingOK, I got past this and all appears good. However, the toolbar for Tools On Surface is blank on my screen. In fact, any plugin that uses on-screen options shows as blank. Nvidia driver issue? see attached.
                                      • fredo6F
                                        NEW RELEASE: FredoTools v4.5a - 02 Apr 24
                                        Requirement:
                                        • LibFredo6 v14.3b or above
                                        FredoTools 4.5a is a maintenance release for:
                                        • Future compatibility
                                        yanrothwellY 1 Reply Last reply
                                        • yanrothwellY
                                          yanrothwell @fredo6
                                          @fredo6 Hi I have used Fredo6's tools for manyt years and they are always super useful.
                                          At present, since SU2024 I have had issues with SUClock, which I stopped using whilst it was updated.
                                          I've since started using SUClock since the update and its been working fine.
                                          Today I started up SU2024 with an existing project (double clicking on the skp file itself, incase that is ever relevant how I 'opened up' the file) and I got the following error.
                                          This error hasn't gone away and did not start working up next restart of SU2034, so I wonder if you can help - Screenshot 2024-06-04 104337.png
                                          I see the icon of SUClock but it does nothing when clicked on.
                                          Multiple restarts have not fixed anything. There are similar errors with ThruPaint and Toposhaperm unforrtunately. Can anyone help? plugin information as follows:
                                          Fredo6 Plugins Information on 2024-06-04 12:00:59 +0100
                                          • Sketchup: 24.0.484
                                          • LibFredo6: v14.5b
                                          • LibFredo6 Binary loaded
                                          • Sketchucation ExtensionStore: 4.4.0
                                          • SCFLicense: v6.4a - 74
                                          • Fredo6 Plugins
                                            LordOfTheToolbars v2.7b
                                            Curviloft v2.0a - licensed FULL
                                            Curvizard v2.5a
                                            FredoCorner v2.7a - licensed FULL
                                            FredoScale v3.6a - licensed FULL
                                            FredoTools v4.5a
                                            JointPushPull v4.8a - licensed FULL
                                            SUClock v3.1a
                                            ToolsOnSurface v2.6a - licensed FULL
                                            TopoShaper v2.7a - licensed FULL
                                            Signature File: 2022-03-30 14:03:14 +0100
                                            ClothWorks: 2022-10-27 15:42:55 +0100
                                            Curviloft: 2022-09-03 15:21:17 +0100
                                            FredoCorner: 2024-03-04 13:57:21 +0000
                                            FredoScale: 2022-04-25 11:42:35 +0100
                                            FredoSpline: 2022-11-21 16:26:56 +0000
                                            JointPushPull: 2022-05-08 14:44:25 +0100
                                            ToolsOnSurface: 2022-04-25 13:46:45 +0100
                                            TopoShaper: 2022-09-02 16:10:20 +0100
                                          MrHide_1.8a
                                          AutoInstall Finished.
                                          Using Main Plugins Folder.
                                          C:/Users/<user>/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins
                                          http://www.ianrothwell.co.uk
                                          fredo6F 1 Reply Last reply
                                          • fredo6F
                                            fredo6 @yanrothwell
                                            @yanrothwell
                                            Did you install SU2024 with 'Run as dministrator'?
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 23 / 24
