    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 917.2k Views 122 Watching
    • O
      oZanimal
      Some features not working.
      • Elements Stats (shows the frames but not the texts)
      • Report on Areas
      • Label with Areas
      Fredo6 Fredo Tools 4.3a - 03/06/22
      SketchUp Pro 2022.0.354 64-bit
      Windows 10 Pro 22H2
      The "Fredo Tools - Elements Stats - appearance.png" attached file is a printscreen of how it is working on my SketchUp test file (TESTE.skp).
      The others one are about versions of SketchUp and Fredo Tools.
      SketchUp version.
      SketchUp Extension Manager
      ![How "Elements Stats" feature appears to me.](/uploads/imported_attachments/yKjf_FredoTools-ElementsStats-appearance.png "How "Elements Stats" feature appears to me.")
      • fredo6F
        • Report on Areas
        • Label with Areas
        Could you upgrade to LibFredo6 v13.6a. This should solve the problem.
          Jw81
          Dear Fredo:
          Hi, I would like to know if the license perpetual/ one time purchase? "Fredo6Bundle2022 - A bundle of 8 plugins"
            The licenses, including those in the bundle are perpetual, and only need to be purchased once.
            Each license also lets you validate it on up to three different computers, so for example, you can use it at your home, in the office and on a laptop...
            • fredo6F
              NEW RELEASE: FredoTools v4.4a - 13 Nov 23
              Requirement: LibFredo6 v12.5a or above
              FredoTools 4.4a fixes a bug in SolidVolume, whereby the volumes of scaled objects could be mis-computed. It also adds the capability to compute the volume of pusedo-solids.
              See FredoTools plugin home page for Download.
              See also main post of this thread for User Discussion.
                mstumpo
                Surface on tools stopped working on SU 2023. I see on the site that I can use the normal TOS for later versions of SU but can't seem to find a link for that. Really need that plugin to work on a project.
                  Tools on Surface is working fine for me in SketchUp 2023. Share your .skp file so we can see what you are working with and what might be causing the problem.
                    mstumpo
                    File is attached. I re-downloaded the RBZ and license file, removed p[lug-in and re-added back. I don't see a place to use the license file and the plug-in is not complaining that a license was not found.
                    Tools on surface not working.skp
                      mstumpo
                      In addition, while checking my sketchucation license status it shows Tools On Surface as 0/3 as if it was not licensed. Maybe that's the issue?
                        You need to save the license file[s] somewhere sensible - I use a special licensing folder in my Documents.
                        Then you validate the license for that extension by using the validate button etc in the Tools > Fredo6 Collection > ExtensionName > License... submenu for that extension, which opens a dialog...
                          PS: Also make sure that you have installed the latest version of the extension, LibFredo6 and the SketchUcation toolset [for the licensing], and have restarted SketchUp...
                            mstumpo
                            Tools On Surface not displayingOK, I got past this and all appears good. However, the toolbar for Tools On Surface is blank on my screen. In fact, any plugin that uses on-screen options shows as blank. Nvidia driver issue? see attached.
                            • fredo6F
                              NEW RELEASE: FredoTools v4.5a - 02 Apr 24
                              Requirement:
                              • LibFredo6 v14.3b or above
                              FredoTools 4.5a is a maintenance release for:
                              • Future compatibility
                              yanrothwellY 1 Reply Last reply
                              • yanrothwellY
                                yanrothwell @fredo6
                                @fredo6 Hi I have used Fredo6's tools for manyt years and they are always super useful.
                                At present, since SU2024 I have had issues with SUClock, which I stopped using whilst it was updated.
                                I've since started using SUClock since the update and its been working fine.
                                Today I started up SU2024 with an existing project (double clicking on the skp file itself, incase that is ever relevant how I 'opened up' the file) and I got the following error.
                                This error hasn't gone away and did not start working up next restart of SU2034, so I wonder if you can help - Screenshot 2024-06-04 104337.png
                                I see the icon of SUClock but it does nothing when clicked on.
                                Multiple restarts have not fixed anything. There are similar errors with ThruPaint and Toposhaperm unforrtunately. Can anyone help? plugin information as follows:
                                Fredo6 Plugins Information on 2024-06-04 12:00:59 +0100
                                • Sketchup: 24.0.484
                                • LibFredo6: v14.5b
                                • LibFredo6 Binary loaded
                                • Sketchucation ExtensionStore: 4.4.0
                                • SCFLicense: v6.4a - 74
                                • Fredo6 Plugins
                                  LordOfTheToolbars v2.7b
                                  Curviloft v2.0a - licensed FULL
                                  Curvizard v2.5a
                                  FredoCorner v2.7a - licensed FULL
                                  FredoScale v3.6a - licensed FULL
                                  FredoTools v4.5a
                                  JointPushPull v4.8a - licensed FULL
                                  SUClock v3.1a
                                  ToolsOnSurface v2.6a - licensed FULL
                                  TopoShaper v2.7a - licensed FULL
                                  Signature File: 2022-03-30 14:03:14 +0100
                                  ClothWorks: 2022-10-27 15:42:55 +0100
                                  Curviloft: 2022-09-03 15:21:17 +0100
                                  FredoCorner: 2024-03-04 13:57:21 +0000
                                  FredoScale: 2022-04-25 11:42:35 +0100
                                  FredoSpline: 2022-11-21 16:26:56 +0000
                                  JointPushPull: 2022-05-08 14:44:25 +0100
                                  ToolsOnSurface: 2022-04-25 13:46:45 +0100
                                  TopoShaper: 2022-09-02 16:10:20 +0100
                                MrHide_1.8a
                                AutoInstall Finished.
                                Using Main Plugins Folder.
                                C:/Users/<user>/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins
                                http://www.ianrothwell.co.uk
                                fredo6F 1 Reply Last reply
                                • fredo6F
                                  fredo6 @yanrothwell
                                  @yanrothwell
                                  Did you install SU2024 with 'Run as dministrator'?
                                  • yanrothwellY
                                    yanrothwell @fredo6
                                    @fredo6 yes
                                    • fredo6F
                                      fredo6 @yanrothwell
                                      @yanrothwell
                                      Could you open the Ruby console and copy paste the following command, and then type Enter:
                                      UI.openURL F6_SUClock::Project.get_tmpdir
                                      This will open the temp directory, in which you have files with extension .txt and a form like XXX__YYY.txt.
                                      Just erase them. It seems that one of them is corrupted.
                                      Erasing them should not impact your SUClock data.
                                      Then restart Sketchup.
                                      • yanrothwellY
                                        yanrothwell @fredo6
                                        @fredo6 Many thanks - after doing just that and restarting, it worked. no errors upon startup.
                                        Cheers \o/
                                        • fredo6F
                                          NEW RELEASE: FredoTools v4.5c - 24 Jun 24
                                          Requirement:
                                          FredoTools 4.5c is a maintenance release for:
                                          • Fix for the caluclation of volumes in SolidVolume
                                            rv1974
                                            a true Doh! moment - Angle Inspector has Slope meter in %% ! Many many thanks, Fredo.
                                            P.S. Maybe one day it would become interactive - showing live the slope altering.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 23 / 24
